Old Wed, Dec-22-2010, 03:52:26 PM   #1
ndyvidual
ndyvidual's Avatar
Reputation: 0 ndyvidual is on a distinguished road
Default Effectiveness of a rear strut bar...any?
While I'm acquiring my suspension upgrade parts over the Winter, I was wondering do rear strut bars add any handling improvements to the E46. Thought I would ask knowledge think tank here. What do you think? Link below for a random example.
http://www.bmwtuningmag.com/active-a...r-strut-brace/
Jump to top ndyvidual is offline   Reply With Quote
Old Wed, Dec-22-2010, 03:58:33 PM   #2
Levim9
Reputation: 0 Levim9 is on a distinguished road
Default Re: Effectiveness of a rear strut bar...any?
I made myself a rear shock brace and I didn't really notice a difference. It does stiffen the chassis, but probably not enough that you'll notice. (Maybe you would on the track) I just like it because the ends serve as shock tower reinforcement plates and the bar looks cool.
Jump to top Levim9 is online now   Reply With Quote
Old Wed, Dec-22-2010, 04:26:50 PM   #3
ndyvidual
ndyvidual's Avatar
So far an E46, the advantages are aesthetics and possibly additional mount bracing? Can someone confirm the bracing functionality?
I'm concerned with the reduced function of the trunk cargo (pass through is reduced). I had planned to get some reinforced rear shock mounts, but if this bar will serve the same function, then I'd only get one or the other.
Old Wed, Dec-22-2010, 04:41:01 PM   #4
Levim9
I'm not sure how the size of the trunks differ between sedan and M3s but this is one I made installed in a sedan. They don't take up much space. You can't fold down the rear seats though with the bar. Some bars (like the Active Autowerke) are hinged and can be detached without getting into the shock towers. It's convenient because you can quickly take the bar section out when needed but some would say that because it's hinged, it won't be as sturdy as a one piece.
No Sunroof - Active Tuned - AFE Stg2 - JVT Headers - OEM Section 1 & 2 - Borla left exit Muffler - UUC SSK - ACT Clutch & Flywheel
Old Wed, Dec-22-2010, 05:15:26 PM   #5
m3816
Shhh..my foot is sleepin on the gas
m3816's Avatar
Reputation: 0 m3816 is on a distinguished road
if people are interested we should talk to Mason engineering for a group buy
HKS GTS8550 Stage II *SuperSprint*Aeromotive
Clutch Masters*4.10*Rogue Engineering
KW3*H&R*Ground Control*Euro rotors*SS lines
42 Design*Vorsteiner*Bimmian*Apex*//M-Alcantara
507WHP @ 8400rpm-11.2psi
**Need a Expert BMW tech in the DMV Pm Me**
Jump to top m3816 is offline   Reply With Quote
Old Wed, Dec-22-2010, 06:43:25 PM   #6
PerkM3
PerkM3's Avatar
Reputation: 0 PerkM3 is on a distinguished road
From what I've seen/read theirs is the best.
Cosmetic/Aero: BW splitter, BW canards, Brooks pro wing, V-CSL bootlid, Tekerbon CSL diffuser, V-GTR hood, CF moonroof delete, CF kidney grills, CF gills, and CF roundels
Suspension/Brakes: MOTON CS 850/450 (rear coilover), GC F/R race sways, RE FCAB/RTAB (track), TMS rear camber arms, GC race camber plates, TMS solid subframe bushings, ZCP F/R rotors, brass caliper guides, BW SS lines, PFC RH665, PFC-01, BW brake ducts/baking plates.
Performance: BW/EPIC Tune, aFe stg2 intake, SS V2 stepped headers, BW race exhaust, TMS pullies, JB Racing clutch/LW flywheel, TMS solid motor mounts, TMS solid trans mounts, BW solid diff mounts, RE shifter linkage, and BW race shifter.
Misc: TMS subframe reinforcement kit, Sparco PRO ADV seat, Sparco side mounts, VAC floor mounts, Kirk Comp. Roll Bar, Schroth Profi III 6-Point harnesses, Jafster shift knob, BimmerWorld 75mm wheel studs, and Enkei NT03+M.
Jump to top PerkM3 is offline   Reply With Quote
Old Wed, Dec-22-2010, 06:53:49 PM   #7
E-solo
E-solo's Avatar
Reputation: 0 E-solo is on a distinguished road
Wouldn't the answer depend on the suspension being used. I'm sure its more effective with a softer suspension as opposed to a stiff suspension.
Jump to top E-solo is offline   Reply With Quote
Old Wed, Dec-22-2010, 07:13:50 PM   #8
wilsel
wilsel's Avatar
Reputation: 0 wilsel is on a distinguished road
IMO the rear deck (where the rear speakers are located) is enough bracing. The only benefit I see is the additional support (thickness) for the rear shocking mounting points.
http://www.m3forum.net/m3forum/image.php?u=112891&type=sigpic&dateline=1266947664
Jump to top wilsel is offline   Reply With Quote
Old Wed, Dec-22-2010, 10:29:21 PM   #9
ClAlpha
Der Ingenieur
ClAlpha's Avatar
Reputation: 0 ClAlpha has disabled reputation
The mounts on that Active Autowerke strut bar are a much better design than those on my Dinan brace. And trust me from experience, you will LOVE that removable center section. Even in order to use the ski bag for those with cold weather packages, you'll need to unfasten the bar to fold down the center flap. Also FWIW, I haven't noticed any difference during normal street driving without the brace. So unless your car gets track or AutoX time, at best this is a mod for aesthetics.
2006 ///M3 ZCP CB/Cin 6MT
Dinan Stage 2 Tune / K&N 57 Intake / Supersprint Race / KW ST Coilovers / Weisslicht AE's / HID 3000K Fogs
Jump to top ClAlpha is offline   Reply With Quote
Old Wed, Dec-22-2010, 10:56:53 PM   #10
Kr3st
///Mean ///Muggin'
Kr3st's Avatar
Reputation: 0 Kr3st is on a distinguished road
I thought if you wanted to Autox the car you want the front end to be stiff with a strut then you want the rear to be able to move around. Meaning not to add one to the back.
Am I wrong?
Supersprint Race |Quad FX-R|TE37SL | BC Racing Coilovers | AA Headers | AA Supercharged 516rwhp on pump gas
Jump to top Kr3st is offline   Reply With Quote
bar, rear, strut, suspension
Discussing Effectiveness of a rear strut bar...any? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
