Old Tue, Dec-14-2010, 12:50:47 PM   #1
kZo
kZo's Avatar
Reputation: 0 kZo is on a distinguished road
Default Appropriate Tool List
I am looking for a list if tools that everyone uses to work on their vehicles. I'm going to start my collection.
I understand that this is a vague question, but if you would list the tool an what it's importance is it would be greatly appreciated.
Example: Craftsman Torque Wrench (some model) - what you use it for.
I think this thread could be used by many to see what the best tools are for a particular job.
Thanks!
Appropriate Tool List - Basic Set (updated 12/15/10)
Low Profile Jack
Jack Stands
Protected Lug Bolt Sleeve
3/4 hex set
Torque Wrench (15lbs - 150lbs)
Ratchet Wrenches
Socket Wrench & Attachments
Torx Socket Set (pref ones with holes)
Tamper Proof Hex Keys
Torque Bits
Sockets (8mm - 22mm)
Breaker Bar
Instant Bolt Remover
Appropriate Tool List - Specialty Jobs
Tool - Job
Budweiser - Self Explanatory
32mm / Dead Blow - Fan Clutch Removal
Protected Lug Bolt Sleeve - Lug Bolt Removal
17mm 1/2" drive socket - Wheel Studs / Oil Drain Plug / Tranny Drain Plug
22mm Hex Socket - Rear Differential drain/flll plug
7mm hex - Replacing Pads
Big C-Clap - compress brake caliper pistons
RTAB Tool - ??
Interior Trim Removal Tool - Removal of interior trim
O2 Sensor crows foot attachment
Peake Code Reader - Error Code Reader
Feeler Gauge - valve adjustments
Micrometer - valve adjustments
Valve Shims - valve adjustments
32mm Open End Wrench - valve adjustments
- kZo
2002 - BMW M3
2006 - Ford F150 King Ranch
Jump to top kZo is offline   Reply With Quote
Old Tue, Dec-14-2010, 01:11:12 PM   #2
jjojo2004
GR68JOJO
jjojo2004's Avatar
Reputation: 0 jjojo2004 is on a distinguished road
You definitely need the tools to remove the fan clutch. This also allows you to replace the water pump too. A must have--I need these tools myself!! It's like a long pulley holder and a big 35MM? open end wrench. Haha
Jump to top jjojo2004 is offline   Reply With Quote
Old Tue, Dec-14-2010, 01:15:08 PM   #3
akashyap
akashyap's Avatar
Reputation: 0 akashyap is on a distinguished road
32mm / dead blow Fan clutch removal.
CDV Delete, Auto Solutions 30%, Koni Yellows, Vogtland Springs, TopSpeed Exhaust
Jump to top akashyap is offline   Reply With Quote
Old Tue, Dec-14-2010, 01:21:22 PM   #4
monochrom3
P-Car Noob
monochrom3's Avatar
Reputation: 0 monochrom3 has disabled reputation
1) 7mm hex (doesn't usually come in a normal allen set) for replacing pads
2) protected lug bolt sleeve
997.2 GT3: Carrara White, no mods necessary
MKV GTI: Black Magic Pearl, 4-Door, DSG, APR Stage 1, Omanyt (R32) wheels, Wolfsburg front end (daily driver)
e36 M3: TechnoViolet, gutted, AutoPower rollbar, CF sunroof delete, BW door panels (track toy)
e46 M3: TiAg, ESS VT450, Dinan 3.91's, Euro headers/cats, SS x-pipe, SS race muffler; GC coilovers & swaybar; Stoptech ST60/40; OEM CSL bootlid, Dinan 19's (sold)
Jump to top monochrom3 is online now   Reply With Quote
Old Tue, Dec-14-2010, 01:38:07 PM   #5
bimmer777
I drive an AWD Turdbro
bimmer777's Avatar
Reputation: 0 bimmer777 is on a distinguished road
Ukraine
This could potentially be a very useful thread. Would be great if some of the regular track guys could chime in.
"Good drivers have dead flies on the side windows" - Walter Röhrl
Jump to top bimmer777 is offline   Reply With Quote
Old Tue, Dec-14-2010, 01:40:06 PM   #6
christopherp
Reputation: 0 christopherp is on a distinguished road
For the normal DIY maintenance: low profile jack, 3/4 hex set, torque wrench that ranges from 15-150 lbs
The skys the limit as far as tools go for cars...
OP, did you go to Iowa? I'm starting my grad program(MBA) there in January.
2005 AW/Cinn 6sp, Vert, oem ZCPs
2001 Mustang Cobra (sold)
Jump to top christopherp is offline   Reply With Quote
Old Tue, Dec-14-2010, 02:08:53 PM   #7
mugenh22a4
เป็นคนจีน
mugenh22a4's Avatar
Reputation: 0 mugenh22a4 is on a distinguished road
Hong Kong
Don't forget the Budweiser
2008 ISF, Smokey Granite Mica on Black
Jump to top mugenh22a4 is offline   Reply With Quote
Old Tue, Dec-14-2010, 04:04:57 PM   #8
kZo
kZo's Avatar
No, unfortunately I did not go to Iowa. I was born and raised here in Iowa though. Huge Hawkeye fan and season ticket owner.
MBA huh? You driving all the way to Iowa City? What do you currently do?
- kZo
2002 - BMW M3
Old Tue, Dec-14-2010, 04:06:32 PM   #9
m3freak86
JERSEY STRONG
m3freak86's Avatar
Reputation: 0 m3freak86 is on a distinguished road
Torque wrench, jack stands, low profile jack, mutiple hex bit set, ratchet wrenches, and a good socket wrench/attachments.
2004 Carbon Black ///M3 (Sold)
My Exhaust Obsession
My Journal
2013 SWP Subaru WRX Hatch
Jump to top m3freak86 is offline   Reply With Quote
Old Tue, Dec-14-2010, 04:11:32 PM   #10
wilsel
wilsel's Avatar
Reputation: 0 wilsel is on a distinguished road
1. 17mm 1/2" drive socket for the wheel studs, oil drain bolt, and tranny drain/fill bolts.
2. A collection of Torx sockets (might as well get the ones with the hole in the center, or you will end up getting 2 sets)
3. 22mm Hex Socket (for the rear diff drain/fill plugs)
4. A big C-Clamp to compress the brake caliper pistons
http://www.m3forum.net/m3forum/image.php?u=112891&type=sigpic&dateline=1266947664
Jump to top wilsel is offline   Reply With Quote
list, tool
Discussing Appropriate Tool List in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
