Old Mon, Aug-09-2004, 11:31:40 PM   #1
jidexl
SPEED
jidexl's Avatar
Reputation: 0 jidexl is on a distinguished road
Unhappy Damaged Rear Differential---GRINDING NOISE-HAVE U HAD THIS PROBLEM
Noticed a grinding noise on sunday so I took the car to the delear thinking it was the brakes.
The service guy promptly told me that it was the rear differential and it was a common problem on the E46 M3. WOW
Has anyone else had this problem
I should get the car back in a few days. I'm getting the SMG recall done at the same time
What gives with the M3????????????????????.
A Video Is Worth a Thousand Pictures
Jump to top jidexl is offline   Reply With Quote
Old Mon, Aug-09-2004, 11:42:27 PM   #2
prvtartnet
prvtartnet's Avatar
Reputation: 0 prvtartnet is on a distinguished road
It's very common. I had my differential and drive shaft replaced. The first time I heard thje grinding it freaked me out. They replaced the differential oil with a much heavier oil. That only masked the problem. They finally replaced it. The regional rep told me they had many such cases.
2004 Silbergrau Black Nappa-Alum Trim-SMG-NAV-19's-Sunshade-Rasp-X-GSP Pedals-Painted Reflectors-Bi-Xenons-PIAA Super Whites-Premium Pkg-Hoen HID-Sirius Radio JL Audio 250/1 monoblock JL Stealthboxes PSS9's Ice-Link- K&N Type 57 Cold Air Intake- Platinum Grill, OEM CSL Rear Diffusor
Skype me-rmarks
http://skype.com
Jump to top prvtartnet is offline   Reply With Quote
Old Mon, Aug-09-2004, 11:46:05 PM   #3
Sirius
How many licks..
Sirius's Avatar
Search it out. Theres been alot of threads on this issue.
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪
97' M3. '10 R6.
Old Tue, Aug-10-2004, 01:54:43 AM   #4
jidexl
SPEED
jidexl's Avatar
Talking Thanx
Thanks I didin't know it was such a common problem
Old Tue, Aug-10-2004, 02:48:17 AM   #5
BaRuMBaDo
Reputation: 0 BaRuMBaDo is on a distinguished road
Check out SIB 33 01 02, 12/2003. Your problem may be solved by it.
http://members.roadfly.org/bmw_e46_m3/index.html
Silver Grey on Imola Red 2004 E46 M3 SMG II
StopTech, Ground Control, BBS RS-GT, 245/265 Michelin PS2
Le Club BMW du Quebec
Jump to top BaRuMBaDo is offline   Reply With Quote
Old Tue, Aug-10-2004, 03:27:33 AM   #6
MattMan
Modded
MattMan's Avatar
Reputation: 573 MattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond reputeMattMan has a reputation beyond repute
the SIB won't fix it.. it never has really.. only fix is FULL REPLACEMENT. Search for Differential grind and you'll see many who have this.. 1 of 3 of my E46 M3s had it.
MattMan
2013 IB E92 M3 6MT
IG: @mattzcp
Jump to top MattMan is offline   Reply With Quote
Old Tue, Aug-10-2004, 03:51:43 AM   #7
M3guyCA
M3guyCA's Avatar
Reputation: 0 M3guyCA is on a distinguished road
ask GRIM333
Jump to top M3guyCA is offline   Reply With Quote
Old Tue, Aug-10-2004, 03:54:06 AM   #8
MattMan
Modded
MattMan's Avatar
http://www.m3forum.net/m3forum/showthread.php?t=28301
http://www.m3forum.net/m3forum/showthread.php?t=31050
MattMan
2013 IB E92 M3 6MT
IG: @mattzcp
Old Tue, Aug-10-2004, 06:12:44 AM   #9
inthehouse
inthehouse's Avatar
Reputation: 0 inthehouse is on a distinguished road
well, I went to my local dealership to check out the 5 series. As i started to reverse I heard a gringing noise. One of the salesman came out and told me to turn it off and have it checked out right away. I ended up waiting for 3 hours in there lobby. they did the SMG recall and they drained the fluid and replaced with fresh diff. oil. they told me that the cluch in the diff. wasnt pickin up any oil and that was why it was grinding? they took it around the block couple of times and its been fine ever since!
ravi
Jump to top inthehouse is offline   Reply With Quote
Old Tue, Aug-10-2004, 06:23:23 AM   #10
Kevin034
Kevin034's Avatar
Reputation: 0 Kevin034 has disabled reputation
yeah man, the M3 is a piece of sh1t. Just beat the sh1t out of it, it'll sort all it's problems out by itself.
Jump to top Kevin034 is offline   Reply With Quote
E46M3 differential grinding ('01-05) Why the problem? johnw E46 M3 (2001-2006) 133 Mon, Aug-03-2009 07:08:55 PM
Problem: Low kind of grinding noise pulling in 6 gear NewYorkBrianM3 E46 M3 (2001-2006) 5 Mon, Sep-25-2006 09:30:26 PM
Notice grinding noise when turning even after differential oil change? TeeKay E46 M3 (2001-2006) 5 Thu, May-11-2006 01:40:21 AM
[B]grinding noise in rear..help[/B] onenastym3 E36 M3 (1992-1999) 9 Fri, Nov-04-2005 12:49:50 AM
Rear Differential Grinding NOISE MattMan E46 M3 (2001-2006) 0 Tue, Jan-21-2003 08:28:45 PM
Discussing Damaged Rear Differential---GRINDING NOISE-HAVE U HAD THIS PROBLEM in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
