Old Sun, Jun-27-2010, 06:44:24 AM   #11
M3&CLK55
M3&CLK55's Avatar
Reputation: 0 M3&CLK55 is on a distinguished road
Taiwan
Originally Posted by adykahung View Post
my symptom is similar to yours, i may need to find my mechanic and see what he said. if that's really trail arm bushing, is it necessary to repair it immedicately? also, how much you pay for the repair? Thanks
I asked my mechanic to sit in my car and listen to the noise, he told me it is caused by the bushing. but you will never know. My mechanic told me, it is ok to drive the car for a while. it does not have to be replaced right away.i am planning to get it done by next month, as soon as i get it done i will let you know the cost.
p.s i had replaced my P/S pump 40k miles ago and p/s high pressure hose 500 miles ago, so i am pretty sure it is not cause by failing p/s pump.
Jump to top M3&CLK55 is offline   Reply With Quote
Old Sun, Jun-27-2010, 07:40:22 AM   #12
///M3-QTR
ॡحمدॡ
///M3-QTR's Avatar
Reputation: 0 ///M3-QTR is on a distinguished road
Qatar
Have you ever changed the differential fluid ?
Euro 01 IR/IR ///M3 113K miles|281rwhp on DD
^ SOLD^
Engine: aFe drop in filter, SS race exhaust |Drivetrain: AS Ultimate SSK w/ UUC DSSR, ZHP shifter knob, GSP clutch pedal.
Suspension : AST 5100's 600/750 w/ Vorshlag camber plates, PF RTAB's, RE RSM, UUC adjustable rear camber arms, TMS reinforcement kit & endlinks |Braking: Cool Carbon, StopTech SS lines| Exterior: Alufelgen SF-71's, VORS(1x1) CSL bumper, trunk and diffuser,OEM rear LED's, blackout front grills, CF side grills , smoked corners and side signal lights, TFX conversion, Umnitza 4300K V2's angle eyes, Euro wide convex mirrors| Interior: US spec trunk release button, OEM alcantara boot, OEM alum pedals.
Jump to top ///M3-QTR is offline   Reply With Quote
Old Sun, Jun-27-2010, 12:43:54 PM   #13
325prada
ClubsportM3
325prada's Avatar
Reputation: 0 325prada is on a distinguished road
Sounds like a fcab. More specifically the front right. Especially if you have headers...mine vibrates against the headers everytime I enter long left sweeping turns.
Jump to top 325prada is offline   Reply With Quote
Old Sun, Jun-27-2010, 03:32:02 PM   #14
adykahung
Reputation: 0 adykahung is on a distinguished road
i changed my diff oil about half year before, and the wried noise is not from rear. is from the front end.
Jump to top adykahung is offline   Reply With Quote
Old Sun, Jun-27-2010, 03:33:20 PM   #15
adykahung
how can i check my FCAB? do i need to take off my wheels? can i check it on a ramp?
Old Sun, Jun-27-2010, 03:35:14 PM   #16
adykahung
Thanks for your advice, i will check my P/S fluid level and any leak. please keep me update on your repair.
Old Sun, Jun-27-2010, 04:45:40 PM   #17
EYEHAVEYOU
likes it raspy
EYEHAVEYOU's Avatar
I had knocking/creaking noise from the steering wheel when doing tight turns. I could not replicate the sound turning the wheel at a stop.
Flushing my power steering fluid solved it for me.
2005 M3 ZCP 6MT - Alpine White /// Imola Red
Old Sun, Jun-27-2010, 11:49:55 PM   #18
adykahung
i did some research on P/S flush and i find this DIY as reference. here is the link. http://forum.e46fanatics.com/showthread.php?t=696928
when i go through the DIY steps, until step 19, i need to trun my steering wheel when my car is off. i found my steering wheel is hard to turn, i turn my key to position 2 already without turn on the car as mention on DIY. and i barely can turn my steering wheel from 12 o'clock position to 2 o'clock position. i can not make a full turn, is it normal? how can i turn the wheel from lock to lock position withour turn on the car?
Old Mon, Jun-28-2010, 12:12:10 AM   #19
EYEHAVEYOU
likes it raspy
EYEHAVEYOU's Avatar
I followed parts of that DIY as well, but I didn't remove the airbox (it was a tight fit to the resevoir cap, but definitely do-able). I also tried turning the wheel with the engine off and had a lot of difficulty. I eventually just started the car and turned the wheel, I didn't encounter any problems. I did this with the resevoir cap off and went back and forth to lock several times - repeated each time I drained the reservoir. Hope this helps.
FYI you're probably aware of this already, but you can't use power steering fluid, you need to use ATF (it should say ATF only on the cap). Just a reminder to you or anyone else who has similar symptoms.
Old Mon, Jun-28-2010, 12:46:36 AM   #20
adykahung
yes, i am able to reach the resevoir without removing the air box, i found a photo that the fitting is really close to a belt, i may just do "simple flush", here is "simple flush" reference. http://www.dvatp.com/bmw/diy/power_steering_flush/ i am afraid to contaminate the belt when i drain from the fitting. i think repeat the "simple flsuh" for 2 quarts of fluid should be enough to change majority of the fluid? or should i repeat more?
also i am planing to use Pentosin CHF 11S Power Steering Fluid, i think it is remmended by many m3forum fellows.
if i change the power strreting flsuh and still can not solve the wried noise, then i may need to check my FCAB.
noice, steering, tight, turn, weird
Discussing Weird noice from steering when tight turn? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
