Old Tue, Apr-17-2012, 05:50:47 PM   #1
ultamte
ultamte's Avatar
Reputation: 0 ultamte is on a distinguished road
Default Part Number/Diagram Help - OBD Port mounting screws/bracket
I have looked through realoem.com and bmwfans.info and can not locate the diagram that shows the OBD port mounting. This is below the drivers steering wheel under the panel above your knees.
My OBD connector is just hanging loose, and I want to buy the screws/parts to secure it in place. Can anyone help with the part numbers, or better yet where the diagram is located in either of those parts databases.
Thanks for any help you can provide, I want to tidy up underneath my dash when I replace my clutch master cylinder.
Chad.
6/98 M3 Convertible
________________
ultamte
E36 M3 Convertible: Estoril/Black/5spd
E39 540/6: Arctic Silver/Black/6spd
E30 325ix: Lachsilber Metallic/Silver/5spd - SOLD 2/24/11
Jump to top ultamte is offline   Reply With Quote
Old Tue, Apr-17-2012, 07:56:10 PM   #2
haus
If I can do this DIY, anyone can.
haus's Avatar
Default Re: Part Number/Diagram Help - OBD Port mounting screws/bracket
I had mine off yesterday. There are two screw clips (I'm not sure what they are called, but screw clips brings up the right images in Google). Those slide into the knee bolster and a couple of sheet metal screws with washers screw through the OBD jack and into the clips through the holes in the bolster.
I'm guessing it's 12 and 14 here, but someone will probably correct me. But I don't know what part 21, "bracket left" and "bracket right" are, so that's why I'm not sure this is the right thing. Honestly, a couple of clips and screws from any hardware store would do the job.
http://www.realoem.com/bmw/showparts...75&hg=51&fg=30
- Greg
Cosmosschwarz / Terminal Grey "Rips" Amaretta 1997 ///M3 - 78K Miles
Old Tue, Apr-17-2012, 08:28:59 PM   #3
ultamte
ultamte's Avatar
That is the diagram I was looking at, but I wasn't sure if it was 12 and 14 that hold the obd in place. Thought there might be a better diagram showing the obd port and how it attaches.
________________
ultamte
Old Tue, Apr-17-2012, 09:12:59 PM   #4
m3onrails
E-Famous
m3onrails's Avatar
Reputation: 0 m3onrails is on a distinguished road
Do you have that knee bolster in your car? (#17)
It's a big useless metal piece, I removed mine for weight savings but then had to build a custom bracket for my OBD port. If your previous owner removed that piece like I did, then that's your problem. If you have that piece installed, then you'll see exactly where the OBD port mounts to it, and any screws should work. I threw mine out, kinda wish I had held onto it so I could ship it to you if that's indeed your problem. Good luck man!
Jump to top m3onrails is online now   Reply With Quote
Old Tue, Apr-17-2012, 11:27:56 PM   #5
ultamte
ultamte's Avatar
Yes, I do have the knee bolster in the car. I didn't get a good look at the mounting points when i was doing my brake switch, and I like everything to be OEM and to use OEM parts/screws etc. I will probably take a quick look before ordering those screws.
Thanks.
________________
ultamte
Old Wed, Apr-18-2012, 02:04:12 AM   #6
RND1
Reputation: 0 RND1 is on a distinguished road
I have the exact same issue so thanks for posting. My car is missing the OBD cover and the connector was just loose above the kick plate. I'd like to put it all back together as it originally came from the factory so let me know what you find out.
Jump to top RND1 is offline   Reply With Quote
Old Wed, Apr-18-2012, 03:19:11 AM   #7
m3onrails
E-Famous
m3onrails's Avatar
Awesome, sorry I couldn't be more help. Post up what you find!
Old Sat, Apr-21-2012, 02:06:59 AM   #8
haus
haus's Avatar
Picture for you.
Sent from my SAMSUNG-SGH-I717 using Tapatalk
- Greg
Old Sat, Apr-21-2012, 02:08:50 AM   #9
haus
haus's Avatar
Other side
- Greg
Old Sat, Apr-21-2012, 04:35:24 PM   #10
ultamte
ultamte's Avatar
Other side
Thanks haus!!!... That is a perfect picture, and it looks like the screws and clips I ordered are correct. Should have the parts early next week.
Thanks again!!!
________________
ultamte
Discussing Part Number/Diagram Help - OBD Port mounting screws/bracket in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
