Old Mon, Apr-30-2012, 02:55:32 AM   #321
BQAD
Reputation: 0 BQAD is on a distinguished road
Default Re: New (awesome) DIY programable option: CSL launch control and shifting (SMG)
I noticed the same thing when I flashed mine to the latest US software. I don't think the issue is the software, I think it's the adaptations. The official procedure per BMW is to re-adapt the trans and clutch after installing new software. If this isn't done correctly I think you end up with slow clutch engagement. Also it takes several hot/cold cycles to fully adjust after doing the adaptations. I just readapted my SMG today using the full and proper procedure in DIS. I'll report back if it makes a difference.
I don't care where just far...
Jump to top BQAD is offline   Reply With Quote
Old Mon, Apr-30-2012, 09:19:59 PM   #322
daumas
Reputation: 0 daumas is on a distinguished road
I did the full adjustment with INPA on both cars I flashed, immediately after flashing. No clutch slip on either car.
Jump to top daumas is offline   Reply With Quote
Old Wed, May-02-2012, 12:37:56 PM   #323
mr_bmw_m3
Reputation: 0 mr_bmw_m3 is on a distinguished road
Just got my car back from the dealer after having it booked in for the SMG & DME updates. Are these updates recent....?
Asked for the CSL update but they said they need a real CSL beside it to perform the update... ?
Numbers are:
DME
OLD: 7835617
NEW: 7837929
SMG:
OLD: 7836384
NEW: 7843253
I also had it booked for various other issues. Got the report and the receipt attached...
Car still pulls to the left...
Car is running KW V3's.
Murdered Out !
Jump to top mr_bmw_m3 is offline   Reply With Quote
Old Wed, May-02-2012, 02:43:28 PM   #324
daumas
Originally Posted by mr_bmw_m3 View Post
SMG:
OLD: 7836384
NEW: 7843253
No. The CSL software is 7843255. If you read this thread instead of posting once (and probably never coming back) you'd have seen this in 30 seconds.
Old Wed, May-02-2012, 04:32:32 PM   #325
wildpig
wildpig
Reputation: 0 wildpig is on a distinguished road
read the guy post. Stealer refused to input 255, due to his car being non csl and upgrade to whatever latest non-csl smg software.
Jump to top wildpig is offline   Reply With Quote
Old Wed, May-02-2012, 11:14:12 PM   #326
mr_bmw_m3
Thank you WildPig
Murdered Out !
Old Thu, May-03-2012, 01:29:14 AM   #327
LSM3
Reputation: 0 LSM3 is on a distinguished road
What is this procedure exactly?? Can you report whether there is a difference afterwards?
_______________________________________________
2006 M3 Competition Package : Interlagos Blau
ESS Tune : CSL SMG Tune : Eisenmann Race : AE : Eibach : Tekarbon
Jump to top LSM3 is offline   Reply With Quote
Old Thu, May-03-2012, 11:28:16 AM   #328
mr_bmw_m3
Figured it out. The PDF is missing a VERY important step.
After importing all of the data and copying ECU and SGDAT, you must ALSO copy the GDATEN folder. You may also have to edit the SGIDC.AS2 file and remove a line if WinKFP says it cannot read it. It will tell you the line number.
I just flashed my car. Took about 30 seconds! No battery charger used (yes, very risky).
I did exactly the above, but I still get that Error 200 as previously posted.
Murdered Out !
Old Fri, May-04-2012, 02:34:32 PM   #329
BQAD
1. Teach clutch valve values
2. Fully adapt transmission
3. Teach clutch slip point
4. Teach the offset of the longitudinal acceleration sensor
5. Reset clutch curve
Attached are screen shots from DIS. I was across the country on business all week so I haven't had a chance to drive it much yet. You can definitely feel that it's changed but I need to drive it for a solid week before I'll know how much of a difference it makes.
*Update*
So after driving it for more than a week it definitely feels better. There's still a small delay/slip when giving it full throttle but otherwise it's back to the way it was before I updated. Quick shifts with a bit of clunk in S5 and no clunk in S4. Based on some other posts I read I think the last step (reset clutch curve) is important for the whole procedure to work correctly. I didn't do that last step the first few times I did the adaptations.
Old Mon, May-07-2012, 03:09:10 AM   #330
mr_bmw_m3
dont use DIS, i only got autoenginuity tool...
stutter gone, still slips and drives like ****.
hey on another note, if I move my steering wheel column all the way down, ALOT of excessive engine noise comes through the cabin, sounds like ****. when the car revs it not a deep throaty M3 sounds its like a little 4 cylinder whirring noise, my girl always laughs it Dealer said all m3's do it...
Murdered Out !
Discussing New (awesome) DIY programable option: CSL launch control and shifting (SMG) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
