| M3 Track: Racing and DE Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! |
likes it raspy
I just purchased a set of front Turner Motorsport Cool Willy track pads from a member on the forum for my upcoming track day. They are true track pads, but work over a wider range of temps than most track pads, not as aggressive as PFC01's by any means.
This will only be my 2nd track day, at my first track day I barely illicited any fade from the stock pads by the end of my last run, so I clearly am not taking full advantage of my brakes yet. That said, will I be safe using these pads just on the front for this next event (with stock pads in the rear), or should I just suck it up and order a set of rear Cool Willy pads from Turner? They recommend that I use the track pads as a set, and while I agree that's typically a good idea, what does the forum think in my specific case? |
Bottom Feeder
![]() Location: Longmont, CO
i wouldn't recommend it, but some folks have gotten away with running OEM pads at the track.
i set a pair on fire after 3 laps... YMMV my 330 hardly used rear pads, the M3 surprisingly uses them a lot.
_ Garrett ![]() 2011 Rocky Mountain Region GTS4 champion & "Rookie of the Year" 2012 Rocky Mountain Region GTS3 champion Thanks Sponsors: SCR Performance |
Goin' crazy... wanna come?
![]() Location: Parker
I'd say you are fine. Better OEMs than some of the other options out there for street pads. If you really didn't have problems with the OEM pads, you'll probably be ok for another event or so.
If you aren't running OEMs in the back, then all bets are off!
2005 Interlagos Blue M3 - Cinammon Interior - ZCP - 6MT - Premium - HK Sound Performance Mods: D/A Race Software, D/A VAC Lightweight UnderDrive Pulleys, Streamline Panel, Ceramic Coated Stainless headers, Race-cats, B&B Tri-Flow, Motons, Vorshlag plates, GC Adj. Rear Camber Arms, GC Race Hybrid FCAB, Powerflex RTABs, H-Sport Sways, GC adjustable endlinks, GSP Clutch Pedal, 40% Autosolutions SSK, Rogue Trans Mounts, PFC WC/GAC front brake kit, PFC-01s for the track. Click Here for nightmare ECS story. - LOL, it was deleted, guess it shows the sponsors can get away with anything here. |
#4 |
Not A Super Robot
I would stick with same pads for front and rear.
What is the spec of Cool Willy?
![]() 02 M3 Titanium Silver Mods AST 4100, Hyperco 600F/750R, H&R Sways, Evolve-R Stage 1, Dinan Exhaust, 18x9.5 Volk RE30 Gunmetal, Yokohama AD08, Vorshlag Camber Plates, Ferodo DS2500, StopTech SS, ZCP Rotors, Turner 12.5mm Spacers, Rogue RTAB Shim, HD RSM, Turner Endlinks, Turner Stud Kit, Kics 40, GSP Pedals, CF Trunk, CF Rear Diffuser, CF Front Splitter, CF Dash Overlay, CF SMG Dome, Euro Tray, AMT Stealth Camera Mount, Matte Black Front/Side Grille, Blackout Decals All-Around, Black Vinyl Roof Overlay, Mycarr Angel Eyes, Yellow Fogs, Escort 9500ix |
#5 |
![]() Location: Fort Lauderdale
I ran racing pads in front. The rears they cut for me were wrong (Cobalt Friction) so we had to run my stock Brembo Rear pads. I could not imagine the car stopping any better. It was insane stopping power.
They are for sale with unused rears BTW to fit Brembo GT for 18 inch wheels. I had no problems waht so ever. I watched a night event with some m3's. Most of their rear rotors would glow red like the fronts. Other cars mostly did not run with rear rotors that looked as aggressive (did not glow red).
I wasn't speeding...I was QUALIFYING! HPF Stage 3, Electric exhaust cut out, Auto Power muffler , BREMBO GT BBK, Endless race pads, TC Kline DUAL coil overs,TMS front and rear adjustable anti sway bars,Power Flex FCABS, AKG RTABs and subframe bushings,OS Gikken diff, HPF weld in Subframe kit, CF trim almost everywhere,Vorsteiner CF diffuser, Strassentech type CF lip, Aurora Angel Eyes, DRL,HID Fogs 6k, Headlights HID 6k, Apex wheels,315x17"rear,265x18" fr, Passport Escort 9500CI .. custom mount of controls in ash tray, , Quatro CF shock tower brace,Pioneer Avic Z3, BSW stg 1, BSW sub |
#6 |
![]() Location: the OC!
You will be fine. I run PFC01 with my Stoptech caliper in the front, bone stock brake in the rear and have not experienced any braking issues on the track. The only thing you might notice is your rear pad will wear faster.
2004 Silver Gray - 6 speed suspension: TCKline D/A Coilovers, 550F/600R; TCKline Camber Plates; RSM performance: El Diablo Exhaust; Borla midpipe ; OEM18 X 4; Powerflex RTAB, 4.10 diff aesthetic: painted reflector; SPP 55W fog; Hardwired V1; 35% metalic tint; oem ipod adaptor; DPEO; CSL trunk; CSL diffuser |
#7 | ||
likes it raspy
#8 |
![]() Location: In my mind
You're 100% fine, have fun.
#9 |
![]() Location: Washington, DC
You're asking for even more brake fade this way. The fronts will be doing all the work, which will cause the rears to fade badly (and evaporate if you get fast enough). Eventually the fronts will fade too.
Having ridden this sort of combo into a gravel trap at 115+, I can't recommend it.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 2002 BMW M3 Alpinweiß/Black - JBL MS-62C, IDQ-12v3, JBL MS-8 1999 323i KP/GTS2 Alpinweiß - Hood-in-the-windshield mod 1990 325is Brilliantrot/Tan - GC/Bilstein, Sway 1989 325is Alpinweiß/Black - S50B30, GC/Koni, Sways, BBS RX, Hybrid C61-2, Sundown SA-12, JBL MS-8 1989 M3 Alpinweiß/Black - S50B32. 321hp. ![]() Hers: 1996 Porsche 911 Turbo Black/Black Hers: 1988 325iX Coupe Diamondschwartz/Black 5spd - Korman lengthened front driveshaft, Cam, Bilstein, H&R Sport, snow chains.
#10 | |
Bugs explode at 160MPH
![]() Location: missouri
How long have you been doing that? Have you had any rotor cracking problems by doing this? How stable is your car under hard braking? What's the greatest brake point at your local track? What run group are you?
305RWHP ///M My car idles at 90mph...
| front, pads, rear, stocks, track |
