| M3 Track: Racing and DE Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! |
![]() Location: CA
I am looking at some new tires for my M3, particularly 245/40-18 and 275/35-18. I just bought some lightweight wheels, so naturally I'm looking at tire weights.
I've basically come down to the Hankook V12 Evo K110 and the Dunlop Star Spec. For the 245's: Hankook = 25lbs Dunlop = 27lbs For the 275's: Hankook = 27lbs Dunlop = 32lbs So the Dunlops have 14lbs more unsprung, rotating weight, and yet I've heard a lot of good things about these tires. How much difference does it really make? So, also considering the huge price difference ($600 Hankook, $960 Dunlop), is there any reason to get the Dunlops? They seem to be quite similar, scoring 1st and 2nd in a C&D test.
![]() ~*Mods*~: High Flow Carbon Fiber Strut Pipe Trim, Custom Aero DME Shift Linkage, Forged Titanium Race-Euro-Spec Illuminated Diff Sleeves, Catless Dog CSL Retrofit, Mod Bug Delete & More S54 Valve Adjustment DIY, Excel, Print out: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip |
![]() Location: San Diego/Copenhagen
Go with the Hankook's. They are lighter and cheaper, so seems like a no brainer to me.................
1994 E34 M5 Touring 3.8L Daytona Violet 2007 E60 M5 5.0L Alpine White 2010 E70 X5 3.0L TT Alpine White 2003 E46 M3 3.2L Silver Grey/Orange EVOSPORT - SPARCO - VORSTEINER - H&R - ROTORA - ENKEI - CONTINENTAL
![]() Location: CA
That's what I'm thinking. I just know a lot of people are pleased with the Dunlops. I'm curious how much difference it really makes, or maybe people focus on wheel weights but overlook tire weights which actually impact performance more due to the weight being further from the center.
#4 | |
Chin 3/3 @ VIR Full
![]() Location: Chapel Hill, NC
A big reason the "extreme performance" tires are heavier is the extra sidewall and tread reinforcement that is designed to deal with greater lateral loads, etc. In addition, their rubber compound is designed for max dry grip along with the tread design. Yes the Star Specs (and AD08, RE-11, NT05, etc) are heavier and don't last as long, but for track driving they're worth it. In fact, a fellow M3F member was at VIR this weekend and he said his Hankooks (same model you're considering) were just terrible on the track ![]()
2004 SilverGrey 6MT 2012 VW JSW TDI 6MT Past - '91 Saab 900TC / '98 M3 / '06 WRX / '98 ITR / '88 Saab 9000T |
#5 |
Flyguy
![]() Location: O'Fallon,IL
FWIW the 275 Star Spec weighs 30.8 lbs. As JPH says,if it's intended as a dual purpose tire,go with the Dunlops or one of the other extreme performance tires.
Mike K. 2005 M3 |
#6 | |
![]() Location: Calgary
#7 | |||
![]() Location: CA
When you say they will vastly outperform the hankooks, what do you mean? It looks like they do quite well in comparison: ![]() ![]() ![]() ![]() ![]() ![]() Quote:
![]() ~*Mods*~: High Flow Carbon Fiber Strut Pipe Trim, Custom Aero DME Shift Linkage, Forged Titanium Race-Euro-Spec Illuminated Diff Sleeves, Catless Dog CSL Retrofit, Mod Bug Delete & More S54 Valve Adjustment DIY, Excel, Print out: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip Last edited by kuksul08; Fri, Oct-22-2010 at 03:29:18 AM. |
#8 |
Chin 3/3 @ VIR Full
^^The primary difference in performance will be how fast their grip drops off as things heat up. The difference in the two tires after a ~60sec autocross was only 0.5 seconds, but they'll probably feel a lot different 15 minutes into a DE session.
All of this said, if you're going to use these tires on the street with a few autox/DEs per year in the future, there's nothing wrong with buying the Hankooks; they'll be better for you 98% of the time (the Star Specs are very stiff and get, ahem, *loud* when they're worn down) and if you start doing autox and track events more in the future you'll eventually see that you need to upgrade rubber (and get a couple more rear OEM wheels)
#9 |
![]() Location: Seattle
Don't buy the dunlops for street, they aren't a very good street tire.
They were designed for stock autoX class, they have a very soft compound that comes up to temp quite quickly, which is very important for competitive autox'ing. The hankooks are a much better street/all around tire, they are very quiet have great grip and are fantastic in the wet. Also their treadwear rating is much higher so they should last longer than the dunlops.
#10 |
![]() Location: CA
Thanks for the input
| importance, tire, weight |
