![]() Location: Charlotte - Plaza Midwood
What's the best offset for these wheel for e46 m3 application? Thanks!
Hum
02CBM3
![]() Location: Lynnwood, WA
the offset i have is..Front: ET 20 Rear: ET33
#3 | |
![]() Location: Dallas
Your desired tire sizes + the look you want determines wheel width. Wheel width generally doesn't influence the needed offset unless you wanna look like a dumdum and be stretched and poked ![]() You need to post what kind of look your going for and also select your tire sizes first.
"I heel-toe therefore I am..." "Yes I'm stretched and poked. No, college is for losers" 2003 Tiag/Red 3 pedals - Under Construction 2007 S2000 Grand Prix White on Black/Red Interior - KW V3 - Direzza Star Specs 225/45ZR17, 255/40ZR17 - T1R Forged Halfshaft Spacers - CR interior bits |
#4 |
I've got 90% front and rear tires. They're stock tire sizes. Doesn't mean I have to stay with these tires if they'll look retarded. If they work, great. If not, I'll just buy new tires.
Cb, what size tires are you running?
#5 |
I think that's backwards, right?
2004 SilberGrau M3 Coupe 6MT
#6 |
![]() Location: Concord, NC
Take a look at this page. The majority of they wheels that they make are for the E90's. You should be able to find a lot more information here:
http://www.e90post.com/forums/showthread.php?t=297809 This wheel is made to fit many different applications and the specific offset for the E46 M3 is 35 Front and 22 Rear. I proper tire size is 245/35 on the front and 275/30 on the rears. |
| alufelgen, question, sf71 |
