Old Thu, Nov-18-2010, 12:26:03 PM   #1
Angry German
Angry German's Avatar
Reputation: 0 Angry German is on a distinguished road
Default ZCP Upgrade Install Prices?
Anyone out there have their competition brake upgrade package installed by the dealer? There are 3 BMW delaers near me and here are the prices they quoted:
$801.59 (how they came up with such an exact number I do not know)
$610.00
$600-$700 - these guys told me it should take 6-7hrs
Does this sound right? I need to find some indy shops and ask them as well.
Jump to top Angry German is offline   Reply With Quote
Old Thu, Nov-18-2010, 12:32:00 PM   #2
Shimmy23
Addicted
Shimmy23's Avatar
Reputation: 0 Shimmy23 is on a distinguished road
thats spendy... is there a reason you can't do it yourself? Do you belong to BMWCCA? I'm sure there's some locals that can help you out.
brandon
Jump to top Shimmy23 is offline   Reply With Quote
Old Thu, Nov-18-2010, 12:54:33 PM   #3
tropicatango
tropicatango's Avatar
Reputation: 0 tropicatango is on a distinguished road
dont pay for that, the prices they told you are a joke, do it by yourself, it's easy or have somebody do this for you, should take less than 1h30 if you take your time or do it with somebody and learn but dont pay 500$ and over to have this done,
Jump to top tropicatango is offline   Reply With Quote
Old Thu, Nov-18-2010, 12:57:29 PM   #4
m3816
Shhh..my foot is sleepin on the gas
m3816's Avatar
Reputation: 0 m3816 is on a distinguished road
I agree and disagree.
Never do your own brakes if you have not partnered with someone who has done a brake job in the past to do it with you. But dont pay does stupid prices either. If you are in Nova/MD I may be able to send you to some one who will do it for half that price.
HKS GTS8550 Stage II *SuperSprint*Aeromotive
Clutch Masters*4.10*Rogue Engineering
KW3*H&R*Ground Control*Euro rotors*SS lines
42 Design*Vorsteiner*Bimmian*Apex*//M-Alcantara
507WHP @ 8400rpm-11.2psi
**Need a Expert BMW tech in the DMV Pm Me**
Jump to top m3816 is offline   Reply With Quote
Old Thu, Nov-18-2010, 02:12:58 PM   #5
M42boy
Reputation: 0 M42boy is on a distinguished road
It's relatively easy to do it yourself. A few things you need to be aware of...
First off, you will be draining your entire brake system of fluid, since the calipers are coming off. I'd reccomned now as a good time to upgrade lines to StopTech or some other good DOT-Approved stainless steel braided line.
When loostening the lines to the body, use a flare nut end wrench, and dowse the nut on the end of the hard line with PB Blaster or some other penetrant a good hour or so before you try to turn it. This will ensure it will come loose easily and won't strip the nut. (May want to soak it a few times before turning it) They are typically brass or some soft metal, and can strip easily if you are not careful. The flare end nut wrench allows you to get contact with all surfaces of the nut and apply more torque than a standard wrench and won't allow it to 'slip'.
Once it's all back together, you have to evacuuate the system of air. You will need to push a lot of fluid through the vehicle to get the entire brake system rid of air. I'd reccomend buying or borrowing a pressure bleeder, like the Motive Bleeder. Good time to upgrade to a high-performance brake fluid. The BMW fluid is fine, but a lot of people use SuperBlue or Motul.
That's probably the hardest part of the job. The actual replacing of brake hardware (calipers and rotors) is EASY!
Well, I say that, and there's always something that can bite you in the arse. I found that the rotor locating screws on my front two rotors are stripped out and need to be dealt with. That can take some time. Anyone reccomend the best way to get those things out??
Jump to top M42boy is offline   Reply With Quote
Old Thu, Nov-18-2010, 02:17:34 PM   #6
maveric23
maveric23's Avatar
Reputation: 0 maveric23 is on a distinguished road
Lightbulb
Originally Posted by Angry German View Post
Anyone out there have their competition brake upgrade package installed by the dealer?...
It's not necessary to have a dealer do this procedure. Call Indy BMW shops for estimates instead.
Do you wish that Double VANOS never existed? Vote!
2004 Silver Gray/Black M3 Convertible
Jump to top maveric23 is offline   Reply With Quote
Old Thu, Nov-18-2010, 02:33:23 PM   #7
vndkshn
Goin' crazy... wanna come?
Reputation: 0 vndkshn is on a distinguished road
Not true.. IF you do it right. When I swapped my calipers, I probably dropped 4 drops from the hard line out of each side.
The trick, take a broom handle and wedge it between your seat and the brake pedal. You only need to press the pedal down an inch or two. This will move the piston in the master cylinder past the port that allows fluid to leave the reservoir and enter the master cylinder, making its way to the lines.. which are disconnected! :-)
Do that, you will lose very little fluid (although a good flush is a good idea) and more importantly, not introduce alot of air into the system.
2005 Interlagos Blue M3 - Cinammon Interior - ZCP - 6MT - Premium - HK Sound
Performance Mods: D/A Race Software, D/A VAC Lightweight UnderDrive Pulleys, Streamline Panel, Ceramic Coated Stainless headers, Race-cats, B&B Tri-Flow, Motons, Vorshlag plates, GC Adj. Rear Camber Arms, GC Race Hybrid FCAB, Powerflex RTABs, H-Sport Sways, GC adjustable endlinks, GSP Clutch Pedal, 40% Autosolutions SSK, Rogue Trans Mounts, PFC WC/GAC front brake kit, PFC-01s for the track.
Click Here for nightmare ECS story. - LOL, it was deleted, guess it shows the sponsors can get away with anything here.
Jump to top vndkshn is offline   Reply With Quote
Old Thu, Nov-18-2010, 02:47:31 PM   #8
jph28
Chin 3/3 @ VIR Full
Reputation: 0 jph28 is on a distinguished road
That's a pretty ridiculous assertion given that he's asking about replacing the pads / rotors / calipers / carriers
I'm not surprised that a shop would quote ~6 hours many places charge one hour per axle just to replace brake pads and one hour to flush the brake fluid. That said, pads and rotors alone can reasonably be done in less than two hours on stands in the garage.
Also remember that if you let too much brake fluid drain out while replacing the calipers that you'll need to take the car to a shop with a GT1 tool to properly bleed the ABS portion of the system.
2004 SilverGrey 6MT
2012 VW JSW TDI 6MT
Past - '91 Saab 900TC / '98 M3 / '06 WRX / '98 ITR / '88 Saab 9000T
Jump to top jph28 is online now   Reply With Quote
Old Thu, Nov-18-2010, 03:25:57 PM   #9
vndkshn
Yeah, an hour and a half if you have done it before and are using airtools.
Good point on the drain.. which is why the broom handle trick is such a huge help.
Old Thu, Nov-18-2010, 07:23:06 PM   #10
02CBM3
02CBM3
02CBM3's Avatar
Reputation: 0 02CBM3 is on a distinguished road
dont ever.. EVER let the dealer touch ur car.. im having mine installed for $250
Jump to top 02CBM3 is offline   Reply With Quote
install, prices, upgrade, zcp
Discussing ZCP Upgrade Install Prices? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
