Old Mon, Dec-06-2010, 03:05:32 AM   #1
silvr04M3
Reputation: 0 silvr04M3 is on a distinguished road
Default Alternator problem AGAIN!
hey guys so about 4-5 months ago my battery light was comin on at over 4500 5k rpm so i bought a rebuilt alternator from a forum member and worked fine and today the batt light started comin on agin only under 1500 rpm tho once i get goin it goes away... MY QUESTION IS DO YOU GUYS THINK IM GOOD TO DRIVE THE CAR THIS WEEK MAYBE NEXT WEEK ALSO UNTIL I GET THE NEW ALTERNATOR?? I will more than likely be orderin from somewhere online. thanks in advance guys..
Jump to top silvr04M3 is offline   Reply With Quote
Old Mon, Dec-06-2010, 05:18:59 AM   #2
silvr04M3
bump..
Old Mon, Dec-06-2010, 05:28:11 AM   #3
zq
Reputation: 0 zq is on a distinguished road
does it ever die on you?
Jump to top zq is offline   Reply With Quote
Old Mon, Dec-06-2010, 04:01:08 PM   #4
deilenberger
deilenberger's Avatar
Do you have towing insurance? Motor club?
If not - I'd park it until you replace the alternator. We have no way of knowing if even when the light is going out if the alternator is adequately recharging your battery. Nor do you.
Might be OK, might not. Balance the cost/benefit ratio yourself based on your situation.
  • 2001 M-Coupe - TiSilver/Black - Das Boot..
  • 2006 Cayenne/S - Iceland Silver Metallic/Stone-steel Gray - Truckster.
  • 2007 R1200R - Roadster, black mit/white pinstripes - the REAL BMW..
Old Mon, Dec-06-2010, 06:24:19 PM   #5
mredwin25
mredwin25's Avatar
Reputation: 0 mredwin25 is on a distinguished road
If the light is on that means the alt is either dead or on it's way there, either way it's not working at 100% and will only get worst.
E90 Jerez M3
335i Vert
Jump to top mredwin25 is offline   Reply With Quote
Old Mon, Dec-06-2010, 06:50:32 PM   #6
GRIDLOCK
Reputation: 0 GRIDLOCK is on a distinguished road
PM'ed ya.
Jump to top GRIDLOCK is offline   Reply With Quote
Old Mon, Dec-06-2010, 07:12:14 PM   #7
NikolaiD
NikolaiD's Avatar
Bulgaria
I would monitor the system voltage, and if it's low, don't drive the car. You can do a lot of damage to the electronic components of the car by not giving them enough power to run efficiently.
I posted up how to watch it recently in here:
http://www.m3forum.net/m3forum/showthread.php?t=343020
MSS54 Error Codes
(work in progress)
Old Mon, Dec-06-2010, 07:24:28 PM   #8
mredwin25
mredwin25's Avatar
why risk it
E90 Jerez M3
335i Vert
Old Mon, Dec-06-2010, 08:20:45 PM   #9
GRKM3
GRKM3's Avatar
Reputation: 0 GRKM3 is on a distinguished road
Check your battery cables too.
2003 Steel Gray Metallic M3 - Imola Red Interior - SMGII - Premium - HK Sound - NAV - BT -Sirius
Mods :VFE Stage 2 SC, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe,TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R Brakes, OEM CSL Roof, VCSL D/S Carbon Trunk, diffuser and bumper, Armrest Delete, carbon mirror shells, OEM LED tail lights, BBS CH, Alcantara steering wheel, Armrest delete, Valentine V1, Laser Interceptor...
5D Mark III | 24-70 2.8 IIL | 17-40 4L | 50 1.8II | 580EXII
Jump to top GRKM3 is online now   Reply With Quote
Old Tue, Dec-07-2010, 04:59:49 AM   #10
silvr04M3
yeah i jus parked it right away and decided now to even risk it I have triple a anyways in case anything were to happen (free towin) but decided to jus avoid problems so i might jus get the alternator checked out and see if ima need a new one.. was tellin my boss about it and he let me borrow his F350 while i get my car goin again so its something different for a week or 2.. thanks for the feedback guys..
alternator, problem
Discussing Alternator problem AGAIN! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
