Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > M3Forum Sponsor Announcements and Specials
M3Forum Sponsor Announcements and Specials Browse this forum to locate any specials our board sponsors may be holding.
Old Fri, Sep-09-2011, 07:41:03 PM   #1
ECSTuning
ECSTuning's Avatar
Reputation: 0 ECSTuning is on a distinguished road
Default :: ECS Tuning :: Schwaben Tools!
As a proud retailer of Schwaben Tools we will be utilizing this thread to introduce new products to you as well as answer any tool related questions.
Ever wonder what tool you need to make working on your BMW easier?
Schwaben has a collection of BMW specific tools to get the job done.
Click here to view all Schwaben BMW Tools
Schwaben Protecta Socket Set
Includes 17mm, 19mm and 21mm sockets.
Ever fear using your sockets around delicate paint and other finishes. The plastic outer coatings on the sockets prevents damage commonly associated with installation and removal of wheels. 1/2" drive sockets allow you to install a breaker bar and remove even the most stubborn wheel bolts. Chrome molly construction is the ultimate in strength and prove you with years of service. Convenient carrying case snaps closed to keep your sockets organized and protected.
Two styles to choose from
Standard Protecta Socket Set $19.95
and
Long Reach Protecta Socket Set $39.95
Click here to order or for more information.
Have questions? Need answers? Live Chat us! 8:30am to 12:00am Midnight EST
sales@ecstuning.com | customerservice@ecstuning.com
Customer Service Hours: 8:00 AM to 8:00 PM EST
Sales Team Hours: 8:00 to 11:00 PM EST
800.924.5172
Facebook | YouTube|OEM BMW Part Number Search
Jump to top ECSTuning is offline   Reply With Quote
Old Mon, Oct-10-2011, 07:24:56 PM   #2
ECSTuning
ECSTuning's Avatar
Default Re: :: ECS Tuning :: Schwaben Tools!
We here at ECS Tuning are proud to announce not one but TWO new Schwaben tools specific for making working on your BMW easier! The Schwaben BMW Water Pump Pulley Tool and The Schwaben BMW Service Wrench.
Tired of busted knuckles? The Schwaben BMW Water Pump Pulley Locking Tool can not only save your knuckles but save you time!
The Schwaben water pump holder is a must-have item for removing BMW engine cooling fans. Just screw it on to the water pump pulley using two pump bolts. The long lever and positive attachment then let you hold the pump stationary while loosening the reverse-thread fan coupling.
Eliminates the hassle and aggravation of keeping the pump stationary with pliers or other makeshift holders. Safer, too.
Works on many 6 cylinder BMW engines, including M52, M54, S50, S52.
The Schwaben BMW Service Wrench is a step saver when performing regular maintenance on a BMW.
Take one wrench, not two. Remove and tighten BMW engine, transmission, and differential fill and drain plugs with a single tool. The long chrome handle is durable and provides extra leverage for removing tight plugs.
A must have addition for professional technician or pro-sumer, alike.
ECS Tuning
800.924.5172
Old Tue, Apr-03-2012, 09:00:19 PM   #3
ECSTuning
ECSTuning's Avatar
Have you ever said to yourself, "If I only had the right tri wing bit I could finish this job!"
Well now you can with the Schwabeen 100 Piece Bit set!
The Schwaben 100-piece specialty bit set includes bits to fit a wide assortment of automotive fasteners, including tamper-proof Torx® and hex bits. Breeze through repairs knowing you can remove odd specialty fasteners with ease.
These bits are made of hardened Chrome Vanadium steel for years of dependable use. Packaged in a handy blow molded case with individually marked bit slots for easy organization.
Set includes:
10 fractional SAE hex, 9 Torx tamper-proof, 9 Torx
9 Metric hex bits, 9 slotted bits, 8 Pozi-drive, 8 Phillips, 4 square-recess, 4 tri-wing
3 spline, 3 Torq, 3 clutch, wing-nut driver, magnetic bit holder and socket bit holder
Having the right tool for the job is half the battle.
Click HERE to order your 100 Piece Bit Set today!
800.924.5172
Old Wed, May-09-2012, 08:25:49 PM   #4
ECSTuning
ECSTuning's Avatar
This sturdy steel wrench has a polished chrome finish, quick reverse lever, and knurled locking handle to maintain the selected torque setting when in use.
The Schwaben Torque Wrenches are the right tool for the job.
Click HERE for 1/2" Drive
Click HERE for 3/8" Drive
800.924.5172
Discussing :: ECS Tuning :: Schwaben Tools! in the M3Forum Sponsor Announcements and Specials Forum - Browse this forum to locate any specials our board sponsors may be holding. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
