Old Sat, Aug-14-2010, 05:23:16 PM   #11
KBuva06
Reputation: 0 KBuva06 is on a distinguished road
what type of chopper is it
is your tail # 166M3???
Jump to top KBuva06 is offline   Reply With Quote
Old Sat, Aug-14-2010, 09:17:11 PM   #12
Richardsperry
95 SC M3
Richardsperry's Avatar
Originally Posted by Supered Ehm View Post
engine work too (i.e. thicker headgasket, rods, rings)
It's even worse with ZKWs...
Nope stock internals.
Makes no difference what headlight you have. The aftercooler is behind the sc head.
Old Sat, Aug-14-2010, 09:29:46 PM   #13
Supered ///M
Panther fans get on your feet
Supered ///M's Avatar
Reputation: 0 Supered ///M is on a distinguished road
So you're saying you can safely run more than 5-6 psi on stock internals??? That would make me very uneasy. I know two people (one who turboed and one who s/c) and were pushing between 10-15 psi and both ended up blowing their engines (one the headgasket and the other bent a rod).
-Sam
Mods: RMS Vortech V1 Supercharger, M50 manifold swap, B&B tri-flo DTM exhaust, Ron Stygar Custom SS kit, autometer oil temp. and boost gauges, ASC throttle body delete, H&R Springs, Bilstein shocks, Dinan rear strut tower brace, Mason front strut tower brace, UUC Barbarian front/rear sway bars, X-brace front subframe connector, JTD rear shock mounts, Steel braided brake lines, yellow tinted fogs, genuine euro plate, ZKW headlights with 8000k LED angel eyes, racing decal, and other stuff
Jump to top Supered ///M is offline   Reply With Quote
Old Sun, Aug-15-2010, 12:10:53 AM   #14
Richardsperry
95 SC M3
It's pretty safe up to 9 psi (that's what I'm running, 3.33" sc pulley, 38#/hr injectors, 3.5" hfm, Aquamist 1S, and a AA tune.) With a good tune and alcohol/water injection. They blew out a hg because they were boosting more than 9. 10-15 is just stupid.
Old Sun, Aug-15-2010, 01:07:50 AM   #15
Supered ///M
what kind rwhp do you put down with that setup?
-Sam
Old Sun, Aug-15-2010, 02:14:11 AM   #16
Richardsperry
95 SC M3
Just over 300 on a DynoDynamics. Probably about 320 on a Dynojet.
Old Sun, Aug-15-2010, 02:52:47 AM   #17
Mad Dog 20/20
Boosted Member
Mad Dog 20/20's Avatar
Reputation: 0 Mad Dog 20/20 has disabled reputation
With a centri SC, you can easily run 10-12 psi (370-425 whp) on OE HG and internals - IF you are charge-cooled and running a proper tune. 10-12 psi is pretty much standard issue for your basic charge-cooled stage 2 SC kit.
The rods are generally good up to at least 550 wheel.
http://img.photobucket.com/albums/v351/xsverdict/sigMooreDyno-1-1.jpg?t=1264742867
Jump to top Mad Dog 20/20 is offline   Reply With Quote
Old Sun, Aug-15-2010, 03:40:50 AM   #18
Supered ///M
Wow didn't know that...so I could run a stage 2 setup without having to do engine work?
-Sam
Old Sun, Aug-15-2010, 11:58:17 AM   #19
AA sells stage II supercharger kits running 12-13 psi for use with the stock headgasket. The centrifugal supercharger makes very little midrange boost so the cylinder pressure is not so dangerous. With a stage II turbo, all 12-13 psi would be there in the midrange so a thicker HG to reduce compression (or lower CR pistons) is used. As stated above, people have used stock rods in 600 rwhp engines making over 500 lbs rwtq.
Old Sun, Aug-15-2010, 12:03:59 PM   #20
I used a 0.098 HG to reduce CR from 10.5:1 to about 9.8:1. Again, stock pistons, rings and rods are find. I have since changed to a turbo for more power. I changed the HG from the 0.098 to a 0.140 to drop CR to about 8.9:1 for the turbo since full boost will arrive by 4000 rpm instead of only at redline with the centrifugal supercharger.
charger, coming, e36, intercooler, kit, vortech
Discussing E36 VF Kit, Vortech Charger, Intercooler kit coming! in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
