Old Mon, Nov-01-2010, 02:19:46 AM   #1
lor443
lor443's Avatar
Reputation: 0 lor443 is on a distinguished road
Default Inspection necessary?
Hi, I bought my 2006 m3 a couple months ago I'm at 37,000 miles and it says I need inspection in a couple 100 miles, when I called the dealer he checked my vin and said inspection 1 was done and inspection 2 won't be necessary for a while. So why does my car say I need inspection? Thanks
Jump to top lor443 is offline   Reply With Quote
Old Mon, Nov-01-2010, 02:22:44 AM   #2
TitaniumSilber
TitaniumSilber's Avatar
Reputation: 0 TitaniumSilber is on a distinguished road
if the service records show that its been done, then u most likely dont need it.
They prob forgot to re-set the counter.
U can go back to the dealer, or actually to another dealer, give them your vin and they should be able to give you a print out.
Jump to top TitaniumSilber is offline   Reply With Quote
Old Fri, Jan-28-2011, 03:27:18 PM   #3
lor443
lor443's Avatar
Default Re: Inspection necessary?
It says just inspection one has bin done not inspection II?
2006 M3 SMG
Old Fri, Jan-28-2011, 03:31:04 PM   #4
daumas
Reputation: 0 daumas is on a distinguished road
Please search.
Just google on how to reset it yourself or let the dealer do it.
Jump to top daumas is offline   Reply With Quote
Old Fri, Jan-28-2011, 03:57:58 PM   #5
deadlysyns
deadlysyns's Avatar
Reputation: 0 deadlysyns is on a distinguished road
your cluster just says Inspection, it does not say I or II. Since you are at 37K, then you are probably due for Inspection II.
Call and ask about service history on your car and see the exact mileage when Inspection I was done. This is the only way to know for certain. Most people have their Inspection II done between 40k-60k mark, it all depends on how hard the car was driven.
Jump to top deadlysyns is online now   Reply With Quote
Old Fri, Jan-28-2011, 04:16:01 PM   #6
maveric23
maveric23's Avatar
Reputation: 0 maveric23 is on a distinguished road
Lightbulb Re: Inspection necessary?
Technically, the computer bases the counter on the amount of gas that is consumed. But I agree, it sounds like you need an Inspection 2. The car probably had a high number of city mileage.
Do you wish that Double VANOS never existed? Vote!
2004 Silver Gray/Black M3 Convertible
Jump to top maveric23 is offline   Reply With Quote
Old Fri, Jan-28-2011, 04:39:03 PM   #7
deadlysyns
deadlysyns's Avatar
the harder you drive, the more gas you use.
Old Fri, Jan-28-2011, 07:36:11 PM   #8
lor443
lor443's Avatar
Originally Posted by daumas View Post
Please search.
I know how to reset the cluster. I'm trying to figure out if I should do the inspection or not.
2006 M3 SMG
Old Fri, Jan-28-2011, 07:37:09 PM   #9
lor443
lor443's Avatar
So you think I should do the inspection? The dealer said I should do it at around 55-60k?
2006 M3 SMG
Old Fri, Jan-28-2011, 08:03:56 PM   #10
deadlysyns
deadlysyns's Avatar
you need to know when inspection I was done to be certain.
you can go ahead and do Isp II and just keep track of your service history from that point on so you do lose track.
inspection
Discussing Inspection necessary? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
