ARM Powered
![]() Location: Bay Area
Any SMG owner out there ever tried dyno with Dynapack chassis dyno? I tried it today but the car won't shift above 2nd gear. We already put the car in dyno mode via autologic but still didn't work. We ended up just dyno'd in 2nd gear. Anyone ever experienced this or know how to solve this issue?
***Update on page 3***
1968 Porsche 912 2011 Porsche GT3 RS 2006 Interlago blue OEM CSL Dinan S3-R M3 (Gone )1988 E30 Henna M3 S50B32 (Gone )2006 Ducati Burnt Yellow SportClassic Sport1000 Last edited by edwin814; Mon, Feb-21-2011 at 11:01:21 PM. |
Red on Red
![]() Location: M3 Capital of the World - Irvine, CA
DSC off maybe? Good luck. Let us know if you figured it out.
ARM Powered
We turned off the DSC as well. At first I thought it was due to Dinan software, but another stock E46 SMG had the same issue.
1968 Porsche 912 2011 Porsche GT3 RS 2006 Interlago blue OEM CSL Dinan S3-R M3 (Gone )1988 E30 Henna M3 S50B32 (Gone )2006 Ducati Burnt Yellow SportClassic Sport1000 |
#4 |
when u said u put it in dyno mode, did u disengage the DSC before starting the car?
#5 |
ARM Powered
we started the car, activate dyno mode via autologic then turned out DSC. How do you turn off DSC before starting the car?
#6 |
#7 |
![]() Location: Hobart Oz
Did you turn off DSC just with a quick push or by holding it? You need to hold it for 8-10 secs (thereabouts) to turn it off for the dyno. If you hold it for too long it goes into 'stuck switch' mode tho.
Cheers JM |
#8 | |
ARM Powered
I wonder if turning on the sport mode would help...
http://www.m3forum.net/m3forum/showp...12&postcount=4 Yup, we did the press and hold DSC for few seconds to turn it off completely.
#9 |
I doubt sport mode would make a difference, all it does is change the throttle mapping, but (clutching at straws...) what about the SMG program and, in fact were you changing gears with a few revs on? On the road mine won't go out of second unless I'm above about 2500, particularly when it's cold.
Cheers JM |
#10 |
![]() Location: SF/Bay Area
Yeah! I'm pretty sure those are for pre 03. We tried a similar process,that were somewhat similar but it still didn't work.
06' M Lovin every second of it! 2006 Silver Grey M3 Coupe |
| dynapack, dynopack, issue, smg |
