leebske
![]() Location: Auckland
Hey,
I am having to order my spacers from overseas but want the most aggressive stance possible at the moment as the rims I bought have a 35mm offset at the rear and are 9.5inches. Also, it is lowered so the rim tucks inside the wheel arch so couldnt push it out too much otherwise it will hit Whats the largest possible spacer you think I could go to? Cheers in advance
![]() Mods: VS Work 19" Staggered | CSL Rear Diffuser | K&N Air Intake | H&R Adjustable Suspension | Hamann Exhaust by Supersprint
Autosolutions Ultra SSK | Umnitza Orion V2 Angel Eyes | ZHP Shift Knob & Alcantara Boot | CF Hood Vent | CF Splitters | Smoked Corners Blacked Kidney & Side Gills | LED Rear lights | 30% Tint | Hardwired V1 | Footwell LED Interior Lights | CF Wrap Trim | Charcoal Tail Lights Clutch Stop | CDV Delete Upcoming: Aluminum Pedals | CSL Bootlid |
เป็นคนจีน
![]() Location: Seattle
Pics? What type of tires do you have
2008 ISF, Smokey Granite Mica on Black ![]()
leebske
Sorry to dig this thread up but here are the pics.
Im running 275/35/19s at the rear and it has been lowered on H&R Cup Kit Coilovers and Springs. Whats the largest spacer you think I could get away with? I think the offset is the same as the front like 34/35 ![]() ![]() ![]() ![]()
#4 |
PicFail
measure from your sidewall to the inside of the fender. that is how big of a spacer you can run (I would say minus 5-8mm for rubbing) You can run 10inch wide in the rear with a 25 mm offset with a 10mm spacer (Making a 15mm et) without rubbing |
#5 |
leebske
Sorry im not too familiar with those terms. Where is sidewall-to-inside fender?
#6 |
Chin 3/3 @ VIR Full
![]() Location: Chapel Hill, NC
Yikes, how wide is your wheel? Those tires are horribly stretched for being 275 width. Sweeping those issues under the rug, regarding a spacer it looks like only have room for a few mm at best... By the way a 275/35-19 is a pretty tall tire.
2004 SilverGrey 6MT 2012 VW JSW TDI 6MT Past - '91 Saab 900TC / '98 M3 / '06 WRX / '98 ITR / '88 Saab 9000T |
#7 |
![]() Location: Raleigh NC
Measure this (laterally, not diagonally as I drew it in the picture):
![]() Then subtract 3-5mm to be safe for clearance reason. That's how big of a spacer you can run with any given setup. I would also recommend getting a better wheel / tire setup before getting spacers for cosmetic reason though! Those tires are stretched!
#8 |
Anti-Bling
Either those are wider than 9.5" or your tires are smaller than 275's. 275's aren't even stretched like that on a 10.5" wheel.
Mr. Wolfe
2003 Alpine/Cinnamon ///M3 Coupe 6MT ZCP Wheels l 4.10 Diff. l KWv2 l JVT l ESS l H&R Sway l AR-20's l 10mm/15mm Spacers l ZHP Shift Knob l FK 452's l RE l PF |
#9 |
einpresstiefe
![]() Location: northern california
For the rear without fender roll, you can go up to a 275/30 tire with a 19x10 20et wheel. This will rub when going on harsh bumps or dips, but nothing bad where anything gets damaged. When you roll your fenders, you can probably get an extra 5mm.
For the 9.5" rear you have, you can probably stick a 20mm spacer back there if I'm understanding your post correctly.
| largest, run, spacers |
