Old Sat, Oct-23-2010, 03:11:05 AM   #1
Sliquepimp
Reputation: 0 Sliquepimp is on a distinguished road
Default Need help with vert back seat removal...
Hello all. I've already pulled the bottom rear portion and also the speaker grill panels. I read on bimmerforums that the back seat pulls out and up..... No. I've read that all seats since e30 have 2 bolts at the bottom and then pull up.... No. I've pulled the trunk carpet and there seems to be 2 bolts(one on each side) coming through the sheet metal. So, can I get a definitive answer on how to remove the upper portion of an e36 vert m3 seat? Thanks in advance.
Jump to top Sliquepimp is offline   Reply With Quote
Old Sat, Oct-23-2010, 03:15:00 AM   #2
PurduinaM3
Reputation: 0 PurduinaM3 is on a distinguished road
Do they fold down? The fold down seats are tricky, but there's a piece in the center on the floor that unlatches the top of the back seats to be able to pull them out...
Jump to top PurduinaM3 is offline   Reply With Quote
Old Sat, Oct-23-2010, 03:45:40 AM   #3
Sliquepimp
nope, don't appear to fold. The lower portion velcros out, then a flap that would be used for skis is there except I have the subwoofer in the middle. It seems that either there is a bolt hiding under the side panels or maybe a bolster issue.... plus I cannot get the headrests out. I've pulled up to no avail. One post says they have to be out, the other doesn't...... arrrrghhhh....
Old Sat, Oct-23-2010, 05:56:54 AM   #4
firedancer414
are you a dog, too?
firedancer414's Avatar
Reputation: 0 firedancer414 is on a distinguished road
Pull out and up, really. No bolts. You have to wiggle the headrests forward/backward to get them out. The headrests DO need to come out first.
Brian - [Current] 2009 997.2 C2 Aqua/Stone Cabrio - [Sold] 1999 E36 M3 Estoril/Dove Cabrio
Jump to top firedancer414 is offline   Reply With Quote
Old Mon, Oct-25-2010, 05:24:58 PM   #5
Synenergy52
Reputation: 0 Synenergy52 is on a distinguished road
The headrests come out. Stand on the seats if you have to for leverage. Directions: Pull very hard.
As far as the rear seats folding down, vert seats do not. I think BSW (bavarian sound werks) has a video on youtube on the e36 m3 vert rear seat removal. search it.
Jump to top Synenergy52 is offline   Reply With Quote
Old Mon, Oct-25-2010, 08:13:45 PM   #6
Sliquepimp
Howdy. Thanks for the confirmation. I do have to say though, you have understated the procedure tremendously. I almost sprained my wrist pulling and yanking on the headrests.... I bent the bottom support bar of the seat pulling up and out..... So, my advice for anyone attempting this job would be: Push and wiggle the rear headrests until you can get them raised 2-3 inches. That is hard enough on it's own. Then get a 15+ inch pry bar or the bar from a floor jack (like I used). Wrap the end of it in shop towels or some kind of padding, put the bar through the gap under the headrest and put the end of the bar on the roll-over protection dome, then use the bar as a fulcrum lever to raise and ultimately pop out the headrests. Once they are out, up and out on the seat portion, just isn't enough info. It should be said specifically, grasp top of seat where headrests were just removed from and pull towards yourself sharply. It will pop out, just like the front of the bottom portion. Then and only then, can you lift up and it will slide out of the clips. Thank god my interior was junky or I would have wrecked it getting it out...
Old Mon, Oct-25-2010, 08:15:45 PM   #7
firedancer414
are you a dog, too?
Can't believe you had to apply that much force. Sorry man.
Old Mon, Oct-25-2010, 08:36:39 PM   #8
Sliquepimp
Hey, not your fault. I really appreciate you confirming that they do indeed pop out. There is a lot of misinformation out there. But yes, the headrests do lock the back portion in place, so without them gone, it is no go on getting that back out. Also, I would recommend the top being open so you can stand up and put enough force into it.
back, removal, seat, vert
Discussing Need help with vert back seat removal... in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
