Old Sun, Sep-19-2010, 04:51:04 PM   #1
graphite9
graphite9's Avatar
Reputation: 0 graphite9 is on a distinguished road
Default Can I have a bad ring but not burn oil?
So, Hello all im new to this forum. I recently picked up a 98 m3 with 157k, super clean for $4500. Problem is, it has one cylinder with 90psi. All others were 175-180. Thats why I got it so cheap. The prev owner said he was driving it, and it started running rough. He pulled over and it sounded fine at idle. Got back in the car thinking maybe it was too cold. Continued driving, to notice it felt like it was missing. Immediately went back home and parked it. Pulled the plugs, all looked clean. Towed it down to the shop and ran a compression test. Cyl 2 was abnormally low... 90. But the car doesnt smoke at all. No coolant in the oil, or vise versa. Is it possible you could drop that much in compression and not burn oil? I have budgeted for a valve job, but if its a piston im screwed!
THanks for any input.
Jump to top graphite9 is offline   Reply With Quote
Old Sun, Sep-19-2010, 09:13:41 PM   #2
Maginnovision
Got stock love?
Reputation: 0 Maginnovision is on a distinguished road
There are many reasons a cylinder could be low. If you're doing a valve job you'll be able to check every possibility. Valve job should include pressure testing the head and decking it. You'll be able to see if the gasket decided to blow as well, which will have to be replaced anyway. Just because coolant and oil aren't mixing doesn't rule anything out. The mixing of the two is an indication something is wrong, not mixing doesn't mean there isn't a problem. If it is a bottom end problem you should be able to see that as well. I'd say go ahead with the valve job, and you should be able to figure out what's wrong. If nothing else, the shop SHOULD have done a leakdown test after the compression test. If they didn't, or didn't suggest it, don't go back there.
My cars:
1995 BMW M3
1984 Toyota Supra
2007 Honda Civic SI
Jump to top Maginnovision is offline   Reply With Quote
Old Sun, Sep-19-2010, 09:17:26 PM   #3
M3F1RST
M3F1RST's Avatar
Reputation: 0 M3F1RST is on a distinguished road
I was going to indicate the same thing, there could be valve issues or headgasket issues that aren't apparent, it doesn't have to be a bad ring to lose compression. If you do a leakdown test you can usually tell where the air is coming from to determine the issue.
FBP 99 Acura 2.3 CL 5 spd (plenty of Vtak!) Estoril 98 BMW M3 Sedan(Back in DD action )
Penn State University '08...better than your school since 1855
Sigma Lambda Beta International Fraternity Incorporated
UTI Class of '10, BMW "STEPchild"
Acurazine.com Mod Squad
Jump to top M3F1RST is offline   Reply With Quote
Old Sun, Sep-19-2010, 10:03:46 PM   #4
graphite9
graphite9's Avatar
thanks for the input guys. Yeah I'm suprised they didn't do a leakdown test. Im just praying its not bottom end. The car has higher mileage, but I do know it was dealer maintained for its life, and it 100% stock. Is it very common to have a head gasket go, and not have fluids mix? And I was under the assumption that overheating was the cause to blow a gasket. (on a n/a engine). My mechanic is coming over to do a leakdown on it today(I hope). I have done major engine work on hondas, subies, and vr6's, but I'm new to BMW's. I really hope its just a head issue. If the leakdown indicated the bottom end, Im going to look for a good used engine, rather than having it rebuilt. If its a valve, I'm going to do a valvejob/HG, and all assc parts. How long do the chains normally go? My mechanic is super anal and wants to do it all. But in my opinion, if they are in spec, Id like to leave em...Thanks again for your input, Im just praying to the bmw gods its a HG, or burnt valve.
Old Sun, Sep-19-2010, 11:44:42 PM   #5
salty
salty's Avatar
Reputation: 0 salty is on a distinguished road
Squirt oil in the cylinder to isolate wether it is the valves or rings. (if the pressure goes up it is the rings) If it needs some rings, it might need a rebore as well. Bottom end refers to the crank and bearings, which is not related to compression issues. Good luck. I'd be going with a used engine if anything is terminal.
Bob S
EX 98 M3/4/5 Cosmos owner, 2007 Subaru Forester XT daily, 2003 325 IT, 1999 10AE Miata, 1971, 2800 CS (In the Garage getting refreshed) 1966 Corvair 500/140, 1972 BMW 2002 Malaga.
Jump to top salty is offline   Reply With Quote
Old Mon, Sep-20-2010, 12:36:31 AM   #6
graphite9
graphite9's Avatar
well, I just did the oil trick. I dumped an oil bottle cap into the problematic cyl. Think It might have been too much because it jumped to 275...EEK. Im gonna wait till my mechanic brings his leak down tester over. I did notice a tad bit of oily looking substance on the plug when I first pulled it before the tests. But, It could be all the unburned fuel the in the cylinder. Does anyone know where the best source for used motors is? Seems like they run about $3500 with 80-150k. If the head needs a valve job, I can have it machined, and all associated parts+labor for under $1,700. If its the bottom, I'll part out the engine and grab a good donor.
past cars...
84 sfa toyota
2nd gen rx-7
JDM ITR 00 SI
vr6'd mk2 GTI
350whp LGT
Current...
98 silver m3 coupe
68 fj40 sbc, crossover, 35's
Old Mon, Sep-20-2010, 01:33:48 AM   #7
egebhardt
egebhardt's Avatar
Nice. A big jump with oil in the cylinder. That's good news. Maybe a valve issue after all.
I put in a call to a www.bmrparts.com (Sacramento, CA) a month ago because my engine burns a quart of oil every 1,000 miles, which is not as bad as a lot of them I know of.
They wanted $2,500 for a used engine with 210psi, guaranteed. $100 shipped to anywhere in the Bay Area of CA. I did not purchase it and scrapped the whole idea.
97 Byzanz on Magma 4dr - Sold 7.7.17 Jerad in CO
Old Mon, Sep-20-2010, 01:52:29 AM   #8
salty
salty's Avatar
A big jump in the pressure with oil implies rings not valves.
Bob S
Old Mon, Sep-20-2010, 02:37:26 AM   #9
egebhardt
egebhardt's Avatar
Oh. Duh. My mistake.
Old Mon, Sep-20-2010, 02:47:17 AM   #10
An oil cap is certainly not that much. 275psi? That would lead me to believe you have a faulty tester.
Redo that test with your mechanic around. Make sure the engine is warmed up when you do this test.
bad, burn, oil, ring
Discussing Can I have a bad ring but not burn oil? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
