Old Sun, Aug-01-2010, 10:25:34 PM   #11
EricSMG
30 something
Not enough "goods" to be worth it, IMO. Replica 18s weigh 24/25 lbs each (I have a set on the Estoril) and really don't look good compared to OEM wheels. You will not notice any performance difference going from OEM 19s to an 18" rep. At MOST you might notice a tiny bit more oomph in 1st/2nd gear....but even that is questionable. But better handling???? Not a chance in hell. I autoX my OEM 19s and run faster lap times than some guys with square OEM 18s and mega camber.
Now, on the other hand, moving to strong light weight 18s would be worth it. In other words, go big or don't bother.
'04 46M 6MT || '01 330Ci 5MT
Old Sun, Aug-01-2010, 11:05:07 PM   #12
DreiKraft
von Bayern für Bayern
DreiKraft's Avatar
Reputation: 0 DreiKraft is on a distinguished road
Germany
i pretty much agree with the above. hardly any noticeable performance benefits to switching. but the fact that 18" tires are so much cheaper makes it worth by itself. the ability to fit a taller sidewall is what makes it attractive personally, but then again 17"s would then be even better in that regard... g'luck OP
Jump to top DreiKraft is offline   Reply With Quote
Old Mon, Aug-02-2010, 12:03:59 AM   #13
drmudryk
Dr. Dan
Reputation: 0 drmudryk is on a distinguished road
The tires on these rims are Dunlop SP Sport Maxx? I think that is it.
If I get $800 for these am I getting a good deal?
These 19s are harsh even with the Pss10 cranked all the way as soft as it would go. Then again I am coming from a luxury car.
Damn car is so noisy...guess I just have to get used to.
FOR SALE 2005 M3 SMG, PSS10, Borla Cat-Back, Turner Sway Bars, H&R Spacer F/R, Turner Bar links F/R, Turner camber plates, K&N Cold Air, Navigation.
I have my eyes on a 2008 M5. (I have kids)
http://www.m3forum.net/m3forum/showthread.php?t=329255
Jump to top drmudryk is offline   Reply With Quote
Old Mon, Aug-02-2010, 01:29:07 AM   #14
m3816
Shhh..my foot is sleepin on the gas
m3816's Avatar
Reputation: 0 m3816 is on a distinguished road
M67 Double Spoke Crome Shadow (OEM 18)
8 J x 18 ET47 11,2 kg (x 2.2lb/kg = 24.64 lbs)
9 J x 18 ET26 12,2 kg (x 2.2lb/kg = 26.84 lbs)
VMR REP VB3 (CSL)
18"x8.5" +40mm Front
18"x9.5" +22mm Rear
Weight
Wheel: 24.0lbs Front/Rear
Wheel: 24.5lbs Front/Rear
M67 Double Spoke Polished (OEM 19)
8 J x 19 ET47 12,6 kg (x 2.2lb/kg = 27.72 lbs)
9 1/2 J x 19 ET27 13,3 kg ( x 2.2lb/kg = 29.26 lbs
+1 for reps
but if you have the money get on one of these RAC group buys
HKS GTS8550 Stage II *SuperSprint*Aeromotive
Clutch Masters*4.10*Rogue Engineering
KW3*H&R*Ground Control*Euro rotors*SS lines
42 Design*Vorsteiner*Bimmian*Apex*//M-Alcantara
507WHP @ 8400rpm-11.2psi
**Need a Expert BMW tech in the DMV Pm Me**
Jump to top m3816 is offline   Reply With Quote
Old Mon, Aug-02-2010, 02:42:50 AM   #15
wheelman46
wheelman46's Avatar
Reputation: 0 wheelman46 is on a distinguished road
Let me know if you have someone that wants to buy two sets. I'd like to sell mine as well. It's painful at track days to be the only dude with 19"s.
Originally Posted by drmudryk View Post
I am not worried about the look as the car is lowered 1.25 inches with the PSS10 coil overs. How much should I look to sell my OEM 19" rims for? Rears have 20% left and front have 60% left. Mild curb rash on a few, but otherwise look GREAT.
05 CB/Cinnamon, 6spd, bone stock...for now
Jump to top wheelman46 is offline   Reply With Quote
Old Mon, Aug-02-2010, 03:58:13 AM   #16
1baadm3
1baadm3's Avatar
Reputation: 0 1baadm3 is on a distinguished road
more like a down grade in both look and strength to me if you go for the 18 rep. I would either go for a good looking, really light, and strong 18 forged or stick with OEM.
I checked tirerack and don't see much of a different in price for tire between 18 and 19. I mean 20 bucks extra per tire is not really a big deal IMO consider each tire will last you 10000+ miles.
SOLD - 2002 e46 M3 phoenix yellow/kiwi, Ground control 450F/550R, Tubi exaust.
Jump to top 1baadm3 is offline   Reply With Quote
Old Mon, Aug-02-2010, 09:17:02 PM   #17
drmudryk
Dr. Dan
I hear the new bushings in the front and back the previous owner put on would make my ride really harsh.
I hear this loud almost metal sound from the front end when I hit a bump.
Remember PSS10 setup with new bushings from Turner Motorsports....
Old Mon, Aug-02-2010, 10:12:02 PM   #18
jon @ eas
jon @ eas's Avatar
Reputation: 0 jon @ eas has disabled reputation
VMR REP VB3 (CSL)
18"x9.5" +22mm Rear
Weight
+1 for reps
+1
VMR has a great wheel that will be lighter than your normal 19" OE set up, but along with that, 18"s will give you a better ride quality, and more tire options which is the reason some guys on this forum do that.
Feel free to PM me if you want some VMR wheels!
Jon M. | european auto source (eas)
email: jon@europeanautosource.com web: www.europeanautosource.com
tel 866.669.0705 | ca: 714.369.8524 x31 | fax: 714.908.1796
Twitter | Flikr | Facebook | YouTube
Jump to top jon @ eas is offline   Reply With Quote
Old Tue, Aug-03-2010, 06:48:01 PM   #19
EricSMG
30 something
Yep....about the only real difference would be slightly better ride quality over small sharp bumps. However - most guys run the 19s with the 245/275 sizes which are actually shorter than the factory 225/255 sizes, and thus, a bit harsher. I tried the 245/275 setup for a month and didn't like it.
If you look at the 225/255 tires you'll notice that they're rather tall, with virtually the same sidewall as the typical 18" tire sizes. I personally can't tell the difference in ride quality (or performance) between them and I'm a picky SOB when it comes to NVH.
Bottom line: if you want a real performance difference you have to go ultra light weight. A 24lb rep ain't gonna do jack.
Exactamundo on both accounts.
Old Tue, Aug-03-2010, 07:03:06 PM   #20
gazosnic
Reputation: 0 gazosnic is on a distinguished road
yea - i would take OEM 19's or 18" CSL reps.
Jump to top gazosnic is offline   Reply With Quote
19 for 18, oem, replicas, stupid, switching, zcp
Discussing Am I stupid switching OEM 19" for 18" ZCP Replicas? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
