Old Fri, Jun-25-2010, 03:25:17 PM   #1
notopM3
Reputation: 0 notopM3 is on a distinguished road
Default California smog check
Just had my smog check yesterday and barely passed. Everything was good except the HC test. This test measures the amount of unburnt fuel leaving the engine. The max allowable is 54 parts per million, average is 9...I was at 53. All the other tests were almost perfect.
Any suggestion on how to get that number down?
Jump to top notopM3 is offline   Reply With Quote
Old Fri, Jun-25-2010, 05:19:52 PM   #2
camdinans3
Resident Rabble Rouser
camdinans3's Avatar
Reputation: 0 camdinans3 is on a distinguished road
new spark plugs and maybe clean your MAF and IVC
did you drive the car really hard right beforehand to get the cats hot?
Andrew: AVUS 1995
///95 Supercharged Club
Jump to top camdinans3 is offline   Reply With Quote
Old Fri, Jun-25-2010, 05:20:33 PM   #3
M3Blurr
Turd bro S54 retard!
M3Blurr's Avatar
Reputation: 0 M3Blurr is on a distinguished road
How many miles on the spark plugs and oil? Tune up might be needed before attempting an inspection next year.
Jump to top M3Blurr is offline   Reply With Quote
Old Fri, Jun-25-2010, 06:01:43 PM   #4
M3n00b
2012 Formula 1 Game Champion!!!
M3n00b's Avatar
Car wasn't warm enough....
2013 F1 Game:
Originally Posted by propchef View Post
Ferrari to Alonso: F**k the tires, full speed ahead.
Old Fri, Jun-25-2010, 06:45:32 PM   #5
das borgen
Off-Topic King
das borgen's Avatar
Reputation: 0 das borgen is on a distinguished road
all 3 answers could explain your "problem"
Jump to top das borgen is offline   Reply With Quote
Old Sat, Jun-26-2010, 05:47:25 AM   #6
notopM3
I changed the plugs about 8 months ago. Cleaned the MAF about the same time. WHat's the IVC? Didn't really drive hard before the check.
Old Sat, Jun-26-2010, 05:48:41 AM   #7
notopM3
Fortunately I only have to get it done every other year. I just changed the oil about 2,000 miles ago with Mobile 1. Plugs are about 8 months old.
Old Sat, Jun-26-2010, 05:56:07 AM   #8
Zummie
Alpine Phoenix Owner
Zummie's Avatar
Reputation: 0 Zummie is on a distinguished road
I got my car smogged on Tuesday morning and passed with flying colors and had 1s and 2s for everything. I drove my car around for 20 minutes before I got it smogged. I got it fully warm and then some. When you do end up not passing replace all of your O2 sensors and you should be good after that.
-Jonathan
1998 M3 Sedan, Alpine White - Black
Dinan Exhaust, Dinan CAI, Dinan Stage 2 Software, X-Brace, Front H&R Sway Bar, UUC Black TMEs, RE RSMs, Rear TCKline Koni's and Front S/A Koni's, H&R OE Sports, GC RTAB Shims, Stewart WP, Zionsville Radiator, Depo IV w/ DDM 55W 6K HIDs, DDM 55W 6K HID Fogs, JTD Underpanel, Z3 Steering Rack, Hyper Silver Arc-8's 17x9 with 245/40s and V1
Jump to top Zummie is online now   Reply With Quote
Old Sat, Jun-26-2010, 06:10:11 AM   #9
notopM3
The guy at the check place mentioned the O2 sensors.
Old Sat, Jun-26-2010, 05:44:14 PM   #10
alanil
Reputation: 0 alanil is on a distinguished road
If you want to save some $$ just do the pre-cat ones. Those are the only ones used by the engine for air fuel mixture. They should be replaced at about 100k miles to keep the car running most efficiently and with the lowest emissions.
The post cat O2s are for the car to sense that the cats are working. The computer is just checking the voltage of those O2s for a "pass" or "fail".
Jump to top alanil is offline   Reply With Quote
california, check, smog
Discussing California smog check in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
