Old Mon, Jul-30-2012, 12:02:30 AM   #51
Magic M3
Magic M3's Avatar
Reputation: 0 Magic M3 is on a distinguished road
Default Re: Another leaking coolant thread :) need some advice
Strange, Calvin and I flushed mine about 2 years ago when the new head went on. BMW coolant was used with distilled water. I looked the other day, and the fluid in the overflow tank appears green. I've heard that eventually turns green and confirmed this with a buddy that owns an Indy Bosch auth service center. Not sure why but it just happens.
"What, that?....Oh, it's Stock....ish!"
Jump to top Magic M3 is offline   Reply With Quote
Old Mon, Jul-30-2012, 12:08:09 AM   #52
M3n00b
2012 Formula 1 Game Champion!!!
M3n00b's Avatar
Every time I've changed mine its been blue.
...tapatalk...
2013 F1 Game:
Originally Posted by propchef View Post
Ferrari to Alonso: F**k the tires, full speed ahead.
Old Mon, Jul-30-2012, 12:28:58 AM   #53
white-hot
has left the building
white-hot's Avatar
Yeah, blue. Just did the vert, bluish after 5 years. You running any other additives in there?
Old Mon, Jul-30-2012, 02:45:55 AM   #54
aaron1996
Reputation: 0 aaron1996 is on a distinguished road
Originally Posted by Richardsperry View Post
Look, it's not that hard.
If you are incapable of doing it yourself for whatever reason, take it to a qualified mechanic.
But, I'm betting it's the expansion tank. Either the small hose that goes in the top, or the level sensor at the bottom, or the tank itself split.
What ever it is, that's a pretty big leak.
Thank you sir Richard, so here is what I did. I drove from church back home and popped the hood immediately as I parked. I noticed hissing sounds form the middle of the engine which sounded more like a sprinkler. I then saw where the leak was coming from a small hose somewhere underneath everything visible on top. Cut the tip of the hose and clamped it back on. Here are a couple of photos of tip that was cut off and when I was done.
http://i1220.photobucket.com/albums/.../Photo0210.jpg
http://i1220.photobucket.com/albums/.../Photo0211.jpg
Then I bled the system again and plan on testing it later.
Jump to top aaron1996 is offline   Reply With Quote
Old Thu, Aug-02-2012, 06:22:25 AM   #55
aaron1996
Car is running normal as it has been. Getting replacement hoses in hopefully by Saturday so I'll have no worries on leaks.
Old Thu, Aug-02-2012, 07:25:49 AM   #56
MMMGP
Marty
MMMGP's Avatar
Reputation: 0 MMMGP is on a distinguished road
Poland
I refreshed my cooling system in March and discovered that one of my hoses (upper) appears to be defective. I ordered the Elaplast hoses from Pelican; upper, lower, and expansion tank to radiator hose, thinking I could save a couple bucks. Well.... bad move on my part.
First off, the expansions tank to radiator hose was incorrectly molded. The shape of the hose was way off so I left my review on the Pelican site (got a full refund) and I purchased an OE hose from the dealer.
Then a few months back, I began to notice a strange build-up/crystallization at each end of the upper radiator hose. The coolant appears to be seeping through the ply layer and is using this layer as an exit-to-atmosphere channel. This time around Pelican is not down with the full refund, instead they are sending me a new OE hose for $11. Eh, decent deal, but a new hose from thebmwpartstore.com is less than $16. I bet they think they are doing me a favor (originally I thought they were sending me an OE hose for free) but I just don't want to deal with it anymore. Send me the friggin' hose so I can put my cooling system refresh to bed for another 80K miles!
Point of the story is, don't cheap out! Get friggin' OE hoses from the dealer and call it a day! The lower hose is holding out, for now... but i'll be checking on it monthly.
As for the blue BMW coolant turning green, maybe this happens when Water Wetter is added to the cooling mixture?
Jump to top MMMGP is offline   Reply With Quote
Old Fri, Aug-03-2012, 11:21:41 PM   #57
runindawg
95M3 04ZHP
Reputation: 0 runindawg is on a distinguished road
Aaron
I don't know what you plan but I would use that hose failure as a heads up that all hoses need to be replaced.
I just replaced every hose in the system on my '95. I am original owner and had already done the easy to get to hoses, but this time I did everything.
Some of them are a pain to get to but it can be done without pulling the intake manifold. I can't say which method would be quicker.
Jump to top runindawg is offline   Reply With Quote
Old Sun, Aug-05-2012, 02:57:52 AM   #58
aaron1996
Originally Posted by runindawg View Post
Aaron
Thanks Nitram. Yes, it did give me a heads up. Hoses came in and also replaced radiator, water pump, and thermostat.
Discussing Another leaking coolant thread :) need some advice in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
