Old Tue, Sep-27-2011, 04:24:43 PM   #1
E46Dinan
E46Dinan's Avatar
Reputation: 0 E46Dinan is on a distinguished road
Default moisture in headlight lens?
Found my drivers side lens dripping with moisture inside. Lens are like new.
Disassembled, wiped out moisture, checked sealing strips, reassembled. No rain or wash and next day full of moisture again?? What's happening?
2003 1/2 M3 coupe AW and LSB interior, 4.10's, Comp wheels, brakes, SMG unit. TMS reinf. AA exhaust, Powerflex, Koni, Eibach,etc..
2001 325CI Dinan 3 TS and IR M3 interior, 5spd sold
2001 M3 convert TS and Black interior,6 spd sold
1995 M3,5 spd sold
1986 635Csi, 5 spd sold
Jump to top E46Dinan is offline   Reply With Quote
Old Tue, Sep-27-2011, 04:26:36 PM   #2
LightWerkz
Automotive Lighting Innovations
LightWerkz's Avatar
Reputation: 0 LightWerkz is on a distinguished road
Default Re: moisture in headlight lens?
Lenses arent seating correctly, or there is damage to the gasket in between the lens and housing.
If its not that I would check for a crack in the housing.
Caesar Rowinski - LIGHTWERKZ
2001 BMW M5 - Alpine White on Caramel
Jump to top LightWerkz is offline   Reply With Quote
Old Tue, Sep-27-2011, 04:27:30 PM   #3
m3freak86
JERSEY STRONG
m3freak86's Avatar
Reputation: 0 m3freak86 is on a distinguished road
Make sure all of the plastic tabs aren't bent in which causes the seal to have a gap and let moisture in. The tab I am mainly talking about is the one on the inside of each headlight. It's a skinny black plastic tab that helps align the headlight lens. I made this mistake once and closed the headlight up with that plastic tab bent in by accident. Saw it let moisture in. Took it apart and realized it was bent in.
If that's not the case, look around your seal to see if there are any cracks. Rubber wears out over time.
2013 SWP Subaru WRX Hatch (gone)
WRX Journal
2004 Carbon Black///M3 (gone)
Mods and Specs
My Exhaust Obsession
My Journal
Jump to top m3freak86 is offline   Reply With Quote
Old Tue, Sep-27-2011, 04:31:45 PM   #4
M3_mann
Reputation: 0 M3_mann is on a distinguished road
Probably corrosion on the rubber seal between the headlight and lens. Check for anything that can cause a leak. crack, bend...even holes. I had a rock chip crack on the driver side corner, and that caused moisture to form.
2008 Space Grey/Extended Black ///M3
2003 A07/Imola ///M3
Past BMWs-
2006 Interlagos Blue ZCP 6mt E46 ///M3
2003 Imola Red SMG, 2003 Carbon Black 6mt E46 ///M3
2004 & 2005 Mystic Blue E46 ///M3 6mt
1990 E30 325is - S52 Swapped
1987 Euro E30
Jump to top M3_mann is offline   Reply With Quote
Old Tue, Sep-27-2011, 04:46:36 PM   #5
E46Dinan
E46Dinan's Avatar
Thanks for quick responses. Gasket looks like new and I has carefull to wipe it before reassembly. Must have drawn moisture in as it has been humid here and never rained since I cleared it. Hate to disassemble again.
1995 M3,5 spd sold
Old Tue, Sep-27-2011, 04:49:48 PM   #6
Dan4hockey99
stancebro4lyfe
Dan4hockey99's Avatar
Reputation: 0 Dan4hockey99 is on a distinguished road
Ukraine
My depo corner has moisture in it but I can't even open it to get it out...it's the one piece that you screw in...any tips? No cracks anywhere?!
1998 BMW M3 LS1 Swap
| Felony Form | 5.7L LS1 | Enkei RPF1 | Renown | Brembo | BC Racing Coilovers |
Jump to top Dan4hockey99 is offline   Reply With Quote
Old Tue, Sep-27-2011, 04:52:13 PM   #7
m3freak86
JERSEY STRONG
m3freak86's Avatar
It's a gamble with those. Some have cracks in them and let moisture in, some don't. My first set I had fogged up everytime I washed the car. Hated it, so I bought another set and no fogging problems at all. If you don't want to get another set, try putting some seal around the edges/cracks.
WRX Journal
Mods and Specs
My Journal
Old Tue, Sep-27-2011, 05:24:40 PM   #8
TheGoodGuy
Superhero
Reputation: 0 TheGoodGuy is on a distinguished road
Check all of what was mentioned above, once you find your culprit, before you fix it, throw in a anti-moisture pellet bag(like the ones inside shoe boxes) before you put the headlight back together, that should keep it from building moisture again!
2x 90 M3's | 97 M3/4/5
Jump to top TheGoodGuy is offline   Reply With Quote
Old Tue, Sep-27-2011, 05:30:45 PM   #9
AP3X_FTW
Visor Down For Business
AP3X_FTW's Avatar
Reputation: 0 AP3X_FTW is on a distinguished road
I also have this issue on my passenger headlight and it just started happening after I installed my AE's. I have to install my 6000k bulbs and ZKW lenses anyways so Ill be taking them apart and doing s quick inspection.
E46 M3 Slicktop
E70 X5 M Sport
i3 RE
Jump to top AP3X_FTW is offline   Reply With Quote
Old Tue, Sep-27-2011, 05:33:55 PM   #10
SMG333
Reputation: 0 SMG333 is on a distinguished road
I had this problem a few weeks back. My problem was the clip as mentioned by m3freak. After I fixed it the next day i had moisture again. . .i turned the headlights on, heated the moisture away and it did not return. I guess i had fixed it on another muggy day and what was trapped fogged up a little. I dont know if this is your problem but give it a try.
Jump to top SMG333 is offline   Reply With Quote
Discussing moisture in headlight lens? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
