#21 |
![]() Location: San Jose, Ca
i did at least double this so far and i'm not done yet:
full cooling system front control arms fcabs rtabs warranty on tck shocks new gc endlinks clutch and bearing motor mounts CPV injector cleaning alternator spark plugs pulleys re tranny mounts were still good gonna do all ball joints and bushings in the rear & subframe reinforcement soon there's probably more i'm missing
PM me for a Shim Kit |
#22 |
![]() Location: SE PA
Yep. In the last 20,000 miles I have replaced every single piece of rubber and balljoint on the car
Current Cars: 2005 IR/IR M3, 2003 TiAg M5, 1995 S50 B32 GT3 RS Green M3 Race Car _____Former Cars: 2004 TiAg/IR M3, 1996 TV/black M3, 1995 AW M3 shell Useful stuff: Objective suspension comparison, DIY suspension install VIDEOS (e36 version), Stick Driving Basics, e46 Climate Control, Better Fuel Economy 101, 10W-60 TWS Everything on the car: Mod List __________ HighRes M Wallpapers (Misc collected pics) <--- save target to desktop Selling: Suspensions, brakes, safety equipment, etc (ask away!) Renting: Valve shim adjustment kit, RTAB tool, Ball joint tool |
#23 |
I still think it's overboard. Maintenance doesn't necessarily imply replace even if it's still good. Many of those items and parts can be periodically inspected and you can actually assess - albeit not always, I'll give you that - whether a replacement is needed.
The example of radiator, radiator hoses, and drive belts was a bad one. All three can be easily inspected and assessed for damage and/or wear. Your drive belt doesn't simply snap off over night without exhibiting some signs of wear like noise, etc. You can't simply put a mileage on some parts. Driving habits and environment play a huge role. For example, I've been driving manual transmission cars for the last 15 years. I know that this is going to come as a shocker to many of you, but I never burned a clutch, going back to my 1991 Accord days with over 200k miles on the original clutch. I know people who needed clutch replacements in the M3 after 30k miles of ownership.
![]() 2004 Alpine White M3 Coupe - 6MT - HK - Navigation - Factory Sunroof Delete 1998 AW M3/4/5 - sold |
#24 |
A clutch geting worn out by noob driving has no bearing on the life of components like the alternator, water pump, etc.
#25 |
![]() Location: San Francisco
I have a warranty which is why i may think this is "overboard" i do simple maintenance such as spark plugs, RTABS FCABs oil change, but nothing serious.
If something decides to die, this is why i paid money for the warranty. Not trying to have my car run my life or be constantly on my mind. As nice as the M may be, it is just a tool. Either way, good job on taking good care of your car. Thumbs up!
#26 | |
Your water pump and other cooling components can be greatly affected by the environment. On many cars the pump's internal seals and impellers can deteriorate faster in cold climates and where there is salt/corrosion, ultimately leading to premature water pump failure. But environmental factors can also be controlled. For instance, garaging your car in winter vs letting it sit outside.
#27 |
My water pump (car) is garaged every night and blew up at 97,000-- 3000 miles before I was going to replace it. Resulting in me being driven 300 miles home to get the truck/trailer, 300 miles back to pick up the car, then 300 miles back home again. 900 extra miles of driving, 600 of which were in a truck with a trailer.
... which was the single time my car has broken down on me. I'm not even going to wait 100,000 for my next cooling system swap.
#28 | |
#29 |
FWIW, i'm in cali and my water pump looked brand new when i changed it out at 102k
#30 |
That's true, but I think you're expected service life range is off. People lose their water pumps at 70k on this car fairly regularly. I think 100k is a pretty full life, beyond which anyone is really pushing their luck.
Could be worse, could be the e36, where 75k is pushing your luck ![]()
| 100k, cooling system, maintenance, radiator |
