#21 |
E46FANATICS
![]() Location: Italy
Besides the words"I THINK". From my assumtion.
In the FT Walton/Crestview area? come on by for a detail. |
#22 |
I read that people that never been to the track, doesn't race the car still get subframe failures. I think a big contribtion to the subframe failure is the road conditions.
'02 Euro Tuned///M3 6spd Carbon Black cover with a layer of dust and Grey Int. Suspension: Koni Adj with Vogtland Springs, UUC FCAB, RE RTABS and GC Street Camber Plates ![]() |
#23 |
Certainly it's not just people who track their cars that are getting subframe mount cracks, everyone is susceptible. The cracks are a result of torsional loads generated by the engine, the torque causes a twisting motion and the subframe mounts receive the brunt of it. I think it's less about road conditions, and more about hard and sudden accelerations, and doing such things repeatedly. This isn't my own opinion, as I actually know jack, but this is what I've read from the Turner Motorsport site.
"The E46 rear driveline and suspension are very similar to that of the E36. An unfortunate side effect of this is that the E46 also shares some of the same problems as the E36. One of these problems is the rear mounting points for the subframe, which can rip out from their spots in the sheet metal. This happens because the rear differential transmits the torsional load from the engine through the subframe, then into the chassis. This constant loading and unloading weakens the sheet metal and causes it to fatigue and separate from the chassis. BMW tried to fix this problem in the E46 by placing a cross member on the front two mounting points of the subframe. This cross member keeps the front mounting points from having problems by placing the bushing and the stud in double-sheer, thus reducing the twisting action on the sheet metal. The unfortunate side effect of this is that the load from the front of the subframe now gets transmitted to the left rear of the subframe. This is where we have seen many failures of the chassis on low mileage street cars and race cars." |
#24 |
Mod Hound!
![]() Location: Texas
Verts have a thicker belt of reinforcing metal along the same area where coupes see subframe cracking. This is for added stiffness for the body to offset the vert not have the hardtop of the coupe. This isnt saying it couldnt happen to a vert, but the odds are that it wont, since 99% of verts can never see the track AND the reinforcement in the body of the vert helps to offset hard street driving by verts...
2003.5 e46 ///M 3 TiAg Cabriolet SMG II... <> CSL Carbon Fiber Intake w/MAF, Brembo Gran Turismo, Euro Headers & Cats, K&N 69, Radenergie Carbon Fiber Strutbar <> EAS Carbon Fiber Kidney Grills, Carbon Fiber Fender Grills, SMG Carbon Fiber Paddles, Vorsteiner 2 Sided CF VCSL Boot <> EAS Slvr Carbon Fiber Interior Trim, Blk Carbon Fiber SMG Dome, Carbon Fiber Console, & Blk/Slvr Steering Wheel Trim <> EAS Carbon Fiber Engine Bay, Vorsteiner Carbon Fiber Valve Cover, RPI Intake Scoops, CarPC w/Nav/MP3/HD Radio/TV <> Eisenmann Race Exhaust, Supersprint X-Pipe with Resonator, Ekarbon 1/2 Carbon Fiber Diffuser, DEPO Smoked Corners <> 19x8.5 19x9.5 VMR V710s in HyperSilver, Painted Corner Reflectors, EAS Carbon Fiber Emblems, Carbon Fiber Hood Vent <> Slvr CF Pedals, OEM 2-Tone Hardtop, Windscreen, & Alarm, 6K Headlights & HID Fogs, Blk Carbon Fiber Headlight Trim |
#25 |
tracking the car don't means subframe damage. If so all m3 at the track are cracking?
These no proof that vet owner drives less hard then coupes. It all depends on the owner. If i have a vert and i know it wont tear the subframe ill drive harder instead of thinking it will tear. |
#26 | |
E46FANATICS
#27 | ||
![]() Location: SE PA
These two are correct:
Current Cars: 2005 IR/IR M3, 2003 TiAg M5, 1995 S50 B32 GT3 RS Green M3 Race Car _____Former Cars: 2004 TiAg/IR M3, 1996 TV/black M3, 1995 AW M3 shell Useful stuff: Objective suspension comparison, DIY suspension install VIDEOS (e36 version), Stick Driving Basics, e46 Climate Control, Better Fuel Economy 101, 10W-60 TWS Everything on the car: Mod List __________ HighRes M Wallpapers (Misc collected pics) <--- save target to desktop Selling: Suspensions, brakes, safety equipment, etc (ask away!) Renting: Valve shim adjustment kit, RTAB tool, Ball joint tool |
#28 | |
#29 |
![]() Location: North Vancouver
Yes. This can explain why the verts are more than 300lbs heavier than the coupes
#30 |
I drive my vert pretty hard.
Thanks to some friends at the track, I'm able to get on without the need for a roll-cage for some events. (not recommended) I also autocross now on a regular basis. My car does not have any sub-frame cracks. I'm dropping the diff this weekend and will take another look. I believe the vert frame is tough enough.
2002 TiAg M3 Cabriolet ![]() Dinan S-M3 Kit {Throttle Bodies/CAI/MAF/Stage 4 software} Dinan Strut tower brace & Front sway bar Auto Solutions SSK UUC Motorwerks "Rasp-X" mid-pipe Urethane RTAB's/FCAB's/RSM's Hawk HPS Brake Pads CDV delete V1 Hardwired THIS CAR IS NOW FOR SALE! |
| damage, subframe, suffer, true, verts |
