Old Thu, Oct-21-2010, 06:14:51 PM   #11
kuksul08
I would probably get it. Right now I have an airbag light on which alone could cost up to $1000, then you have brakes, possible vanos failure, etc.
S54 Valve Adjustment DIY, Excel, Print out:
http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
Old Thu, Oct-21-2010, 07:25:11 PM   #12
gimmethemuumuu
'08 M3 Sedan & '07 328i Wagon
Reputation: 0 gimmethemuumuu is on a distinguished road
Originally Posted by Tak555 View Post
yah, that would probably help.
my car is a 2004, that i bought used in 2007, with 18k miles on it. it currently has about 47k miles on it. when i bought the car, i also purchased an aftermarket warranty for about $2,100 that would cover me for an additional 70k miles and 5 years (exclusionary type of warranty).
when i initially bought the car, it actually had a little bit of factory warranty left, and during the first 3 months i had a couple electrical problems (battery went bad, alternator died, interior lights on the fritz) plus some little things like premature wear on interior trim, etc. so those things were taken care of using the bmw warranty.
since that time, i've had zero problems. no smg or vanos problems, and when i had my subframe looked at by an indy shop, they said everything looked good.
OK. So, you've done about 30K miles with no issues, much less major ones. And, as you've said, you're cleared on the typical biggies: SMG, VANOS, and subframe. For my purposes, she'll be a 6-speed, so SMG wouldn't be a factor. VANOS--only time will tell. On the subframe front, I'm having a PPI done by an independent shop before finalizing the purchase.
I'm curious if anyone else has had any more complex and costly repairs . . .
Jump to top gimmethemuumuu is offline   Reply With Quote
Old Thu, Oct-21-2010, 07:28:08 PM   #13
gimmethemuumuu
Yeah, I'm still not sure. Certainly, an airbag issue could be a little pricey, especially if done at the dealer. As it is, I would use a local shop for that.
On the brakes front, the maintenance for that wouldn't be covered, of course, thing being an extended warranty, rather than maintenance deal. Unless there's some sort of brakes issue I'm not aware of on these cars?
Old Thu, Oct-21-2010, 07:34:56 PM   #14
Reputation: 0 Obioban has a spectacular aura about
You can pick up a used engine these days for $3000.... and that's about as bad as it can get. Everything that fails before 100,000 is maintenance stuff (bushings, etc), and won't be covered either way. I'd pass.
Current Cars: 2005 IR/IR M3, 2003 TiAg M5, 1995 S50 B32 GT3 RS Green M3 Race Car _____Former Cars: 2004 TiAg/IR M3, 1996 TV/black M3, 1995 AW M3 shell
Useful stuff: Objective suspension comparison, DIY suspension install VIDEOS (e36 version), Stick Driving Basics, e46 Climate Control, Better Fuel Economy 101, 10W-60 TWS
Everything on the car: Mod List __________ HighRes M Wallpapers (Misc collected pics) <--- save target to desktop
Selling: Suspensions, brakes, safety equipment, etc (ask away!)
Renting: Valve shim adjustment kit, RTAB tool, Ball joint tool
Old Thu, Oct-21-2010, 07:54:46 PM   #15
deadlysyns
deadlysyns's Avatar
Reputation: 0 deadlysyns is on a distinguished road
$1000 to reset an airbag light? Tell them to lay down the crack pipe.
Jump to top deadlysyns is offline   Reply With Quote
Old Thu, Oct-21-2010, 08:00:03 PM   #16
Warranty won't reset an airbag light, anyway... unless it's due to an airbag failure. I've never seen an airbag light for failure-- it's always due to use or someone unplugging it without disconnecting the battery first.
Likewise, brakes would also not be covered by the warranty.
... Which leaves you with the small chance of VANOS failure, which, worst case scenario grenades your engine... and you buy one for $3000.
Old Thu, Oct-21-2010, 08:35:21 PM   #17
Tak555
Tak555's Avatar
Reputation: 0 Tak555 is on a distinguished road
ya, so far so good for me... but 47k miles over six years is pretty low i think. not that it matters that much, but just something to consider.
my wife's old e46 323ci had an airbag light come on, and when a shop checked it out, everything was good (ie, it would operate normally), but some sensor went bad. and to change the sensor out would cost bookoo. maybe not $1k, but still not worth it.
Previous Cars:
2004 BMW /// M3 Coupe
Jet Black, Black Nappa, SMGII, HK Sound, E92 18" Wheels w/PS2s, TCK SA 500/500, DINAN exhaust, PF RTAB, DICE
E9X 18" Wheel Specs:
18x8.5 ET29
18x9.5 ET23
Previous Cars:
2004 Audi S4 Avant (owned for a week... returned to Carmax after independent inspection came back negative)
2003 Mitsubishi Evolution8
2003 Subaru Impreza WRX
1999 Subaru Impreza 2.5RS
1992 Toyota Pickup
Jump to top Tak555 is offline   Reply With Quote
Old Thu, Oct-21-2010, 09:40:00 PM   #18
gimmethemuumuu
Certainly, if that the worst-case scenario--picking up a used engine for $3000 because of extreme VANOS failure --that's not too bad. Of course, there's still the cost to get that engine put in. (I ain't that smart All things considered, though, that does sound like a good argument for the save-the-money-for-a-rainy-day approach.
Old Thu, Oct-21-2010, 09:41:38 PM   #19
gimmethemuumuu
Yeah, it seems that it would have to be a series of cumulative failures totalling more than $3700 to make it worthwhile to get the warranty.
Old Thu, Oct-21-2010, 09:42:59 PM   #20
gimmethemuumuu
Yeah, 47K and six years is pretty low. Nonetheless, I appreciate the input
60k, 6speed, extended, warranty
Discussing '05 M3, 6-speed, 60K mi: Extended Warranty? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
