Old Fri, Jun-25-2010, 03:39:17 AM   #1
Matthew C Smith
Reputation: 0 Matthew C Smith is on a distinguished road
Default Rear Toe Alignment Tool
Does anyone have a lead on the tool to set the toe on the rear of an e46 M3? I believe it will work with any e46. It slips over one of the nuts/studs and the little tab on the RTAB bracket.
My local independent shop would like to use it, but is not interested in purchasing it.
Is this typically used?
Jump to top Matthew C Smith is offline   Reply With Quote
Old Mon, Jun-28-2010, 05:23:22 PM   #2
Matthew C Smith
Anyone?
Old Mon, Jun-28-2010, 05:26:33 PM   #3
rantarM3
Reputation: 0 rantarM3 is on a distinguished road
Is this what you are referring to?
Jump to top rantarM3 is offline   Reply With Quote
Old Mon, Jun-28-2010, 05:40:59 PM   #4
zivagolee
Reputation: 0 zivagolee is on a distinguished road
Most ppl just eyeball it. I have this tool if anyone wants to purchase it (only used it twice).
2003 Orient Blue M3
Jump to top zivagolee is offline   Reply With Quote
Old Mon, Jun-28-2010, 05:50:06 PM   #5
nrubenstein
It's completely ****ing useless if you don't have a full alignment rack. Banging on the wheel is more precise when you're using strings. Trust me.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison
2002 BMW M3 Alpinweiß/Black - JBL MS-62C, IDQ-12v3, JBL MS-8
1989 325is Alpinweiß/Black - S50B30, GC/Koni, Sways, BBS RX, Hybrid C61-2, Sundown SA-12, JBL MS-8
1989 M3 Alpinweiß/Black - S50B32. 321hp.
Hers: 1996 Porsche 911 Turbo Black/Black
Hers: 1988 325iX Coupe Diamondschwartz/Black 5spd - Korman lengthened front driveshaft, Cam, Bilstein, H&R Sport, snow chains.
Old Mon, Jun-28-2010, 05:54:26 PM   #6
zivagolee
Unless you are asking about that round little tool so you can adjust toe easier? I also got this when doing alignment with strings as well. It helps to make the minute adjustments easier.
2003 Orient Blue M3
Old Mon, Jun-28-2010, 06:21:34 PM   #7
Matthew C Smith
Attachment 120088
No, it's some sort of a cam/rotate tool that slips over one of the bolts to turn/move the RTAB carrier in relation of the chassis.
That tool just makes sure the RTAB carrier is properly set in relation to the trailing arm.
Old Mon, Jun-28-2010, 06:23:06 PM   #8
Matthew C Smith
Yeah, that's the one I think.
Old Mon, Jun-28-2010, 06:48:43 PM   #9
zivagolee
It's not *needed* but it does help make adjustments easier. I haven't been to any alignment shop that actually has it and it seems they live without just fine.
2003 Orient Blue M3
Old Mon, Jun-28-2010, 07:01:33 PM   #10
Matthew C Smith
I agree with you. I've done and had alignments done on other 3 series without issue.
I was just curious if it was commonly used and available.
alignment, rear, toe, tool
Discussing Rear Toe Alignment Tool in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
