Old Tue, May-24-2011, 09:57:36 PM   #1
karlviet
karlviet
Reputation: 0 karlviet is on a distinguished road
Default Check Control Module By-Pass
I was extremely grateful for the advice given here http://forums.bimmerforums.com/forum...hlight=lbf+fix when I installed HIDs and kept getting a low beam failure message. After I had installed Depos in the rear I then started to get similar messages for the tails and stop lights (LEDs) and wondered if there was a similar solution. After studying the wiring diagrams, I came up with a similar solution to by-pass the CCM and avoid all those error messages.
Follow the advice given in the thread above to by-pass the CCM on the low beam circuit. Next to the white plug to the CCM is a black plug. The white plug covers the front of the car, while the black plug covers the rear. You will be connecting together wires from both plugs, if you continue.
If you want to by-pass the CCM for the tail lights, cut the following wires from the plugs and join them together:
1. grey/white/yellow band + grey/blue/yellow band + grey/yellow
2. grey/violet/yellow band + grey/green/yellow band + grey/violet
The first connections cover the right cluster and the second connections the left cluster.
If you want to by-pass the CCM for the stop lamps, cut the blue/red (right cluster) and blue/brown (left cluster) running to the black plug and the blue/red running to the white plug and connect them together.
By carrying out the following procedure, you will avoid all those annoying error messages without losing the advantage of being warned when your washer fluid, coolant, etc is down.
I made solderd connections and finished off with heat-shrink, but you can do it however you like.
Jump to top karlviet is offline   Reply With Quote
Old Tue, May-24-2011, 10:00:39 PM   #2
Default Re: Check Control Module By-Pass
I'd rather disable the check control system through the software on the OBC than cut a single wire as a "fix".
On that note, I'd probably get OEM lighting first and not have to resort to such measures. LED E36 tails
Old Tue, May-24-2011, 10:04:53 PM   #3
ASC FTL
it only holds back the M POWAAH
Reputation: 0 ASC FTL has disabled reputation
Ive never seen LED tails on an e36... any pics?
'99 s52 ///M3 s50 mani, JC CAI, JC tune, remus exhaust, ASC delete, xbrace, Eibach Pro springs, Konis, zionsville rad, ZKW hids
Jump to top ASC FTL is offline   Reply With Quote
Old Tue, May-24-2011, 10:06:56 PM   #4
WRXEATR
The Frugal and Outspoken One
Reputation: 0 WRXEATR is on a distinguished road
Brett speaks the truth....
Jump to top WRXEATR is offline   Reply With Quote
Old Tue, May-24-2011, 10:15:34 PM   #5
Old Tue, May-24-2011, 10:21:21 PM   #6
ASC FTL
Those housings are terrible, I thought you guys meant OEM with DIY leds or something.
Old Tue, May-24-2011, 10:24:51 PM   #7
Nope, he meant Chinese Alibaba ordered lights.
Old Wed, May-25-2011, 01:17:21 AM   #8
scoobiedoo2029
Reputation: 0 scoobiedoo2029 is on a distinguished road
well thats cool about getting the obc to shut up, but howabout making it stop with the brake light circuit failure? im really thinking its my aftermarket clear tail lights causing it not the brake light switch. my brake lights always work but i sometimes get the error ant its annoying to see the obc keep blinking at you.
Jump to top scoobiedoo2029 is offline   Reply With Quote
Old Wed, May-25-2011, 01:18:05 AM   #9
Disable it in the software test features.
bulb failure, ccm by-pass, hid, led
Discussing Check Control Module By-Pass in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
