Old Wed, Dec-22-2010, 07:05:24 PM   #11
NikolaiD
NikolaiD's Avatar
Bulgaria
Default Re: 2002 vert window issue
Originally Posted by PeteyyPab View Post
The Regulator is probably at fault if the window drop is inconsistent. If you push up/down on the glass does the glass move or stay in place?? It should be pretty firm.
It sounds like you have some slop somewhere.
It does move when I push it down vertically, but in the front only. Comes down about 5mm when I push on it. Is there a guide for the line too?
I guess I should install TIS and look through it instead of bothering you...
I haven't touched the line though, just swapped the glass. I wonder why it'll slop.
MSS54 Error Codes
(work in progress)
Old Mon, Dec-27-2010, 07:05:03 PM   #12
NikolaiD
NikolaiD's Avatar
Bulgaria
To follow up, I have found a fault that is causing the window to not close.
The window holders slide on the black metal frames using 2 green delrin guides each, the top guide on the rear holder has broken to pieces and the tilt adjustment will no longer push the window in, so when the window goes up, it won't align with the top.
I guess the only way to fix that and the slop is to replace the actuator. My only question is, do I need to replace the motor as well?
MSS54 Error Codes
(work in progress)
Old Mon, Dec-27-2010, 07:09:17 PM   #13
PeteyyPab
So long M3, its been a trip!
Reputation: 0 PeteyyPab has disabled reputation
Italy
No need to replace the motor as long as it still works.. three screws a twist and pull and you can swap it over to the new regulator
TOTALED: 3/20/2011 - ill miss u, HELLO: M5, Looking forward to the journey
In the cool still hours of night, you can still hear my subframe pulling away and my VANOS bolts backing out.
VERT Subframe mount failure confirmed 5/4/2010
Jump to top PeteyyPab is offline   Reply With Quote
2002, issue, vert, window
Discussing 2002 vert window issue in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
