///M NUT
![]() Location: Syracuse, NY Danbury, CT
I've tried looking everywhere but I can't find anything about this wheel size. Probably because it wont fit but who knows.
Stock everything. Wheels are FRONT 18x8 +35 REAR 18x9 +35 Will these fit without spacers? Thanks! |
#2 | |
Sponsor
![]() Location: Oakville
What kinda look are you after? |
///M NUT
I just don't want it to look stupid, haha.
#4 |
Sponsor
If you own the wheels already the fronts will be fine with a et35, you could probably add a 5mm spacer if you want it to look really aggressive since you are at stock ride height.
The rears will look stupid though...get a 15mm or even 16mm spacer...you won't see the rim for the fender gaps, especially stock height. If you need a spacer we have them in stock, 16mm Click here |
#5 |
///M NUT
hmmmm, ok 1 more quick question, its about tires though. I found a good set of used winter tires they're 245/45R/18 for all four. They should fit the OEM 18's fine correct?
#6 | |
![]() Location: Southern Cali
Rears are 18x9 +26 |
#7 |
einpresstiefe
![]() Location: northern california
You can put a 25mm spacer and it'd be less aggressive than a 10" wide wheel with 20et.
| fitment, offset, wheel |
