Old Sat, Apr-21-2012, 01:26:03 AM   #1
white-hot
has left the building
white-hot's Avatar
Default WARNING: RE RSM's and Koni 1159S not compatible!
Ok, so I get my new Rogue Engineering RSM’s in today. Loving these things! So I grab the new Koni 8210-1159Sport externally adjustable shocks and mount them up. Then, a problem:
As you can see this shock, at least the ones I got, come with a metal cover that is quite a large diameter. When the RSM is mounted there is no clearance for the nuts, even if you try and start threading with the top plate lifted and the nut flat on the base. There is simply no way to make this work short of modifying something. I am quite sad but will have to move to one of the classic top-mount style RSM’s. Good news is I can just use my old ones, the better one you can get from TMS by JT Design, which are still like new.
Anyway, I know this shock will not be a very commonly picked unit, but just wanted to put this up to save anyone else the trouble.
Old Sat, Apr-21-2012, 02:03:19 AM   #2
Jrrrrrrr
M3 Boot
Jrrrrrrr's Avatar
Default Re: WARNING: RE RSM's and Koni 1159S not compatible!
Sucks, but thanks for the PSA. Such is the price of trying out "not so picked units."
Old Sat, Apr-21-2012, 02:16:11 AM   #3
white-hot
white-hot's Avatar
Tell me about it!
Old Sat, Apr-21-2012, 02:42:44 AM   #4
cscat87
cscat87's Avatar
Reputation: 0 cscat87 is on a distinguished road
Kudos for being a guinea pig. My RE RSMs and Bilsteins are a match made in heaven
03 M3 Convertible 6-spd- Alpine White/Cinnamon
97 M3 Coupe 5-spd- Cosmos/Black
Jump to top cscat87 is offline   Reply With Quote
Old Sat, Apr-21-2012, 02:45:25 AM   #5
KWorker17
Brett Favre of M3's
KWorker17's Avatar
Reputation: 0 KWorker17 is on a distinguished road
Arent they upside down?
Edit: Guess not, fail on my part.
Kevin
Jump to top KWorker17 is offline   Reply With Quote
Old Sat, Apr-21-2012, 04:31:30 AM   #6
EricSMG
30 something
Wait - are those 10mm mounts, or 12?
Because stock is 10mm...
'04 46M 6MT || '01 330Ci 5MT
Old Sat, Apr-21-2012, 11:47:09 AM   #7
Richardsperry
95 SC M3
Richardsperry's Avatar
Not entirely sure what I was looking at in the first picture. Is that like the Koni version of the bumpstop/plastic boot on the stock shocks? (dust protectors) or is it integral to the shock?
Old Sat, Apr-21-2012, 02:19:02 PM   #8
M3RKED
Reputation: 0 M3RKED is on a distinguished road
No you're right the bolts are supposed to face the other way
Jump to top M3RKED is offline   Reply With Quote
Old Sat, Apr-21-2012, 02:26:00 PM   #9
Magic M3
Magic M3's Avatar
Reputation: 0 Magic M3 is on a distinguished road
If those are bolts, not studs, flip em and run them up from the bottem. If they are studs, disregard.....
"What, that?....Oh, it's Stock....ish!"
Jump to top Magic M3 is offline   Reply With Quote
Old Sat, Apr-21-2012, 03:05:09 PM   #10
white-hot
white-hot's Avatar
Rogue offers 12mm washers for the mounts to handle the larger diameter shocks.
Yes, sorry guess the pic is too close. The yellow part is the metal dust cover that comes with the shock. The shock body is larger than a normal OE shock and therefore the dust cover is also larger, and the fact that it is metal makes it larger still. I could take the dustcover off but an OE one would not work and would have to come up with something else. Simpler to just use a different mount.
They are not upside down, the Rouge Engineering mounts are a downward facing stud design with the studs welded to the top reinforcement plate. Can’t turn them over.
Discussing WARNING: RE RSM's and Koni 1159S not compatible! in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
