Old Sun, Nov-13-2011, 01:47:34 AM   #1
aznbo187
MCLA
aznbo187's Avatar
Default DIY: E46 M3 Oil Change
Since the other thread is from the last decade, I figured it was a good idea to make a more thorough DIY thread with current part numbers and a video.
HD Images along with the DIY are also hosted at MClub.la
Maintenance Schedule
BMW recommends an oil and filter change every 15,000 miles. Most enthusiasts find that range a bit excessive and perform an oil and filter change every 7,500 miles. Not only will this prolong the life of the engine internals, but proper lubrication is a vital to the VANOS system and rod bearings – two sensitive components of the S54 engine. Again, this is a very subjective decision, but changing it sooner does give you some piece of mind.
An oil change is simple and straight forward. You will need these two items:
(1) Oil Filter Kit
(6 Liters) Synthetic 10w-60 Oil
Tools needed:
  • A way to elevate your car (ramps, lift, hydraulic jack)
  • Drain Funnel & Drain Pan (6 quart capacity)
  • Torque Wrench (3/4 Inch Drive; 5-80ft/lbs Range)
  • Socket Wrench (3/4 Inch Drive)
  • 13mm Socket (3/4 Inch Drive)
  • 6mm Hex Socket (3/4 Inch Drive)
  • Flathead Screwdriver
Filter Kit Options
There are several oil filters available, but I would limit it to these three OEM, or OE-spec filter manufacturers. All three of these have proven reliability and, most importantly, include the new O-Rings for the housing cap and bolt, as well as the new crush washer required for every change.
  • BMW Original Oil Filter Kit (11-42-1-730-389)
  • Mann Oil Filter Kit (HU 926/4X)
  • Mahle Oil Filter Kit (OX187D)
Engine Oil Options
BMW’s factory recommended oil is Castrol TWS 10w-60, which was specifically engineered for the Motorsport marquee by Castrol.
Some independent shops recommend Liqui Moly Race Tech GT1, Mobil 1 Extended Life Synthetic 10w-60 and other performance brands. There is no added benefit, as the BMW factory recommended Castrol 10w-60 has been proven to work fine even in 500whp forced induction applications. There may be some monetary savings, but it’s usually only about $25-30 per oil change. Extensive internet debate actually recommends the Castrol blend above all others for this application.
  • Castrol TWS 10w-60 (OEM Fluid)
  • Liqui Moly Race Tech GT1 10w-60
  • Mobil 1 Extended Life Synthetic 10w-60
Ok, and the most important part - instructions! Read these, watch the video and it all will make sense.
1. Drive around to get your car to normal operating temperatures.
2. Jack up the front of the car and remove the black plastic oil drain access panel with a flat head.
3. Open the hood and locate the oil filter housing. Using the 13mm socket wrench remove the oil filter housing bolt that holds the cap down. Take caution as the filter will still be hot to the touch, as well as the filter element.
4. Remove the bolt, filter, and housing cap and place it on your work bench.
5. The new filter kit will come with a set of new o-ring and washers. There is a big O-Ring on the filter housing cap, a small o-ring on the housing bolt, and a small washer on the housing bolt as well. Remove and replace them.
6. Wipe down the filter housing, and install new filter.
7. Back on the bottom of the car, bring your oil drain pan and place it under the drain bolt. Remove the drain bolt using the 6mm hex socket. Be careful not to strip the bolt as it's a soft metal compound and strips easily.
8. Replace the drain bolt washer with a new washer included in the filter kit.
9. Once done draining, re-install the drain bolt, and torque the drain bolt to 18ft/lbs using the torque wrench.
10. Fill the fresh fluid via the filter housing or engine oil cap opening. It's a good practice to fill one bottle through the new filter to pre-saturate it.
11. The engine needs 6.3 quarts, which is 6 bottles. But most of the time you will be refilling roughly 5.5 bottles, due to the residual oil that doesn't drain. I always fill about 5.5 bottles, and check the dipstick to make sure.
12. Once fresh fluid is filled, re-install the filter housing cap and bolt and torque it down to 24ft/lbs.
13. Drive around for a few minutes, and re-check oil level. Fluid level should be in between the two marks on the dipstick. If on the lower half, top off with some fluid.
Disclaimer
If you found this video/how-to guide helpful, it would be nice if you could like the YouTube video, or subscribe to our channel so we have a chance to be an affiliate. That's all.
Old Thu, Dec-22-2011, 06:03:45 AM   #2
Captai
Reputation: 0 Captai is on a distinguished road
Default Re: DIY: E46 M3 Oil Change
If i presaturate the filter with a full bottle, will i still need to fill the engine with 6 bottles? making it a total of 7 bottles needed for the procedure?
