![]() Location: Northern Suburbs/Chicago
Yes I did a search. Couldn't find a definitive answer.
Noticed on my car that a few LEDs are barely lit on the drivers side in the outer ring. Is my only option full tail light replacement?
MY02 ///M3 - Steel Grey/Black I am on my third E46 M3....yes, I am crazy Gone: 03 Tiag/Black 04 Silver Grey/Black |
เป็นคนจีน
![]() Location: Seattle
Unless you're good at taking apart the taillight and removing and resoldering the individual LEDs, yes, your only option is to replace the unit.
2008 ISF, Smokey Granite Mica on Black ![]()
Crap...figured as much. Off to getbmwparts I go
#4 |
Damn, that sucks. Going to check mine now.
2003 Steel Gray Metallic M3 - Imola Red Interior - SMGII - Premium - HK Sound - NAV - BT -Sirius Mods :VFE Stage 2 SC, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe,TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R Brakes, OEM CSL Roof, VCSL D/S Carbon Trunk, diffuser and bumper, Armrest Delete, carbon mirror shells, OEM LED tail lights, BBS CH, Alcantara steering wheel, Armrest delete, Valentine V1, Laser Interceptor... 5D Mark III | 24-70 2.8 IIL | 17-40 4L | 50 1.8II | 580EXII |
#5 |
I would have never known except my wife was following me home tonight.
#6 |
Did you do the DIY mod that turns on the outer ring when you brake?
#7 |
![]() Location: CA
It shouldn't be that hard to replace the LEDs. Try to disassemble the unit and find out what type they are, then go to digikey.
![]() ~*Mods*~: High Flow Carbon Fiber Strut Pipe Trim, Custom Aero DME Shift Linkage, Forged Titanium Race-Euro-Spec Illuminated Diff Sleeves, Catless Dog CSL Retrofit, Mod Bug Delete & More S54 Valve Adjustment DIY, Excel, Print out: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip |
#8 |
No. I checked the wiring and previous owner did not either. That pic is with the lights on and the outer ring lights up with the lights on. With the lights off, they don't light up when you are on the brake.
#9 |
I seem to recall from the sales brochure something about adaptive brake lights. IIRC, the adaptive lights meant that there were more lights/brighter lights under harder braking? Possibly what is happening here?
#10 | |
With the headlights on, the outer ring will be lit With the headlights off, the outer ring is only lit when the adaptive brakes come in to play. The other taillight had the full outer ring lit with the headlights on. This one has three dim LEDs.
| led, light, oem, question, tail |
