Can anyone guide me to a ring & pinion change on an e46 M3 differential? Buying the R&P is one of the easier steps. Finding all that I will need, seals, bearing, etc. Their part numbers and where to get them is not so easy. Finally, understand what's involved and the tricks necessary to do the rebuild, a DIY is just about impossible to find online.
I have purchased a used diff and the R&P. I would like to know what else I need. My plan is to change the diff and include a 3-clutch w/ variable ramps. I just think the $4k+ the market is charging is a bit overpriced. Can anyone help?
Brembo 355/345 | PFC 01s | TCKline Koni D/A-Front S/A-Rear 500/600 | Vorshlag CP UUC Sway bar | Recaro PP | Schroth harnesses | Volk TE37 9.5x18 | 4.10 diff subframe reinf plates | Continental Race Slicks | AiM Pista | Adjustable AL rear lower control arms | Bimmerworld Race exhaust | 1 slow poke in-training .In-Progress: guibo, drive shaft bear replacement. Coming soon: Sunroof Carbon Fiber install, front brake cooling ducts install. Wish List: Autosolutions SSK, Aeromotions Rear Wing, front splitter, HANS |
If it ain't lightweight, it ain't the right weight.
![]() Location: LA/OC/SD
It's really hard, from what I've read. Which is why there are shops dedicated for this kind of stuff.
I would buy the parts then just take it to a good diff shop and have them do it. I think it costs like $280 to get my 4.10 put in, plus whatever the parts were to fix my leak.
Current: 1969 Ford Mustang Coupe; 351w (5.8L) carb engine; Champion 4 row radiator; Edelbrock Performer RPM Intake Manifold; Edelbrock 750 CFM Carb; 15" Cragar Wheels; 215/60-15 front tires, 255/60-15 rear tires; Doug Tri-Y Headers; Custom 2.5" Dual Side Exit Exhaust w/Xpipe; MSD 6AL; Electric Fuel Pump; March Performance U/D Pulley Set; Monte Carlo Bar; 3200 lbs. ![]() 1995 M3; single 3" exhaust after cats; CF hood; Apex ARC-8 17x9" wheels; Conti DW 245 square; BC Racing Coilovers. SOLD: E46 M3 SMG; Intrax coilovers; ACPT CF DS; SS V1 Headers/Section 1; Zionsville Type 17 kit; VAC Ultra light pulley set; BMW MS 4.10; Evolve-R Tune; 2980 lbs.
I'm trying to get the full list of parts, that's prob. #1. Any idea? Also, where can I buy a 3-clutch LSD w/ variable ramps?
#4 |
tryin' to stay classy
![]() Location: NYC
I've got brand new carrier bearings if you're interested
2005 BMW M3 ZCP 6spd, black on black ENGINE: aFe Dynamic air scoop | DINAN TBs | VAC Motorsport pulleys EXHAUST: SS Stepped V1 Headers | SS race cats | SS resonated X-pipe SUSPENSION/CHASSIS: Moton Street Sport S/A coilovers | Hyperco 450/550 | GC Street camber plates (-2.4*F) | GC RSMs | RE weight jacks | TMS RTAB limiters | TMS RCAs (-1.4*R) | Mason Engineering Race FSTB | OEM front strut tower reinforcement plates | TMS rear subframe reinforcement WHEELS/TIRES: Volk TE37s in gloss white, 18x9.5 +22 (F) 18x10.5 +22 (R) | Michelin PSS 245/40 and 275/35 DRIVETRAIN: 3.91 BMW Motorsport SHIFTING: AS 30% SSK | Illuminated ZHP | RE tranny mounts | GSP clutch pedal with UUC bushings | UUC "big boy" clutch stop | CDV delete | TMS SS clutch line BRAKES: Stoptech SS lines LIGHTING: Lightwerkz TFX retrofit | Digital 55w 4300K HIDs INTERIOR: Euro first aid storage boxes |
#5 |
Obliging
![]() Location: Poorifornia
I wouldn't recommend doing it yourself unless you are extremely patient AND experienced. There is a good bit of precision involved.
There is no need to be upset...
#6 |
30 something
![]() Location: San Diego
That should tell you something.
'04 46M 6MT || '01 330Ci 5MT |
#7 |
![]() Location: Harrisburg/Hershey
02 M3 JB/IR VF StageX-V2 T-Trim,16psi,Direct Port Meth Injection,Walbro 255 Intank,Walbro 255 Inline,-8 Fuel feed, 750cc Injectors 550whp, before tuning SuperSprint V1 stepped headers/Sec 1,AA Gen 3 Muffler Brembo Monoblock 6/4,TCK D/A 500/500,Turner sways,VMR V718,TMS Solid Camber Arms ClutchMaster FX700 twin disc clutch,VAC Solid Diff Bushings, Solid Sub Frame Bushings, AS SSK Coming Soon: 18x9.5/10 Apex ARC-8, Drag radials, Custom Sec 2 03 TiAg/Black SMG- SOLD 03.5 SilverGrey/Imola SMG- SOLD FOR SALE: GT1, Resurfaced Flywheels, S54 head PM for details Performance Installs,Maintenance,ICOM,Engine Builds,Diff Installs,Tool Rentals |
#8 |
I have a friend who is a mechanic. He's going to do it, not me. But before I can have him do it, I need to have the parts and would like to learn it myself. He has done diffs, full transmissions, and not the least installed an LS1 into an E36 M3 - No small feat there. I trust he is very good around a car.
#9 |
It just tells me no one has taken the time to do one.
#10 |
CSL (finished) inside
Be the first!
| 4.10, differential, diy, e46, ring and pinion |
