Old Thu, Feb-16-2012, 03:41:35 AM   #1
turbo_911
auto detailing
turbo_911's Avatar
Reputation: 0 turbo_911 is on a distinguished road
Default Another leaking coolant thread :) need some advice
I noticed that my car is leaking coolant only when I come home after a drive. When the car is cold, nothing is leaking, only when warm. It is dripping VERY slow and overnight you probably will get less than a tea spoon full.
Now the question is, is there any way to trace the leak without taking apart everything?
I've attached two pictures two show where it is leaking from.
In April 2011, by previous owner, water pump, thermostat housing (alum), thermostat, lower radiator hose were replaced. I don't know what kind of water pump it is. I bought the car in August 2011 and have receipts from work. It says it was $85 for pump. Must be OEM? Could it be leaking?
Jump to top turbo_911 is offline   Reply With Quote
Old Thu, Feb-16-2012, 04:01:53 AM   #2
sharpie
Reputation: 0 sharpie is on a distinguished road
Default Re: Another leaking coolant thread :) need some advice
Assuming the first pic is the front of the oil pan - yes it could be the water pump, but it could also be the thermostat housing. You should probably at least take the fan and clutch off to see.
www.kleinconcept.com
Jump to top sharpie is offline   Reply With Quote
Old Thu, Feb-16-2012, 04:02:43 AM   #3
MMMGP
Marty
MMMGP's Avatar
Reputation: 0 MMMGP is on a distinguished road
Poland
Taking the fan off, then the belt, and finally the water pump pulley is no big deal. A few minutes of work and you should be able to see exactly where the leak is coming from.
I have read stories here of the aluminum stat housing leaking... dig into it.
Jump to top MMMGP is offline   Reply With Quote
Old Thu, Feb-16-2012, 04:27:22 AM   #4
turbo_911
auto detailing
turbo_911's Avatar
It would be easy if I had a fan lock tool but since I don't, that's why it was worth a try ask to see if there is any other way to find out what's leaking without taking everything apart
Old Thu, Feb-16-2012, 04:49:34 AM   #5
MMMGP
Marty
MMMGP's Avatar
Poland
Yeah, I bought the lock tool years ago. It's a must have. BTW, I thought BMW coolant was blue, not green.
Old Thu, Feb-16-2012, 08:30:23 AM   #6
bimmaboy88
bimmaboy88's Avatar
Reputation: 0 bimmaboy88 is on a distinguished road
Armenia
don't forget to use bmw coolant (blue).
Eibach Pro Kit
Koni Yellows
H&R Sway Bars
Rear Adjustable Control Arms
AFE Stage 2
Sugar, Spice, and Everything Nice
Jump to top bimmaboy88 is offline   Reply With Quote
Old Thu, Feb-16-2012, 02:43:29 PM   #7
turbo_911
auto detailing
turbo_911's Avatar
Oh that's news to me, I didn't know that BMW coolant is Blue. All other cars I've had, the coolant was green so I though ok that's coolant leaking. I bet if it was blue, I would be like, what's that leaking?
Any difference between normal green and BMW blue coolant?
I wonder if the water pump failed just after less than 5k miles on it? Is that possible?
What else should I check while I'm taking that apart?
EDIT:
Ok I've read online a little and some say mix the BMW coolant with distilled water? Some say use Zerex G-05? Some say green is fine? I'm lost lol
Old Thu, Feb-16-2012, 04:34:39 PM   #8
MMMGP
Marty
MMMGP's Avatar
Poland
Here is what's in the green stuff--Peak 50/50 premix.
This is the OEM stuff--additives like acids and hydroxide. I wonder what the bittering agent tastes like.
And here is the BMW chart for mixing:
Old Thu, Feb-16-2012, 04:44:57 PM   #9
tbaker474
Reputation: 0 tbaker474 is a jewel in the rough
Mix BMW blue coolant 50/50 with distilled water. The BMW stuff is phosphate free which is a must.
Jump to top tbaker474 is offline   Reply With Quote
Old Thu, Feb-16-2012, 04:56:54 PM   #10
egebhardt
egebhardt's Avatar
BMW coolant is blue......... for a while. The the blue additive falls out of solution after a few months and it then looks green.
96 Boston on Grey 2dr - New 5.17.13
98 Estoril on Grey 4dr - New 3.25.12
99 Estoril on Sand 2dr - Sold 7.31.12 Eric driving it
Discussing Another leaking coolant thread :) need some advice in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
