Old Tue, May-03-2011, 09:54:56 PM   #11
02SMG
Reputation: 0 02SMG is on a distinguished road
Default Re: What offset should I run up front on a 19x9.5 wheel?
Originally Posted by M3ANMACHINE View Post
True.
I would highly recommend the +33 over the +45
Why is that? Your previous wheels were +45 right?
Thanks for all info and advise.
Jump to top 02SMG is offline   Reply With Quote
Old Thu, May-26-2011, 05:19:34 AM   #12
mr_bmw_m3
Reputation: 0 mr_bmw_m3 is on a distinguished road
Hey m3anmachine do you know if the 19x9.5 +33 will rub on the KW v3 coilovers up front..?
Murdered Out !
Jump to top mr_bmw_m3 is offline   Reply With Quote
Old Thu, May-26-2011, 06:11:35 AM   #13
M3ANMACHINE
@natrajusa
M3ANMACHINE's Avatar
Yes, but with a 25mm spacer...
+45 would most likely hit the suspension components.
I don't have any experience with the KW's but you can always run a small spacer if they don't clear.
2011 E90 ///M3 | Space Grey | Fox Red | DCT | ZCP | Slicktop
2008 E90 M3 | AW | 6MT | Slicktop
2004 E46 M3 | CB | SMG
Old Thu, May-26-2011, 08:38:48 AM   #14
highf1yinazn
highf1yinazn's Avatar
Reputation: 0 highf1yinazn is on a distinguished road
Im running 19 x 9.5 with +27 offset with 245/35 up front and this setup barely clears the KW v2. With a +33, you will sit 5mm in more towards the coilover strut perch. This will be very close depending on your tire selection.
Interior: Recaro Pole Positions, Wedge Engineering, Hardwired Valentine 1
Exterior: Carbon CSL Trunk & Vorsteiner Diffuser, Aurora AE, Matte Grills & Gills, Squared ZCP/CSL
Suspension: KW V2's, Powerflex RTABs, Rogue Engineering RSM, KW end links, HPF Subframe Reinforcement
Performance: Catless Headers, Resonated Sec1, SGT Ti Exhaust
Jump to top highf1yinazn is offline   Reply With Quote
Old Thu, May-26-2011, 09:52:41 AM   #15
Nicke
Reputation: 0 Nicke is on a distinguished road
Finland
Heres the stock rears upfront. 19*9,5 et 27, camber I'm not sure of ( there definately is some, since the car has "camber mod" with the suspension) but will go for an alignement soon. Tires are 245/35. They fit nicely and don't touch anywhere, but there isn't tons of room (but surely enough). (Dont mind the dirt allover...)
BMW e46 M3 Coupe Jet Black/Cinnamon -02
Jump to top Nicke is offline   Reply With Quote
Old Thu, May-26-2011, 11:08:15 PM   #16
SIN3
Wheel Fitment Connoisseur
SIN3's Avatar
Reputation: 0 SIN3 is on a distinguished road
my wifes non M ZHP
with OEM 19x9.5 squared. stretched tires and cambered mod front and arms rear.
2006 M3 Cabrio sold
"keep it clean, keep it OEM+"
Jump to top SIN3 is offline   Reply With Quote
Old Tue, Jun-14-2011, 01:41:47 AM   #17
02SMG
What's your rear setup?
Discussing What offset should I run up front on a 19x9.5 wheel? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
