#11 |
My other ride is a beater : D
![]() Location: Vancouver, BC
Correct. These only light up when the "adaptive braking" is in use. So normally they only look dim. I retrofitted the LED lights and did the mod to have them on all the time. It is very easy and I still have a last pair of wires left to do the mod if you want them.
2002 M3 Vert TiAG/Blk - with every option Mods: Clear Bra | Tints | Hardwired Passport SRX | Painted Bumper Reflectors | Keyhole Cover | 6000k Predator Chromiums | 6000k Philips Ultinons | 6000k HID Fogs | Philips Silvervision Corners | OEM LED Tails | LED Plate Lights | Trunk Lip Spoiler | Eisenmann Race | CSL Diffuser | CD/DVD Swap | Small Antenna | Blackout Grille and Gills | Smoked Corners Purchased Mods Awaiting Installation: ZCP Brake Upgrade | CF Interior Trim | Royal F1 Paddles Other Vehicles: 2008 X5 4.8i BSM/Blk - most options and a few mods| 2009 Chevy Silverado LTZ - fully loaded |
#12 |
![]() Location: Northern Suburbs/Chicago
Can someone with OEM LED tails (04-06) confirm that with headlights on (and not modified to have the ring on) that the outer ring is lit?
MY02 ///M3 - Steel Grey/Black I am on my third E46 M3....yes, I am crazy Gone: 03 Tiag/Black 04 Silver Grey/Black |
#13 | |
Supersprint North America
![]() Location: Austin, TX
When the parking lights/headlights are OFF, the outer ring DOES NOT illuminate under normal braking. Under heavy/panic braking the outer ring DOES illuminate as an attempt to warn drivers behind you that you are braking harder than normal. When the parking lights/headlights are ON, the outer ring DOES illuminate dimly AT ALL TIMES. Under heavy/panic braking the outer ring illuminates BRIGHTER (at the same level as the rest of the brake lights) as described above. From your picture it appears the lower 3 LEDs of the outer ring are not illuminated, this is not normal operation under any circumstance.
~~~~~~~~~~~~~~~~~~~~~~~~~~ ![]() BMP Design PROMINI Supersprint NA Jared Bronson BMP Design Inc. Supersprint NA 3208 Park Center Drive Tyler, TX 75701 Toll Free: (800) 648-7278 ext. 221 Direct: (903) 262-9961 Fax: (903) 581-8206 j.bronson@supersprintna.com |
#14 | |
![]() Thanks to all
#15 |
If you replace your taillight let me know if you plan on discarding your old one i wouldnt mind taking it apart and working on it when im bored at work.
| led, light, oem, question, tail |
