///M3
![]() Location: Lake Mary
I purchased the interior LED kit from Khoalty for my e46 02 m3. I installed all of the LED's and of course they would not work. I contact them and did some research and they said to try it with one halogen bulb installed, and sure enough, the LED's were working. They said that if that does the trick, I need to install a resistor to mimic the draw that a halogen would have, because the LED's do not draw enough power.
I purchased a pack of 100 ohm 1/4 watt resistors, and 100ohm 1/2 watt resistors. I followed the instructions for where to install them and how from a few threads I found at e46fanatics. Still nothing has worked. I tried installing the resistors in line as well with the bulb by using splice connectors and wiring the resistor/soldering it on to wire leads. Still nothing worked. So here is my question. What size resistor should I be using? Where is the proper place to install this? Does anyone have a definitive solution to this problem. Thank you all for your help. I know this has been asked a couple of times at the very least, but everyone has different kits and I have not come up with a solid solution just yet. Thanks
![]() 02 ///M3 Tiag/Blk 6MT Aesthetic: CSL Front Bumper, CF Kidney Grills, CF Fender Gills, CF Splitters, CF CSL Diffuser, CF Emblems, Smoked Side Markers, Smoked Turn Signals, Tinted Windows, Smoked LED Tails, Carbon Wrapped Dash Trim & Doors, 60 L.E.D. Angel Eyes, Khoalty Interior L.E.D. Kit Audio: Pioneer Touch Screen Navigation, Custom Enclosed JL Sound System with 12" sub Performance: ST Coil Overs, Short Shifter, Headers, K&N Intake, Shark Injector Tuner, Pro-Flex RTAB's |
![]() Location: Long Island
thats weird, i bought a kit off ebay and they worked fine.
04 IR/IR 6spd sold =( |
i noticed that the led bulbs plugged needs to be in certain directions, have you tried flipping the other way around?
'02 Euro Tuned///M3 6spd Carbon Black cover with a layer of dust and Grey Int. Suspension: Koni Adj with Vogtland Springs, UUC FCAB, RE RTABS and GC Street Camber Plates ![]() |
#4 |
///M3
I have all bulbs facing the right direction. I know this because I still have one halogen in which allows them to work. The trick is figuring out what size resistor would mimic the stock halogen bulb in such a way that the car lets the lights work.
So what size resistor do I need in order to remove this one last halogen and install the final LED.
#5 |
![]() Location: Jersey
Can't remember size, but the issue with E46 cars is the passenger side footwell. Install a resistor in that area and you should be fine. The resistor i once had was purchased from F1Autohaus. NO issues after that.
#6 |
///M3
So your saying that installing the resistor on the passenger side foot well will work as apposed to the driver side. I did the driver side and the over head lamp, but I did not try the passenger side.
Will give this a shot today. I honestly didnt think that would make any difference.
#7 |
///M3
I should add, that the passenger foot well is the one with the halogen still installed.
#8 |
Sienar Fleet Systems Inc.
![]() Location: South Florida
I had the same problem with my DIY LED setup. I installed my LEDs and all no workie! The problem is the too low resistance of the LEDs which necessitates a resistor. So, I ordered a resistor from Khoalty.
After wiring it in, (in line in the drivers side footwell) ALL the LED lights worked. However, the resistor got so hot in just a few seconds it burned my finger to where it left a mark for a few days. My point is that it concerned me to the point that it may cause some kind of weird electrical meltdown/fire so I took it out and just left 1 incandescent bulb in the drivers footwell. My guess is that I think a couple of resistors are needed, but right now one bulb not being LED doesn't bug me too much. FYI, here are some resistor load wiring instructions from another site. http://www.superbrightleds.com/pdfs/...istor_info.pdf HTH, ![]()
Current Mods: Brembo GranTurismo BBK, Active Autowerke Exhaust,AR20,RPi Scoops,BMC Filter,H&R's,Konis, Maya RT5,Toyo T1R, Matte Black Grills,Monochrome "M3" badges, CF Valve Cover,Roundels & trim, Depo Smoked Corners,Stealthauto bulbs,New OEM H/L lenses, Lamin-X ,5k HID fogs, Khoalty AE,Keyhole Delete,"Mafioso" tint,OEM BMW Hanger,Slush Mats,Car Cover,Wet Okole "///M" Seatcovers,Stebel Nautilus horn, ClutchStop,-CDV,UUC clutch line, 330d shifter, ZHP knob, "///M" stitch boots,Kill Switch Coming Soon: Alcantara wheel,LED tails,more CF bits,BBS LM's, Recaro's,4.10's and a Ducati 848 Evo! Dream List: S85 conversion! 2002 M3 6MT, Jet Black/Black Nappa, Premium,HK,Rear Spoiler Delete Beater:1984 E30 318i 5MT Polaris/Cardinal,TSW Hockenheim, Hartge rear spoiler, Zender side skirts, Pfeba front.30 mpg &cold A/C! Psalms 56:11 "In God I have put my trust; I will not be afraid. What can man do to me?" |
#9 |
![]() Location: DFW
The LED's should already have at least a 500 ohm resistor in series with the LED's. LED's can't take a 12V source directly or they will burn up.
#10 |
| interior, led, thread |
