Old Thu, Jul-08-2010, 07:33:47 PM   #1
fergraz
fergraz's Avatar
Reputation: 0 fergraz is on a distinguished road
Puerto Rico
Default Engine Coolant Temperature Plausibility & Evaporative Emission Purge Control Valve
I have this two codes:
69 Engine Coolant Temperature Plausibility
24 Evaporative Emission Purge Control Valve
Any hint for the troubleshooting?
2002 SMG ///M3 Tiag/Gray leather All Stock with 3x,xxx Miles
Jump to top fergraz is offline   Reply With Quote
Old Fri, Jul-09-2010, 03:53:39 AM   #2
ISPEEDM3
Got Boost?
ISPEEDM3's Avatar
Reputation: 0 ISPEEDM3 is on a distinguished road
Engine coolant temp code is your sensor that sits on one of your radiator hoses. Like 30 buck
[CENTER]
Jump to top ISPEEDM3 is offline   Reply With Quote
Old Tue, Jul-27-2010, 01:07:45 AM   #3
MisterEm
MisterEm's Avatar
Reputation: 0 MisterEm is on a distinguished road
Anyone fixed this yet?
I get a code 69 once every couple of months.
Jump to top MisterEm is offline   Reply With Quote
Old Tue, Jul-27-2010, 04:01:21 AM   #4
fergraz
fergraz's Avatar
Puerto Rico
For the code 69 Engine Coolant Temperature Plausibility I changed the coolant sensor two weeks ago. I don't have the code since this but the problem was intermitent. I don't sure yet if the problem is solved. For the code 24 Evaporative Emission Purge Control Valve I changed the fuel tank breather valve and the problem was solved. This code was present after each trip.
Old Tue, Jul-27-2010, 04:23:30 AM   #5
MisterEm
MisterEm's Avatar
Which sensor did you change? There are two that I am aware of. My code comes up once in a blue moon. But its the same code 69. Last time I got it was in May.
Old Tue, Jul-27-2010, 05:05:14 AM   #6
fergraz
fergraz's Avatar
Puerto Rico
Number 4. But I'm don't sure yet if this has solved my problem.
Old Tue, Jul-27-2010, 05:24:35 AM   #7
maveric23
maveric23's Avatar
Reputation: 0 maveric23 is on a distinguished road
Lightbulb
Do you have to drain the coolant to replace these sensors?
Thanks for any related info!
Do you wish that Double VANOS never existed? Vote!
2004 Silver Gray/Black M3 Convertible
Jump to top maveric23 is offline   Reply With Quote
Old Tue, Jul-27-2010, 12:14:42 PM   #8
fergraz
fergraz's Avatar
Puerto Rico
No, is very easy. You need to do this with a cool car (before turn on the engine the first time on this day).Don't remove the radiator cap. Remove the sensor electrical plug and then the sensor by pressing the two taps and put the new sensor. Make this with the car cool and don't remove the radiator cap to avoid a coolant spill.
Old Tue, Jul-27-2010, 01:25:29 PM   #9
MY02M3DINAN
MY02M3DINAN's Avatar
Reputation: 0 MY02M3DINAN is on a distinguished road
From what I understand about the temp plausability code is that #4 controls the cooling fans, it is #18 that is the temp sender for the gauge/computer.
2002 TiAg M3 Cabriolet
Dinan S-M3 Kit
{Throttle Bodies/CAI/MAF/Stage 4 software}
Dinan Strut tower brace & Front sway bar
Auto Solutions SSK
UUC Motorwerks "Rasp-X" mid-pipe
Urethane RTAB's/FCAB's/RSM's
Hawk HPS Brake Pads
CDV delete
V1 Hardwired
THIS CAR IS NOW FOR SALE!
Jump to top MY02M3DINAN is offline   Reply With Quote
Old Tue, Jul-27-2010, 01:35:10 PM   #10
fergraz
fergraz's Avatar
Puerto Rico
Good information, thanks! I changed #4 because I don't see any wrong in my gage. It is in the middle always after warming. As I said before, I don't know if my problem was fixed because the code was intemitent.
control, coolant, emission, engine, evaporative, plausibility, purge, temperature, valve
Discussing Engine Coolant Temperature Plausibility & Evaporative Emission Purge Control Valve in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
