Old Sat, Sep-11-2010, 06:19:03 AM   #1
m3j0n
m3j0n's Avatar
Reputation: 0 m3j0n is on a distinguished road
Default need help with a very minor hood adjustment.
the front passenger side corner of my hood is a hair out of height alignment - it sits about a half an inch higher than it should. The issue is only on the passenger side. All of the body gaps and even the driver side are perfect. I was wondering if there is anyway to adjust the hood a little bit to bring the passenger side corner down a little bit. thank you!
-M3J0N
Jump to top m3j0n is offline   Reply With Quote
Old Sun, Sep-12-2010, 05:40:26 AM   #2
m3j0n
m3j0n's Avatar
anyone?
-M3J0N
Old Sun, Sep-12-2010, 05:41:50 AM   #3
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
can you post a pic?
Old Sun, Sep-12-2010, 06:13:13 AM   #4
MPOWERD
Mod Hound!
MPOWERD's Avatar
Reputation: 0 MPOWERD is on a distinguished road
OP has your car even been in an accident?
http://www.m3forum.net/m3forum/image.php?type=sigpic&userid=91859&dateline=123241  4897
2003.5 e46 ///M 3 TiAg Cabriolet SMG II...
<> CSL Carbon Fiber Intake w/MAF, Brembo Gran Turismo, Euro Headers & Cats, K&N 69, Radenergie Carbon Fiber Strutbar
<> EAS Carbon Fiber Kidney Grills, Carbon Fiber Fender Grills, SMG Carbon Fiber Paddles, Vorsteiner 2 Sided CF VCSL Boot
<> EAS Slvr Carbon Fiber Interior Trim, Blk Carbon Fiber SMG Dome, Carbon Fiber Console, & Blk/Slvr Steering Wheel Trim
<> EAS Carbon Fiber Engine Bay, Vorsteiner Carbon Fiber Valve Cover, RPI Intake Scoops, CarPC w/Nav/MP3/HD Radio/TV
<> Eisenmann Race Exhaust, Supersprint X-Pipe with Resonator, Ekarbon 1/2 Carbon Fiber Diffuser, DEPO Smoked Corners
<> 19x8.5 19x9.5 VMR V710s in HyperSilver, Painted Corner Reflectors, EAS Carbon Fiber Emblems, Carbon Fiber Hood Vent
<> Slvr CF Pedals, OEM 2-Tone Hardtop, Windscreen, & Alarm, 6K Headlights & HID Fogs, Blk Carbon Fiber Headlight Trim
Jump to top MPOWERD is offline   Reply With Quote
Old Sun, Sep-12-2010, 06:23:48 AM   #5
m3j0n
m3j0n's Avatar
nope, original paint
-M3J0N
Old Sun, Sep-12-2010, 06:24:18 AM   #6
m3j0n
m3j0n's Avatar
its just a hood adjustment after the installation of a new headlight.
-M3J0N
Old Sun, Sep-12-2010, 06:47:24 AM   #7
MPOWERD
Mod Hound!
MPOWERD's Avatar
The hood should not need adjustment after the installation of a headlight. I just removed my passenger side headlight to replace a bad ignotor and it had no effect at all upon the hood setup.
If the hood is sitting high then the headlight is improperly installed and the hood must be hitting it when closed.
Old Sun, Sep-12-2010, 07:04:31 AM   #8
Jumbosock
Reputation: 0 Jumbosock will become famous soon enough
Are you sure you didn't leave a tool sitting in the engine bay that the hood could be hitting? I've done that before. As stated before the headlight shouldn't have changed the hood alignment so make sure that is installed correctly. If the headlight looks good then there is a bumper that the hood hits. You can just turn it with your hand to adjust the gap.
Jump to top Jumbosock is offline   Reply With Quote
Old Mon, Sep-13-2010, 03:11:39 PM   #9
m3j0n
m3j0n's Avatar
i have adjusted those hood bumpers without any change. THe hood (just to the side of the passenger side kidney grill) is making contact with the trim piece under the passenger side headlamp. THe headlamp is definitely not aligned perfectly and that is the cause of the hood issue. How can I adjust the headlamp itself?
-M3J0N
Old Sun, Sep-11-2011, 05:49:20 AM   #10
regensburg94
regensburg94's Avatar
Reputation: 0 regensburg94 is on a distinguished road
Default Re: need help with a mior hood adjustment.
Did this issue ever get resolved, OP? (am having a similar issue myself - quick adjustment of rubber bumper stop isn't fixing the prob).
Jump to top regensburg94 is offline   Reply With Quote
adjustment, hood, mior
Discussing need help with a mior hood adjustment. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
