#11 | |
![]() Location: CA
![]() ~*Mods*~: High Flow Carbon Fiber Strut Pipe Trim, Custom Aero DME Shift Linkage, Forged Titanium Race-Euro-Spec Illuminated Diff Sleeves, Catless Dog CSL Retrofit, Mod Bug Delete & More S54 Valve Adjustment DIY, Excel, Print out: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip |
#12 |
30 something
![]() Location: San Diego
To be honest, that's not really enough to concern me... we're only talking .4 degree diff. Yeah, something might be ever so slightly bent but at the end of the day it won't make a damn bit of difference since you're able to get both sides even.
That said, a variance in strut/wheel clearance suggests a bent spindle more than a control arm, since the spindle is what holds both the shock and the wheel. Stop trippin' though... not a big deal ![]()
'04 46M 6MT || '01 330Ci 5MT |
#13 | |
![]() Location: CA
#14 | |
30 something
#15 | |
i've heard that control arms aren't so easy to bend so i did not change the curbed one... also because the previous owner had curbed on the same side. he got a new control arm and a new oem sachs brand strut, except the oem sachs strut he put on is a touring model so it was slightly longer. i only replaced the strut with the right oem model and change the tie rods and the left control arm cuz it's gone. after that i got an alignment and the left and right are off by one degree in front camber and the rears are quite uneven (more than 0.3 degrees). and it also looks uneven physically as i can feel if the wheels are lined up straight with the fender. now i have tried taking off the strut brace, plate and adjust (very limited) the stock camber but have no way to measure it the alignment afterwards. what to do? is there anyway to kinda double check before taking it to alignment shop? Last edited by 1ch1ban; Wed, Feb-02-2011 at 12:28:45 AM. |
| alignment |
