Old Sat, Nov-13-2010, 04:21:14 AM   #1
jeffer1no
Reputation: 0 jeffer1no is on a distinguished road
Default Clutch Slipping? Normal SMG stuff?
Okay so I am just a little concerned. I was on my way home from work and playing around a little bit and noticed something odd. I was in s4, traction control off and sport pushed. I didn't even have it wide open but getting on it. When shifting it (not at redline) it seemed like from 2-3 and/or 3-4 it felt a little shudder and then engagement. Not sure if it is because of being in s4 or what. Any advice?
Jump to top jeffer1no is offline   Reply With Quote
Old Sat, Nov-13-2010, 05:15:12 AM   #2
spyfish007
Mmmmm.... Good
spyfish007's Avatar
Reputation: 0 spyfish007 is on a distinguished road
Reset your SMG by using the paddles. Have you done this before? Everyone once in awhile the system gets a little confused.
2004 BMW M3 Coupe SMG
Moton ClubSport Coilovers with Hypercoil springs (500F/275R) | UUC RCABs
ZCP Brakes F/R with stainless steel brake lines
VMR V715 19" Wheels with Hankook V12 tires (245/275)
Jump to top spyfish007 is offline   Reply With Quote
Old Sun, Nov-14-2010, 01:55:42 PM   #3
jeffer1no
How do I do this re-setting that you are mentioning? Sounds like would be a good idea since I got the car only like 3k miles ago and no telling how the last owner drove but based on the music left on the phatnoise harddrive probably very slow
Old Sun, Nov-14-2010, 02:44:15 PM   #4
Haitham
Haitham's Avatar
Reputation: 0 Haitham is on a distinguished road
Palestine
Drive the car at +30 MPH (+50 KPH) and put it in N and then pull both paddles for ten seconds. You'll feel the car adapting to your shift points.
Jump to top Haitham is offline   Reply With Quote
Old Sun, Nov-14-2010, 02:51:54 PM   #5
Hank Cohn
Hank Cohn's Avatar
Reputation: 0 Hank Cohn is on a distinguished road
I reset mine a few days ago and while the difference isn’t night and day; it is noticeably smoother on the up shifts. Definitely worthwhile to do this every so often.
2003 ///M3 Carbon Black
1990 ///M3 Brilliant Red
Jump to top Hank Cohn is offline   Reply With Quote
Old Sun, Nov-14-2010, 07:30:27 PM   #6
2k3GunMetalM3
2k3GunMetalM3's Avatar
Reputation: 0 2k3GunMetalM3 is on a distinguished road
Default May need a new clutch
Mine was shuddering as well and then it progressively got worse. I would try resetting the smg first and if that doesn't work then have a indy shop check it out real quick. It also could be TPS sensor, etc but you won't really know until you get it diagnosed...
"I would have probably stolen cars - it would have given me the same adrenaline rush as racing." -Valentino Rossi
2003 M3. AFE CAIS
Jump to top 2k3GunMetalM3 is offline   Reply With Quote
clutch, normal, slipping, smg, stuff
Discussing Clutch Slipping? Normal SMG stuff? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
