Old Thu, Sep-23-2010, 05:35:38 AM   #1
hickersb
Reputation: 0 hickersb is on a distinguished road
Default Trunk Open Sensor
Intermittantly, seems like typically morning when it is cooler, if I open the trunk then close it, I get the indicator light on the cluster indicating that the trunk is ajar. I really have to slam it shut to get it to go off.
I assume there is some microswitch whose position needs adjusting, or perhaps the little rubber bumpers on the trunk need adjusting/replaced?
Any hints on how to begin troubleshooting?
Jump to top hickersb is offline   Reply With Quote
Old Thu, Sep-23-2010, 04:43:23 PM   #2
ianmason
ianmason's Avatar
Reputation: 0 ianmason is on a distinguished road
I get the same thing, mine happens frequently, so if you find an answer, post it.
Jump to top ianmason is offline   Reply With Quote
Old Thu, Sep-23-2010, 04:53:13 PM   #3
mpower22
CPV O-Ring Guy
mpower22's Avatar
I would think the sensor is in the latch and is actually triggered to it not grounding out on the chassis when it closes. If its not your latch mechanism, likely a loose cable leading to it that it having problems. Move some wires around with it closed. If your seats fold down that is. .
///M3 - Dream Car: Acquired
15-Year Member
2003 M3Laguna Seca Blue/6MT/Black Leather Cloth Interior/Full [CSL] Exhaust/evolve-R
Old Thu, Sep-23-2010, 05:52:15 PM   #4
cscat87
cscat87's Avatar
Reputation: 0 cscat87 is on a distinguished road
Mine does that too. The light will be on after closing it, then I just get back out and re-open/close the trunk and it goes off. Doesn't happen to often though.
1997 M3 Coupe
2003 M3 Convertible
2003 M3 Coupe
2014 320i Jalopnik Edition
2011 Ram 3500
Jump to top cscat87 is offline   Reply With Quote
Old Tue, Sep-25-2012, 03:49:49 AM   #5
Drnknmnky13
Reputation: 0 Drnknmnky13 is on a distinguished road
Default Re: Trunk Open Sensor
I've been doing some searching on this (as my car just started doing this) and the general consensus is the wire loom on the passenger side of the trunk. Apparently the wires break from lots of flexing caused by opening and closing the trunk.
Going to check mine in the morning.
Also... I'm an idiot for not noticing the 2010 on the date code. Oh well...bump for a common issue.
Jump to top Drnknmnky13 is offline   Reply With Quote
open, sensor, trunk
Discussing Trunk Open Sensor in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
