#11 | |
has left the building
#12 | |
Craig
95 BMW M3 Current Project Cosmos Black, E46 6SP, VSL Rad, Stewart Water Pump, AA Header with 3" exhaust, aFe CAI, Euro HFM, 24lbs/hr injectors, unknown tune?, BW SS Brake Lines, Hawk HP+ Pads, M X-Brace, Mason Engineering Aluminum Strut Bar, MM Underpanel. To Do: Overhaul rear suspension, front suspension Tucson, AZ |
#13 |
Craig
I finally got the CCM out and popped it open the CCM to take a peek. I really didn't expect to see anything obvious, but I was wrong, the failure was completely obvious:
![]() The two shunts on the right are burned through. Once I got it out I measured resistance from the license plate light pins in the connector to ground and got 3 ohms, which seems right for cold light bulbs. Not sure why these shunts burned, but the lines to the bulbs seem fine. I have a used part on order.
95 BMW M3 Current Project Cosmos Black, E46 6SP, VSL Rad, Stewart Water Pump, AA Header with 3" exhaust, aFe CAI, Euro HFM, 24lbs/hr injectors, unknown tune?, BW SS Brake Lines, Hawk HP+ Pads, M X-Brace, Mason Engineering Aluminum Strut Bar, MM Underpanel. To Do: Overhaul rear suspension, front suspension Tucson, AZ Last edited by enderw88; Mon, Jun-11-2012 at 12:23:54 AM. |
#14 |
![]() Location: Bremerhaven, Germany
Which pair of shunts burned out: the taller RM8 and RM9 or the shorter RM9 and RM10? I might double check all the fuses supplying power to the CCM (e.g. F37) and confirm they are the right size. Someone may have substituted a larger one and burnt out the shunts (the post #8 scenario).
#15 |
Craig
RM7 and the one next to it burned.
![]() I thought about this all night and did a little forensic research this morning before I left for work. I think this started as the dreaded trunk harness problem. There is evidence of repair of the license plate positive wires just below the deck lid seal. I think they shorted and either that burned out the CCM or a PO tried a larger fuze, before repairing the harness. In any event, I checked all of the fuze values and they are at spec.
95 BMW M3 Current Project Cosmos Black, E46 6SP, VSL Rad, Stewart Water Pump, AA Header with 3" exhaust, aFe CAI, Euro HFM, 24lbs/hr injectors, unknown tune?, BW SS Brake Lines, Hawk HP+ Pads, M X-Brace, Mason Engineering Aluminum Strut Bar, MM Underpanel. To Do: Overhaul rear suspension, front suspension Tucson, AZ Last edited by enderw88; Tue, Apr-03-2012 at 02:29:46 PM. |
#16 |
Thanks, I see it now. I thought the grey might have been the lighting: it appeared similar to me on both shunts but isn't really.
#17 |
Craig
It is hard to photograph, naked eye it really stands out.
#18 |
Glad to see you found the problem! Lets hope that is the last electrical issue you have!
#19 |
I think I am having a similar problem. My trunk wire harness was totally messed up... PO repair turned out to be ridiculous. I crimped the wires again and now just my right license plate light works. I measured 1.8v at the left one (where is this low voltage coming from?). Could this be an issue with the check control ?
#20 | |
Craig
