Old Wed, Oct-20-2010, 08:35:57 PM   #1
fugh understeer
Reputation: 0 fugh understeer is on a distinguished road
Default going in for a subframe reinforcement
Well as a preventative measure im going in to tkx performance in long island for a reinforcement in a couple weeks as i gather the other bits i might want to get done as the car is up. First off i want to mention that their group buy price from a while back is still up. Car is a 02 with 61,xxx miles.
Now unto the questions
1) To anyone who had their subframe done at tkx, how was your experience?
2) What rear subframe mounts should i go with, Should i go with powerflex rtabs, should i do rear shock mounts and/or reinforcements, what diff bushings and should i replace the diff seals? What about the diff bolts how many are there and where can i get them?
3) i am also doing my guibo but transmission bushings are said to be fine but should i go aftermarket?
4)Finally about how much should it cost seperately in labor for rtabs, and the rest above?
Lurked for a while so im not a complete noob, thanks for any replies!
Jump to top fugh understeer is offline   Reply With Quote
Old Wed, Oct-27-2010, 06:03:34 AM   #2
fugh understeer
bump 77 views and no posts?
Old Wed, Oct-27-2010, 01:08:54 PM   #3
Ramp1
Ramp1's Avatar
Reputation: 0 Ramp1 is on a distinguished road
I am going to be doing the same in the spring (car is going away for the winter soon) and I will be sticking with stock bushings all around. I already have an OEM guibo and tranny mounts that I'm putting in.
Aftermarket bushings put more stress on everything else...since you are having the re-enforcement kit done you could go with stiffer ones for tighter handling but as you probably know you sacrifice ride comfort when you do that, so it's really a matter of personal preference weather you go with OEM or aftermarket.
I only do a few track days a year and the rest of the time I'm driving around on bumpy roads and streetcar tracks so that's why I am sticking with OEM.
Jump to top Ramp1 is offline   Reply With Quote
Old Thu, Oct-28-2010, 06:59:03 AM   #4
RahilKhan
e40sickm3 -- on e46fanatics.
Reputation: 0 RahilKhan is on a distinguished road
goodluck
Jump to top RahilKhan is offline   Reply With Quote
Old Thu, Oct-28-2010, 01:17:00 PM   #5
nofronts
nofronts's Avatar
Reputation: 0 nofronts is on a distinguished road
I had TKX do my sub frame reinforcement and every thing was great. I used the Turner kit because they stock it there so i didn't have to buy one separately and wait for shipping. They did the work for less then half my indy shop wanted and even fixed a few other things while the frame was out.
04 SMG Imola Red | Black Cloth / Leather Interior | Koni Yellow's | Rouge RSM | Power Flex RTAB | JVT Headers | Custom Performance CRT 400 Section 1 | Turner Sub Frame Reinforcement | Smoke Corners | Kidney's & Gills Matte Black | Angel Eyes | CSL Diffuser | CSL Boot Lid
Jump to top nofronts is offline   Reply With Quote
Old Thu, Oct-28-2010, 01:20:11 PM   #6
BHenderson
Reputation: 0 BHenderson is on a distinguished road
If you don't mind me asking, how much will it run you to get the subframe reinforced?
Jump to top BHenderson is offline   Reply With Quote
Old Thu, Oct-28-2010, 01:24:05 PM   #7
nofronts
nofronts's Avatar
When i went in the beginning of the summer it was only 700 + the Turner sub frame kit.
Old Thu, Oct-28-2010, 01:30:49 PM   #8
BHenderson
That's pretty good. I need to get another quote on having it done on my car, but I think it was like ~$1000 just for the labor last time I checked.
Old Thu, Oct-28-2010, 01:32:27 PM   #9
nofronts
nofronts's Avatar
This guy at TKX apparently has done hundreds of them and even had a group buy like a year ago so he has it down and can offer it for less.
Old Thu, Oct-28-2010, 01:58:17 PM   #10
BHenderson
Now if only someone in Austin would do a similar group buy...
reinforcement, subframe
Discussing going in for a subframe reinforcement in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
