Old Fri, Aug-20-2010, 12:04:41 AM   #1
mlee4984
Slow M3 Driver
mlee4984's Avatar
Reputation: 0 mlee4984 is on a distinguished road
China
Default Removing Rear Bumper
Hi All
I've done a search but no help. I've removed 4 screws but couldn't find the other 2 that's in the trunk. I've removed all the screws that I can possibly remove but there is something still holding it in place. I can wiggle the bumper...
Any help is appreciated. Sorry for being a NooB...
Mike
Sent from my ADR6300 using Tapatalk
Current: 1997 Estoril Blau Metallic M3
Current: 2009 White Ducati 1198
Current: 1997 Black 240sx KOUKI STOCK
Gone but not forgotten: 2005 Interlagos Blau Metallic M3 ZCP
Gone but not forgotten: 2006 Smoky Granite Mica IS250 AWD
Gone but not forgotten: 2005 Red Honda CBR 600RR
Jump to top mlee4984 is offline   Reply With Quote
Old Fri, Aug-20-2010, 03:22:45 AM   #2
m3816
Shhh..my foot is sleepin on the gas
m3816's Avatar
Reputation: 0 m3816 is on a distinguished road
there are a total of 8 bolts in the trunk 4 bolts on each side.
HKS GTS8550 Stage II *SuperSprint*Aeromotive
Clutch Masters*4.10*Rogue Engineering
KW3*H&R*Ground Control*Euro rotors*SS lines
42 Design*Vorsteiner*Bimmian*Apex*//M-Alcantara
507WHP @ 8400rpm-11.2psi
**Need a Expert BMW tech in the DMV Pm Me**
Jump to top m3816 is offline   Reply With Quote
Old Fri, Aug-20-2010, 03:39:19 AM   #3
m3816
m3816's Avatar
if you notice the 4 bolts are in a diamond shape i am not sure which ones you have removed. you will need to take off the center plastic piece where the trunk latches. it requries removing a few plastic pieces and you mind as well remove the battery plastic cover and the other plastic cover to the left. once all of these are removed the 8 screws are very easy to see (they are Perendicular to the tunk lining and toe hook)
Also dont forget to removed the inner bumper cover screws 3 on each side.
once this is done your bumper will come off like a glove.
call me if needed
GL
Old Fri, Aug-20-2010, 04:17:18 AM   #4
mlee4984
Slow M3 Driver
mlee4984's Avatar
China
call me if needed
GL
Thanks for the heads up. I didn't remove that cover where the trunk latches. I will do that tomorrow and I'll see where that will get me.
I owe you!
Mike
***EDIT*** I found the other 2 bolts! Thanks for the help! ***EDIT***
Old Fri, Aug-20-2010, 04:36:15 PM   #5
m3816
m3816's Avatar
Np boss Glad I could help =)
Old Mon, Jun-13-2011, 03:30:41 PM   #6
Cloudsurfer
Reputation: 0 Cloudsurfer is on a distinguished road
Default Re: Removing Rear Bumper
Anyone have any pics of this? Need to pull my bumper for a repaint....
Jump to top Cloudsurfer is offline   Reply With Quote
bumper, rear, removing
Discussing Removing Rear Bumper in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
