Old Thu, Dec-02-2010, 05:53:19 PM   #11
cstern
Reputation: 0 cstern is on a distinguished road
Originally Posted by hencini View Post
If your brake fluid is reacting to the weather, it's time to flush that bish...
No matter what, it sounds like it's definitely time to flush the system and maybe replace the master and/or slave. After I replaced my failed master cylinder, I was *amazed* by how much higher the clutch engaged.
Do you have side-to-side slop in your clutch pedal? If so, you probably need new bushings (Delrin) and might as well do the plastic pedal while you're in there. I belive that my master cylinder failed prematurely becuase of the side to side slop and it was exhibiting similar travel to yours before it went...
In the meantime, you should be totally fine running without a clutch stop. Anyway, I did it for a while and had no issues. So you could probably remove the stop as a quick fix, but it sounds like you have an issue with the system that you need to address immediately...
I think I would have to agree. My pedal has side to side movements and squeaks occassionally.
I would have to assume something went wrong with the clutch system. It shifted like butter after a tranny fluid change and the z3 shifter a few weeks ago.
Sounds like a slave and flush as well as pedal and bushings. I hope that the master is ok.
Jump to top cstern is offline   Reply With Quote
Old Thu, Dec-02-2010, 05:57:41 PM   #12
hencini
Carlos is My Co-Pilot
hencini's Avatar
Master isn't hard to do. You don't even have to get the car on stands. If your pedal is sloppy, I'd look at the master first.
Jump to top hencini is online now   Reply With Quote
Old Thu, Dec-02-2010, 06:02:59 PM   #13
cstern
Clutch master is cheaper than I expected. Maybe just do it all.
Master $62
Slave ~$60
Clutch pedal $25
Bushings~$20
Fluid~$20
SS Line if I want ~$29 (but it is from uuc)
I can get it all done for under $200
Old Thu, Dec-02-2010, 06:18:10 PM   #14
hencini
hencini's Avatar
Master $62
Slave ~$60
Clutch pedal $25
Bushings~$20
Fluid~$20
I'm not a big fan of throwing money at a problem and/or replacing parts needlessly, but it's tough to argue with those numbers. I'm guessing at least the master needs to be done, and depending on mileage/condition/frequency of flushes in the past, your slave might not be far behind...
Hell, if you're already in there doing bushings and pedal, you might as well do the master, especially if it's questionable... The way I see it, the most you'd be out is $60 for the slave done prematurely, but I guess it's cheap insurance...
I say dooooooo eeeeeeet...
Old Thu, Dec-02-2010, 06:42:45 PM   #15
cstern
I'm not much of a fan either, but since I have to change the fluid and Im relatively new at the process, I would rather handle it all now. It just makes sense.
I'll probably flush again when I do the brakes.
And at 221k miles, just about every part could be replaced because it is probably worn. Except the parts I already replaced.
Old Thu, Dec-02-2010, 08:37:30 PM   #16
hencini
hencini's Avatar
How long have you had the car? At 221K, if you think they're original, it's time...
Old Thu, Dec-02-2010, 09:07:18 PM   #17
cstern
I have had it from 167k on. Actually was our 3 year year anniversary on monday. I have had time or budget constraints over the 3 years. Either no time, but extra money or lots of free time, but no extra money.
I just started having both, but with christmas coming up....
clutch, issue, rogue, stop
Discussing Rogue clutch stop and clutch issue in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