Jump to top Captai is online now   Reply With Quote
Old Thu, Dec-22-2011, 06:23:10 AM   #3
aznbo187
MCLA
aznbo187's Avatar
Nope. This just means that instead of pouring all 6 bottles through the oil cap inlet, you are using one and saturating the filter with it. This does not mean you need an extra bottle. Total capacity does not change.
MCLUB | Los Angeles
Old Fri, Dec-23-2011, 08:49:43 AM   #4
Captai
Thank you!
Much appreciated
Old Fri, Dec-23-2011, 09:23:09 AM   #5
SkeeterV
Reputation: 0 SkeeterV is on a distinguished road
great diy!! simple and very useful.
Jump to top SkeeterV is offline   Reply With Quote
Old Sun, Dec-25-2011, 12:59:12 AM   #6
Toby22
Reputation: 0 Toby22 is on a distinguished road
wow thanks for the video/DIY! i will be doing my first oil change on this car....cant wait Nice to see fellow members taking time to help others, thanks again!!
2003 JB E46 M3-DD
OEM ZCP 19's/Brembo BBK/BC Coilovers/SGT CSL Bootlid/OEM Euro Front Bumper/Evosport Jet Coated Headers/Milltek Muffler/Euro Section1/AA Tune/H&R Wheel Spacers/BMW Performance Pedals/EuroTray/ZHP Shift Knob
2003 Brickyard 350z-SOLD
VOLK TE37/StanceGr+ Coilovers/NISMO Stune Exhaust/Sparco R100 Seats/Veilside V1 Front Lip/ARC Ti Shiftknob/NISMO CAI/Motordyne Plenum Spacer/Megan Longtube Headers/Pioneer AvicD3/Eibach Camber Arms/Rays Duraluminum Lug Nuts/06+ BiXenon Headlights/06+ LED taillights/06+ Front Bumper/UR Underdrive Pulley/CF Engine cover/NISMO Oil Cap/Greddy Strut Bar
2004 SER SpecV-SOLD
STOCK
Jump to top Toby22 is offline   Reply With Quote
Old Tue, Jan-03-2012, 04:20:12 PM   #7
hsverma
hsverma's Avatar
Reputation: 0 hsverma is on a distinguished road
Can anyone please recommend a good Torque wrench (one that actually works) in this range (Ratchet Type 3/8 inch Drive Torque Wrench 5 - 80lbs)? Where can I buy one? The HF one's don't work at lower torque ranges.
Jump to top hsverma is offline   Reply With Quote
Old Tue, Jan-03-2012, 08:00:51 PM   #8
lucky_doggg7
lucky_doggg7
Reputation: 11 lucky_doggg7 is on a distinguished road
Adding to this post, I used a genuine BMW oil plug that uses, if I recall correctly, a 13 mm wrench, instead of the hex key headed drain plug that takes a 6mm hex key. It fit perfectly for some years but recently on an oil change, when the plug was removed, it also took out the aluminum sump pan's threads with it! Yikes! A shop I go to managed to "Time-cert" the stripped hole so now I have a steel threaded insert in my sump pan, AND I use the stock 6mm hex head plug now. I'm thinking if I wasn't so lazy in in buying hex keys, I would have saved myself some money and prevented myself some aggravation, and general drama. Moral to the story: Use the Stock 6mm keyed Oil Plug!
Jump to top lucky_doggg7 is offline   Reply With Quote
Old Tue, Jan-03-2012, 08:45:43 PM   #9
ECSTuning
ECSTuning's Avatar
Reputation: 0 ECSTuning is on a distinguished road
Great DIY! I have an Oil Change kit found HERE which with all the fluids and parts needed for this DIY.
ECS Tuning
Have questions? Need answers? Live Chat us! 8:30am to 12:00am Midnight EST
sales@ecstuning.com | customerservice@ecstuning.com
Customer Service Hours: 8:00 AM to 8:00 PM EST
Sales Team Hours: 8:00 to 11:00 PM EST
800.924.5172
Facebook | YouTube|OEM BMW Part Number Search
Jump to top ECSTuning is online now   Reply With Quote
Old Wed, Jan-04-2012, 02:38:06 AM   #10
Jako1
Jako1's Avatar
Reputation: 0 Jako1 is on a distinguished road
You don't really need a torque wrench. Just tight is good. That means, a little tap with the palm of your hand against the ratchet arm.... After you feel that the plug has seated against the pan.
Jump to top Jako1 is offline   Reply With Quote
diy, e46, maintenance, mclub.la, oil change
Discussing DIY: E46 M3 Oil Change in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
