![]() Location: Connecticut
I've never seen a writeup on this here, so I figured i'd post the necessary information and throw some pics up to aid anyone who might be doing this in the future.
Emblem part numbers are as follows (and they're not cheap, plan on nearly $50 for both pieces): "///M": BMW PN 51142250811 "3": BMW PN 51142250539 Here are the specs for placement: ![]() What you will need: -The specs for placement -A ruler that measures in mm -A level -Some painters tape -A writing implement with a fine tip -T square (not pictured, sorry) Also recommended: -Some rubbing alcohol, clay bar, and microfiber towels...or whatever else you need in order to make sure you have a nice clean paint surface that's free of wax or contaminants. ![]() STEP 1: After cleaning the area completely, mark off A and B. I had the car parked on level ground and used the level to approximate the junction of A and B which is a critical point to measure accurately. I used the level to make sure that line A (height) wasn't crooked. Yes, I know it looks crooked...the dead straight line is under the piece of tape you see in the picture. You could also use the T-square to make sure this line is perpendicular to the lower edge of the trunk, but seeing as the metal is rounded I found using the level easier, and it's definitely close enough if the car is on level ground. After you have the height reference, you'll want to put a horizontal piece of tape that's parallel with the bottom of the edge of the trunk before it starts to round down. Don't use the level for this, as the line isn't completely level. I measured the height out off the edge of the trunk in 3 places and used that to place my horizontal line. This would serve as the horizontal reference for the emblem pieces. ![]() STEP 2: Using the t-square, place a vertical piece so you can square the '3' up real nice. This isn't 100% necessary, but I liked being able to literally butt the emblems up against the tape so the fitment was nice and accurate. Note that the bottom of the '3' is rounded, so it's possible to put that on crooked without a nice tight vertical reference for the side of it. ![]() STEP 3: Mark out C and place the ///M on the car. ![]() ![]() Now, peel off the tape and see how she looks... ![]() ![]() Success. ![]()
-Nick Last edited by fiveightandten; Thu, Jul-26-2012 at 04:07:18 PM. |
Toodle-oo Motherf**kers
I'm still impressed that you can get the car in that garage AND get the doors open!
Nice DIY. Thanks. |
The Frugal and Outspoken One
![]() Location: Orlando (Metro West), FL
Holy crap batman.
Nice work Nick......sheesh. |
#4 | ||
User
![]() Location: CO/IL
![]() Look at that bright red booty
--Brent '97 Arctic coupe 171k '04 Flash Green S60-R GT 77k Quote:
#5 |
![]() Location: Long Island
Wish I saw this a week ago, I just eye balled it but I only replaced the M badge so it was relatively easy to line up.
#6 |
I ///M Faster
![]() Location: San Antonio
Very nice, I want blacked out ///M 3 emblem with colored stripes, no real luck yet though.
Craws out through sunroof then closes it with the key in the trunk lock mech., getting back in would be a problem though .
Bumper Sticker: "Real Racers Go Left AND Right" - So True ![]() Last performance car - e30s52 |
#7 |
Troll Level: 99
![]() Location: Arizona
Look at all that orange peel Nick!!
Jk man, perfect write up! I'll be using this when I replace mine ![]() |
#8 |
![]() Location: San Jose
you know what ive been thinking about this for a while now. i occasionally see some people driving with it too high or too far inside, which obviously looks dumb..this is great success!
#9 |
Vintage Pimp
![]() Location: Oregon
the fact that this even needs to be mentioned...
chaos is hangin around |
#10 |
are you a dog, too?
I know this wasn't the case for Nick since he was using a 318 trunk (I think) ... When I replaced my emblem I just c-taped around the edges of the previous emblem and was able to drop it into the same spot
| emblem, or or or m3, placement, trunk |
