Old Wed, Sep-29-2010, 02:46:24 PM   #1
PerkM3
PerkM3's Avatar
Reputation: 0 PerkM3 is on a distinguished road
Default about VAC Floor Mounts and Harness Brackets
I've had my Sparco's installed now for about a month using the VAC floor mounts but my Kirk roll bar is on it's way and I've ordered the VAC lap belt mounting bracket and the anti-sub bracket that mount to the VAC floor mounts. I'm using the Schroth Profi II Harness and my question is does anyone have any advise or pictures on where I should mount the above brackets?
I know that the lap belts should be inline with the holes through the seats and go straight across my lap but where do I mount the anti-sub bracket (how far back)?
Any advice or info is appreciated.
Cosmetic/Aero: BW splitter, BW canards, Brooks pro wing, V-CSL bootlid, Tekerbon CSL diffuser, V-GTR hood, CF moonroof delete, CF kidney grills, CF gills, and CF roundels
Suspension/Brakes: MOTON CS 850/450 (rear coilover), GC F/R race sways, RE FCAB/RTAB (track), TMS rear camber arms, GC race camber plates, TMS solid subframe bushings, ZCP F/R rotors, brass caliper guides, BW SS lines, PFC RH665, PFC-01, BW brake ducts/baking plates.
Performance: BW/EPIC Tune, aFe stg2 intake, SS V2 stepped headers, BW race exhaust, TMS pullies, JB Racing clutch/LW flywheel, TMS solid motor mounts, TMS solid trans mounts, BW solid diff mounts, RE shifter linkage, and BW race shifter.
Misc: TMS subframe reinforcement kit, Sparco PRO ADV seat, Sparco side mounts, VAC floor mounts, Kirk Comp. Roll Bar, Schroth Profi III 6-Point harnesses, Jafster shift knob, BimmerWorld 75mm wheel studs, and Enkei NT03+M.
Jump to top PerkM3 is offline   Reply With Quote
Old Sun, Oct-03-2010, 05:03:30 AM   #2
Polar
Polar's Avatar
Reputation: 0 Polar is on a distinguished road
VAC suggests you mount the anti-sub bracket as far back as possible (ideally within two or three rows from rearmost position on their long FMAs).
FWIW, I've mounted seat belt bracket on bottom of VAC long FMA (last row - which allows for a nylon nut on the bottom of M8 x 40 mm that runs through side mount, FMA, and seatbelt bracket).
Current: E36 M3 ('98), E46 M3 ('05 ZCP), E90 M3 ('11 ZCP), 2007 Porsche GT3 RS
Jump to top Polar is offline   Reply With Quote
brackets, floor, harness, mounts, vac
Discussing about VAC Floor Mounts and Harness Brackets in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
