Old Wed, Jul-07-2010, 10:38:35 PM   #1
1QWKBMR
Reputation: 0 1QWKBMR is on a distinguished road
Default Camshaft Position Sensor (exhaust) e46 M3
Looking for the DIY on the Camshaft Position Sensor Exhaust replacement as well as how to get the air ducts right & left off from the radiator. http://www.realoem.com/bmw/showparts...07&hg=17&fg=05
Appreciate it...
Thank you
1QWK-BMR
Jump to top 1QWKBMR is offline   Reply With Quote
Old Wed, Jul-07-2010, 10:47:46 PM   #2
maveric23
maveric23's Avatar
Reputation: 0 maveric23 is on a distinguished road
This thread might help:
http://www.m3forum.net/m3forum/showthread.php?t=244167
Do you wish that Double VANOS never existed? Vote!
2004 Silver Gray/Black M3 Convertible
Jump to top maveric23 is offline   Reply With Quote
Old Wed, Jul-07-2010, 11:35:38 PM   #3
bzsbimmer
Reputation: 0 bzsbimmer is on a distinguished road
South Korea
It's a lot easier than replacing the intake cam sensor.
No real tricks other than what was posted on the other thread but once you get it loose see if you can remove it with those small finger ratchets.
I used a small 1/4" ratchet. It's really easy if you're swapping it out when you're adjusting your valves as there is a lot more room because the valve cover is off.
Helping the economy one mod at a time
2004 Mystic Blue
Jump to top bzsbimmer is online now   Reply With Quote
Old Sat, Jul-10-2010, 04:31:34 AM   #4
1QWKBMR
Well here is my follow-up so far: finally got the 5mm bolt off. Wow!!!
I will be adding some recommendations and a few pictures. When done. Got the CPS out and the new one from BMW # 13 62 7 796 054 does not fit. Progress has stalled until the stealership opens in the morning.
All I can say is my back hurts, my hands are not too badly scraped, but let me tell you the only thing running through my mind the entire time is this...
http://www.youtube.com/watch?v=pPzHtVhc_DU
This is exactly what the German engineers were thinking...
Old Sat, Jul-10-2010, 08:11:53 AM   #5
Philly_swedem
Philly_swedem's Avatar
Reputation: 0 Philly_swedem is on a distinguished road
Sweden
it's a pita
I removed my strut brace to reach it easier, stood on the left side of the car and scraped my hands really bad, hot as hell as well
gl
Jump to top Philly_swedem is offline   Reply With Quote
Old Sat, Jul-10-2010, 12:33:44 PM   #6
1QWKBMR
Solid black is the original and the light gray is the new. New one does not fit.
Suggestions please.
Old Sat, Jul-10-2010, 02:33:26 PM   #7
infiniti2424
infiniti2424's Avatar
Reputation: 0 infiniti2424 is on a distinguished road
the new ones a magnum
2005 M3 ZCP IB 55K (Current) Weekend car
2001 Infiniti Q45 80K (Current) Touring car
1994 Lexus SC400 197K (Current) Daily car
1996 Civic LX 96K (SOLD)
2003 WRX 16K (first car...gone)
Jump to top infiniti2424 is offline   Reply With Quote
Old Sat, Jul-10-2010, 02:53:09 PM   #8
maveric23
maveric23's Avatar
Lightbulb
Suggestions please.
According to 01LagunaSecaE46 in http://www.m3forum.net/m3forum/showthread.php?t=244167, "The new sensor will likely be larger than the one you remove. dont let this faze you, as the newer BMW factory part is different than the original, it is larger. im thinking that they beefed up the part, and i'm glad they did, as im not looking forward to replacing this one again any time soon.
Use a new O-ring (of course) as the one you pull out of the head is likely brittle like mine was. it was nowhere near as pliable as the new one, and this is a crucial oil seal, so make it right."
Old Sat, Jul-10-2010, 02:56:45 PM   #9
bzsbimmer
South Korea
That looks like the right part. Make sure your old o-ring isn't still there making it really hard to fit with 2 o-rings
In the picture, it appears that your o-ring is missing from the sensor. Use some oil to lube up the o-ring as well and twist/push it in.
2004 Mystic Blue
Old Sat, Jul-10-2010, 07:01:25 PM   #10
1QWKBMR
Notes:
1. Remove cabin air filter and box
2. Remove Strut Bar (if you have one)
3. Remove oil filler cap
4. Remove crankvent hose
5. Remove Cylinder Head cover
6. 1/4 in ratchet with 5mm short bit
7. Remove the CPS unit from engine - Twist gently and pull
8. Disconnect the CPS sending wire
9. Follow in reverse to install
Recommendations:
1. Allen wrench too hard to use
2. Buy or borrow the 1/4 in ratchet and the 5mm short bit
3. Leave the CPS cable on until the CPS is out of the engine
4. Clean the hole where you took the unit out
5. Add a little clean oil to the new unit and o-ring
6. Add the loctite Blue to the bolt (yes i said bolt see below)
7. Gentlemen and ladies angle of attack is everything. There is no comfortable positon.
Reason there is no good DIY on this is no good way to get pictures. This is the best I could do.
Thank you to all who responded. Also went to the local dealer in Raleigh and the Parts guys and the Tech on site were great. They recommended changing from the Fillister-head screw to a standard bolt (Case Hardened). 16/32 10 mm head.
air duct removal, cam position sensor, camshaft, e46, exhaust, genuine bmw parts, getbmwparts.com, position, sensor, tischer
Discussing Camshaft Position Sensor (exhaust) e46 M3 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
