#11 |
///MFEST DARK KNIGHT
![]() Location: Los Angeles
DSC is:
![]() Don't turn off DSC if you're not ready. Set verocity to level 5. If you still feel it's "lagging", then you must have switched gears below 4000 RPM. Try switching it at 4000 RPM, it should solve your question. ![]() Keep us posted! |
#12 |
![]() Location: Philadelphia
Do you have the the most recent software for the SMG? If so try the reset other wise the gear position sensor may be on its way out, you'll know this if it starts to skip gears. Like 2-5.
04 SMG Imola Red | Black Cloth / Leather Interior | Koni Yellow's | Rouge RSM | Power Flex RTAB | JVT Headers | Custom Performance CRT 400 Section 1 | Turner Sub Frame Reinforcement | Smoke Corners | Kidney's & Gills Matte Black | Angel Eyes | CSL Diffuser | CSL Boot Lid |
#13 |
![]() Location: McHenry
Chances are you're experiencing normal operation of the SMG system. On my car, when shifting from 1st to 2nd at low RPMs (below 4000) I have to count "one thousand one one thousand two" before it has completed the gear change. At higher RPMs it completes the shift much faster.
If you think about it, and if you have driven a manual transmission car before, when you're simply tooling around town in traffic, you don't normally quick shift from 1st to 2nd anyway, so the SMG doesn't realy behave much differently then you would driving a manual trans yourself.
Jetmech Saving pilots lives, one flight at a time 04 M3 SMG Oxford Green Previous BMW's: 97 M3/4 (M5) 98 328iC (Auto) 94 325i (M5)
#14 | |
![]() Location: Alpharetta,GA
Mine does the same. great info and answer. Sounds like normal operation to me also. It does take a bit of getting used to when you first drive the SMG. |
#15 |
30 something
![]() Location: San Diego
Most likely it's just not knowing how to drive the SMG car. If, for example, you're at level 3, and you're shifting @ 2.5k rpm AND you're lifting off the throttle.... it will shift very slow.
Suggestion: use level 4 (never anything less), shift a bit higher (like 3.5k rpm) and don't completely lift off the gas (just lift a little) and you'll be MUCH happier. ![]() Either that or get a stick shift.... Ha!
'04 46M 6MT || '01 330Ci 5MT |
#16 |
![]() Location: North Port
i leave mine on D5 all the time is that bad??? i shift around 3k 3200 no higher... lmk..
#17 |
| 1st, 2nd, big, lag, shifting, smg |
